#51 |
![]() Join Date: Mar 2011
Re: 67 Rear axle bounce
OK guys, I'm bringing up this old thread to update on the rear axle bounce.
A short story first, this thread is about 18 months old, Jimbo's wife had their baby, and has since had another, so his time as been limited to doing anything with the truck. We also had to change the engine (posted in his build thread today, last 2 pages). While we did that we also change part of the drive shaft alignment. I talked with several different drive shaft makers and they all said that it was possible that the 2 piece drive shaft could set up a wobble to cause the bounce. What we did was knock out the rivets from the carrier bearing bracket, and turn it upside down. Took a string from trans to rear axle pinion to make a straight line. Moved the bracket up till drive shaft was it line. Marked and drilled 4 holes, installed grade 8 bolts and tightened down. After breaking in the new engine, we when out on the four lane and man what a difference. We pulled a couple hard throttle pulls to 5,000 rpm in drive (3rd gear) and was smooth. Got up to 90 mph and still smooth. We still have a little vibration, so he is going to take the wheels and tires to a new shop in town that has a laser balance machine and works alot with large wheels. Here's a few before and after shots of the change..Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 11-01-2014 at 12:25 AM. |
#52 |
In the old pictures above you can see how the bracket was mounted above the drive shaft. In the after pictures you can see were we moved it down, and is now under the drive shaft, making a more straight line for the drive shaft.
First pic is looking from rear toward engine 2nd pic is looking from front toward rear axle 3rd pic just a little different angle. You can see were the old holes from the rivets where. Hope this may help someone else. Thanks everyone for all your ideals and suggestions. Glad we final got this taken care of...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 11-01-2014 at 01:53 PM. |
#53 |
![]() Join Date: Sep 2014
I really appreciate when someone posts the solution to their problem. Thank you!
#54 |
So do I, and thank you for checking it out...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#55 |
So I was right!!! BWAHAHAHA! (In my best vampire like voice)
So you raised the middle bearing? I hope the tire balancing takes care of the rest of the vibration. Good luck sir and wow that is a magnificent undercarriage!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#56 |
Yes you were. Yes raised the bearing and it made all the difference. Thanks for the compliment...Jim
#57 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#58 | |
#59 | |
#60 |
Quick update on vibration issue. Turns out it wasn't the axles, sorta. I put the new axles in but the vibration didn't go away. So I started looking at the hub where the wheels go on the axle. With the car on jack stands and running you can see wheel hub is off centered which is causing the up and down bounce. It appears that my Billet Specialty wheels aren't centering up when I bolt them on. I think this is happening because the thickness of the CPP rear rotor. They don't let the axle hub stick far enough past the rotor to engage the wheel hole, thus preventing them from centering up. I'm not sure how to fix this....
#61 |
![]() Join Date: Sep 2007
You said you have 5" drop springs right? But the sway bar you have isint long enough for drops more than 4". Probably not the issue causer but chances are the rear end isint centered.
Since everything on the rearend suspension is new id get a set of original style steelies with probably 225-75-15 tires on them and see if the rearend still hops on those. If so, id say new axles are machined wrong..... Oops sorry. I just read your last post.
1967custom |
#62 |
If your wheels have acorn style lugs they should be centering themselves anyway. Just a little harder on the wheel if the hub is not engaging. I suppose a good machine shop could weld up some steel on the hub. Or you could reorder them possibly from Moser with deeper hubs maybe.
Kinda sounds like they are machined wrong anyway. You should not see any out of round movement when on the stands. Can you see it with the wheels on too? Maybe try your old axles for reference.
