07-01-2013, 03:57 PM | #51 |
Re: My Old 66 chevy
Here's some pictures of the exhaust system. Mufflers are in a temporary position so that When I paint the frame the exhaust system will easily drop out when I pull the motor. Gonna put the mufflers underneath the bed( were they belong).
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
07-01-2013, 04:02 PM | #52 |
Re: My Old 66 chevy
More photos.....
07-01-2013, 04:04 PM | #53 |
Re: My Old 66 chevy
Anybody want this? Maybe for a rat rod?
07-04-2013, 04:24 AM | #54 |
Re: My Old 66 chevy
I've noticed in other posts that aftermarket headers where the buyer has welded up the flange to the pipes instead of the tack welding to the exhaust pipes to the flanges. I'm curious if you have had any problems with leaks or if the pipes stick out a 1/16th more than the flange which will cause a better seals. have a 292 and am wanting to get some more power. want something different than 350 that'll get up and go. yeah i know a 292 is for towing but....
79' c20 std cab 292 3speed granny - daily driver. 77' c30 std cab 454 th400 4.10 - fathers truck then mine. 95' ford bronco 302 4speed overdrive. 2002 mustang auto v6 - girlfriends daily driver. Debt just means that you had more fun than you're suppose to have |
07-04-2013, 04:44 PM | #55 | |
Re: My Old 66 chevy
07-19-2013, 10:50 AM | #56 |
Re: My Old 66 chevy
Well,
I did some painting on my truck last week. The board won't let me upload any pictures rights now cause something got screwed up. Plan is to pull the bed off and clean up the rear end here pretty soon.
07-23-2013, 03:46 PM | #57 |
Professional Crow Bar Tosser
Re: My Old 66 chevy
Nice truck for a starter. I plan on watching this one. Consider it subb'd.
Johnny Cash special Reminds me of my dad's old '65.
Will My Beast "Big Nasty": '92 GMC Sierra K1500 Ext. Cab L31 Swap 4x4 Conversion: 2" Body Lift, 3" Skyjacker Suspension Lift, 9.5" 14-Bolt G80 Rear, 3:73 Gears, 350cid L31 Vortec 5700, 4L60-E Overdrive Automatic My Dad's Beast: CUSTOM '97 Chevrolet Silverado K3500 4-Door Mega Cab Project: 10.5" 14-Bolt G80 Rear, 4:10 Gears, 5.7L 350cid SBC Vortec, 4L80-E Overdrive Automatic "I'd rather PUSH my Chevy than DRIVE your Ford!" |
07-23-2013, 09:35 PM | #58 |
Re: My Old 66 chevy
I bet the dual exhaust sound great
07-23-2013, 09:56 PM | #59 |
Re: My Old 66 chevy
Thanks!
07-23-2013, 09:57 PM | #60 |
Re: My Old 66 chevy
Yes sir, The dual exhaust does sound great especially after 3000 rpm!
07-23-2013, 11:06 PM | #61 |
Re: My Old 66 chevy
How did i miss this? We need a vid of that exhaust roaring!
Car & Truck Projects Google Community. https://plus.google.com/communities/...80679980403145 Youtube channel. http://www.youtube.com/channel/UC2HB...view_as=public 1964 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=419525 |
07-23-2013, 11:33 PM | #62 |
Re: My Old 66 chevy
I don't know! I haven't even made a video of it yet! I'll try to put it on youtube and then post it here. Forum has been doing maintenance and they won't let me upload pictures at the moment. Will post a video here soon. Thanks everyone!
08-02-2013, 07:56 PM | #63 |
Re: My Old 66 chevy
So I decided to wire the fuel pump on my truck to a switch in the cab so I could turn the fuel pump on and off manually....Well...Thant did not turn out to well. After I had hooked everything up I took it for a drive and on my way back(only 2 miles from home) I smelled smoke under the dash and turned out that my wires melted themselves together causing the pump to short and the truck to die. So, with the help of my handy screw driver I shoved the pump wire on the hot side of the battery and drove it home. I don't know why they melted together cause I had a 14 gauge hot wire going to the switch and a 12 gauge wire going to the pump. There was no fuse so I am glad I did not blow my pump. So I hooked it back up to the starter and know all I do is turn the key and off we go...I hope! good ole chevy!
08-03-2013, 06:46 PM | #64 |
Re: My Old 66 chevy
I put a new 100 amp single wire alternator on mine today. Works great. Forum is still all screwed up so they won't let me upload pictures. Really driving me mad now!
08-04-2013, 05:52 PM | #65 |
Re: My Old 66 chevy
Well, hoping later on this week to pull the bed off and start cleaning and painting the frame. Pull the axle and paint and clean it. Gotta alot of work under there!
08-23-2013, 06:09 PM | #66 |
Re: My Old 66 chevy
Primed my bed today. Still can't upload pictures. And its really ticking me off now. Hope they get this mess cleaned up. found an exhaust leak. Hope to fix that soon. Also painted the rear frame.
08-24-2013, 06:30 PM | #67 |
Re: My Old 66 chevy
I know it can be a pain in the neck but i use photobucket always have always will.
08-29-2013, 03:26 PM | #68 |
Re: My Old 66 chevy
Here's a video of my 64 running. Hope it works. Will post a video of my 66 soon. Sorry about my fingers getting in the way.
08-29-2013, 03:28 PM | #69 |
Re: My Old 66 chevy
The clang is two bent pushrods.
09-06-2013, 11:07 AM | #70 |
Re: My Old 66 chevy
That ol 64 runs better than my 66! Probably cause it has 50,000+ miles less than mine. The 66 292 has a strange popping noise. Checked compression all at 94 pounds. I think my cam might be flat in spots or maybe I have a bad valve spring.
09-06-2013, 03:38 PM | #71 |
Re: My Old 66 chevy
you could probably use a valve adjustment mine are getting noisy again after just 3,000 miles or so i also run 15-40w oil to quiet them down.
09-06-2013, 05:29 PM | #72 | |
Re: My Old 66 chevy
even I know I don't have burnt valves but I think I may have some bad springs. Its just telling me it needs to be rebuilt thats all.
09-06-2013, 11:14 PM | #73 |
Re: My Old 66 chevy
yeah i hear ya mine is in need of some work with the lifters for a band aid but hopefully i will not need to drive her much longer.
09-07-2013, 06:05 PM | #74 |
Re: My Old 66 chevy
Did some work with it today.
09-07-2013, 10:23 PM | #75 |
Re: My Old 66 chevy
Here's a video of it running.
