#51 | |
Re: 20 mpg or not?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#52 |
high-Tech Red Neck
Re: 20 mpg or not?
I would say you have a snowball's chance in H-E double hockey stick of getting 20mpg out of a 350 unless you have full EFI, custom tune, no emissions equipment and a 4L80E
Considering you are in a CC dually you are going to need 19.5's to bring the rolling resistance down, and lots of other things. Really you would be better off tossing a Cummins in it. I have a Vortec 454 in my 2000 CC Dually, it is much more aerodynamic than yours, everything on it has been tip top tuned, cats and emissions gear removed, running 65mph I get 14 mpg empty. with a 350 you are going to find that with a 350 you are going to be underpowered in that dually which means less MPG's especially when you hook a trailer to it.
"He used to be a pretty nice feller, now he's a welder!" |
#53 | |
high-Tech Red Neck
Re: 20 mpg or not?
#54 | |
Re: 20 mpg or not?
Im not sure what your meaning by 19.5 what is that. Tossing in a cummins. I dont know if comparing a 454 to this small block is quite a fair comparison. You do realize catalytic converters EGR and other emissions help fuel mileage. removing that stuff would surely hurt mileage. I don't believe this engine is going to be under powered. If it were in anything else it would for sure make 20 and then some. By the way the truck is not a dually and wont be pulling very many trailers. I am looking in to the sequential over the batch fire. cost, reliabilty, and ease of installation will all play a role in my decisions on that. |
#55 | |
high-Tech Red Neck
Re: 20 mpg or not?
In your setup I think the 5.7 with the TPI manifold will be great. I for some reason thought you were building this truck as a tow pig not as a DD for your wife. 19.5's are 19.5" wheels that mount commercial truck tires, they have a much stiffer side wall and thus much less rolling resistance and better MPG's but not applicable to your application. one thing to consider with the 411 ECM is that you can run individual coil packs if you want to.
#56 |
Re: 20 mpg or not?
Individual coil packs will help mpg and power overall adding a msd helps too.
#57 | |
GoatLube Experss
![]() Join Date: Oct 2009
Re: 20 mpg or not?
the TH400 had a first gear ratio of 2.48 and the 700R4 has a firts gear of 3.06 , this will help with get the big truck roll'n even with a 3.73 or higher gear set.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#58 | |
Re: 20 mpg or not?
Those tires are just about 33" tall. Even with the .70 overdrive I'd like to see the rpm knocked down further for max highway fuel economy, and that would require knocking some of that gear out. With the 3.06 first gear the truck gets moving easily enough and doesn't need those 4.11's. A 3.73 would work nicely and drop the cruise rpm another 3-400, probably worth another mpg. You going carb or fuel injection? Either will do the job well enough if you can tune the carb properly (again using a wideband). To maximize fuel injection you'll need tuning software with the wideband, and concentrate on lean cruise conditions with light throttle input. Lots of variables here and alot to be gained. If I can get 14 mpg highway from a 502 in my 79 1 ton with no overdrive then I see no reason why you can't do better with a 350. I've never maximized my combo as far as squeaking mpg out of it. Still has heavy 16.5 steel wheels, mechanical fan, and few other tweaks that can be addressed for max efficiency. Basically a sharply tuned quadrajet on a performer intake with a tweaked distributor, headers, 3" exhaust, cold air intake setup is all that's been tweaked on. Stock 3.73 gears with a stock 30" tire running a 400 turbo. Seems to work pretty good for what I use it for so it's left alone. My blazer is probably the closest to your combo. But I've installed a 6.0 LS engine in front. I run the 4L60E (electronic version of your 700) and also use a 33" tire but I installed 3.73 gears for a mix of performance and economy. The 6.0 (364 cubes) is a stock 04 LQ4 down to the stock exhaust manifolds. I removed the mechanical fan and went dual electric to cut down on some drag. Custom 2 1/2" dual exhaust. I tuned it with a wideband, concentrating on lean cruise, aggressive DFCO tables, some throttle and timing table tweaking as well as trans table tweaking etc...This is a 4x4 still using the stock (heavy Hp robbing) 205 transfer case and the truck weighs 4,960 lbs. I get 17 mpg around town, and 22 mpg highway. So yeah, 20+ is doable in these old boxy trucks with the right parts, but what I've done isn't cheap either. If it were my truck (and you probably don't want to hear this ![]() |
