#51 |
Re: CPP spindles
No you can't.
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
#52 |
Re: CPP spindles
Panel Beaters C.C. |
#53 |
![]() Join Date: Jul 2009
Re: CPP spindles
Keith...
I got a set of the Modular drop spindles with the ears in a batch of PB stuff that I bought on here...I thought they were going to be the ones without the "ears", but no such luck. I also got the upper & lower balljoints in the buy, but the part # embossed on the spindle indicates '73-'87, but the balljoints with the PB arms are '63-'70....but they seem to fit the spindles correctly. How is that possible? I haven't actually put them on a vehicle, just a test fit on my work bench, but no excessive slop or total lack of fitment noted...? |
#54 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: CPP spindles
I bet this has already been the cause of some mix ups. The same freakin part number for a different drop and/or design. How brilliant are these boneheads? Maybe that was the whole point. An easy way to get rid of the old inventory and many buyers wouldn't catch it.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#55 |
Re: CPP spindles
So has anyone recently bought Modular spindles?
Do they now have cast-in caliper mounting ears?
#56 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: CPP spindles
So if you order part numbers: Cp4s1 thru cp4s10 you have no idea which version you are getting. (depending on the the spindle suppliers amount of old stock left on his shelf) Big companies like Summit Racing should have the newer product design.
#57 |
Re: CPP spindles
I sent a message to the CPP Ebay Store, asking if the Modulars have Caliper Ears, or they still need the extra caliper mounting bracket, and he said they still need the $75 bracket.
#58 |
Re: CPP spindles
The true "modulars" are on the bottom. The debate on part numbers and new vs old is the top picture.
#59 |
Re: CPP spindles
So, the Modulars still don't have ears?
#60 |
Re: CPP spindles
No the modulars don't, that's the reason for the $75.00 brackets.
#61 |
Re: CPP spindles
And it didn't help when CPP started making their 2.5" drop spindles with the same appearance (tie rod arm), as their Modular design.
New design vs their old design,...
#62 | |
Re: CPP spindles
So the original Standard Design is now a Modular Design with ears?
#63 | |
Re: CPP spindles
Here's a recent thread where a guy bought the new design and they still move the wheels out about 5/8".
. Quote:
#64 | |
Re: CPP spindles
Only the 2" MODULAR drop spindles (with the ADD-ON bracket) narrow the track width.
#65 | |
Re: CPP spindles
After searching the forums some more, I came to that conclusion That clears things up. I do know that some are still being told that cpp non-modular won't move their wheels out even though they do move the wheels out. So far the reports are around 5/8" per side. That was also my experience. Member Leverhead is supposed to be getting some Modular, and he will then post how they relate to drums track width.
#66 |
Re: CPP spindles
I would imagine that if you also replaced your springs with lowering springs at the same time you replaced your spindles with lowering spindles that your width would increase due to the springs changing your geometry and the results would be skewed.
I am not at the point of ordering my spindles yet but maybe next year. Now I'm going to wait to see if I can get the modulars as I want the option of larger brakes in the future. Great info here. Good work guys.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#67 |
TNT-MOTORSPORTS
Re: CPP spindles
If you use the standard 2-1/2'' drop spindle and then replace it with the 2'' Modular 2-piece spindle ( bolt-on caliper bracket ) and change nothing else it will pull the front wheels in 1-1/8'' per side ..... THIS Has been verified by me first hand. I have been involved in three different trucks that had the wrong backspacing on the front wheels and were undrivable. We changed out the front spindles to the modular design and in all 3 instances it pulled the wheels in by 1-1/8'' per side and the trucks became drivable. These spindles require a bolt on caliper mount bracket also.
I stock the spindles and brackets and have sold at least 10 sets or more of them .... They work if you need to narrow the front track width on your disc brake equipped truck. I am not guessing on this .... this is FIRST HAND experience. |
#68 |
Re: CPP spindles
So when you say "undrivable" What do you mean? Spindles were making it have erratic behavior or the the wheels didn't work?
#69 |
![]() Join Date: Mar 2011
Re: CPP spindles
Tommy, thanks for posting up the info...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#70 | |
TNT-MOTORSPORTS
Re: CPP spindles
When I say undrivable ... I mean the truck has the wrong backspacing wheels on the front and they are rubbing on the outer edge of the wheel well or fender. One of the owners had a set of wheels that he was told would fit his truck .... But when he tried to put them on ....You would not have been able to drive it without destroying the tires. It had standard CPP drop spindles on it. By putting the 2-piece modular spindle on it ... the wheels were pulled in far enough that the clearance issue was fixed and the tires no longer rubbed. The problem that I see the more that I deal with wheels and trucks (I have been doing this for over 30 years ) Is that alot of people do not understand backspacing or offsets .... ALOT of people are confused by the numbers. No problem ... just trying to help ... ! |
#71 |
Re: CPP spindles
a lot of cpp's spindles and other parts are on sale at summit right now.
I bought spindles for $206 and a pair of 6 lug rotors for $116
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
