Old 04-21-2013, 09:41 PM   #1
77dwh
My 78 crew cab dually build
Here is some pics of my other project. Its a 78 crew cab dually that I shortened last fall and have not had a chance to mess with lately. Finally got around to rewiring the dually fender lights and installing the roll pan on it. Currently has a 454 and 4 speeed in it but soon swapping to a 350 tbi and 700r4 to be a little more fuel and highway friendly. After that time to get the stance a lot closer to the ground and go from there.
77dwh is offline   Reply With Quote
Old 04-21-2013, 09:48 PM   #2
bilfman
bilfman's Avatar
Re: My 78 crew cab dually build
Can't wait to see some more!
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-21-2013, 10:23 PM   #3
Eyegore
What Hump?
Eyegore's Avatar
Ditto, but I have to admit I love the current stance and color (not the bed).
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 04-22-2013, 12:43 AM   #4
77dwh
Thanks I like the color also it matches pretty close to my other trucks factory color. I plan to drop it another 4-5 inches. I already thinned down the rear leaves done to 4 or 5 leaves when I did the shortening of the frame. I also have another set of doors to swap on since these have rust in the rear doors and the front doors are messed up from the old big mirrors. It will take time but will be fun when the work is finished and I can drive it more.
Old 04-22-2013, 07:41 AM   #5
rs72z
rs72z's Avatar
Nice start!!
Looking foward to more progress.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 04-22-2013, 05:27 PM   #6
LOW1TON
very cool ride, keep us posted on progress and as always lots of pictures!
"WIDER IS BETTER" (TRUCKS ONLY)
LOW1TON is offline   Reply With Quote
Old 04-28-2013, 09:57 PM   #7
77dwh
I ordered a pair of drop spindles today and gonna start fabbing up my rear flip kit and c notch hope to be a lot lower in a couple weeks time.
Old 05-06-2013, 12:50 AM   #8
77dwh
Spindles on and I cut one and a half coils off. Now time to order some perches up and build me a flip kit. Turned out lower than I dreamed it would
Old 05-06-2013, 12:13 PM   #9
rs72z
rs72z's Avatar
Did you pull the fender wells? Looks like it will rub on good bumps, at least mine did at that height.
___________________
78 ccsb dually
5.3
4l60e
Old 05-06-2013, 01:10 PM   #10
meatwagon83
meatwagon83's Avatar
mine wasnt even that low and rubbed!
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 05-06-2013, 02:54 PM   #11
rs72z
rs72z's Avatar
I had alot shorter tire on mine.
___________________
78 ccsb dually
5.3
4l60e
Old 05-06-2013, 11:13 PM   #12
77dwh
The fenderwells are still in it, I got about an inch and a half between the tires and the fenderwells. I will probably put shorter tires on and the front will hopefully raise up some when I pull the 454 for the tbi 350
Old 05-27-2013, 11:25 PM   #13
77dwh
I got my nice junkyard 90 suburban buckets in today. I will paint the console to match when I swap my doors and panels out. I also got my 350 tbi all cleaned and about ready to fill the void soon to be left by the 454.
Old 05-27-2013, 11:48 PM   #14
izzy_Britton
izzy_Britton's Avatar
This build makes thread makes me miss my old CCD
sold it 2 1/2 years ago for 300$
Keep up the work, steady as she goes. I will watch your build as you post. Looks good so far. what paint do you intend to use to paint your center console? doesnt paint usually just flake off of the plastic because it doesnt stick so well?
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 05-28-2013, 12:01 AM   #15
77dwh
I use some stuff mixed at a local auto body supply shop. it with a good cleaning then some adhesion promoter it works well for me. Used the same process on the headliner plastics of my 77 K10 it works great .
Old 06-03-2013, 01:57 AM   #16
77dwh
I got the rear flipped today. What a PITA getting the perches off to weld them back on. I need to get the materials picked up to build my c notch yet and shock mount extensions. Once thats done I will round up some shocks for the rear. Hopefully get the small block in shortly then start driving it alot.
Old 06-03-2013, 10:12 PM   #17
77dwh
requested side veiw, 225/70/16 front and 235/85/16 rear tires
Old 06-04-2013, 08:57 AM   #18
SCOTI
SCOTI's Avatar
Nice. Looks good right there. How much gap between the axle tube & frame right now w/o the c-notch?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-03-2013, 01:13 PM   #19
LOW1TON
Looks great! I love the stance! Keep up the good work and picture posting.
Old 06-03-2013, 06:44 PM   #20
SCOTI
SCOTI's Avatar
Nice....
How about a good side view pic? Current tire sizes?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-05-2013, 03:29 PM   #21
74 stepside
74 stepside's Avatar
Looks awesome! Always wanted a crewcab squarebody dually or suburban dually.
74 stepside is offline   Reply With Quote
Old 06-05-2013, 10:53 PM   #22
77dwh
There used to be one of the converted dually suburban around me. It was cool just because it was different. It was used to haul a stock car around then it got parted out for its big block a few years later. Wish I would have gotten the rear fenders off it.
Old 06-05-2013, 11:25 PM   #23
ladderback66
Good luck with the build! I have always loved the CCD"s!
ladderback66 is offline   Reply With Quote
Old 06-25-2013, 01:13 AM   #24
77dwh
Its been a busy last few days for me on the crew cab. I got the big block 4 speed and hydro boost out got the tbi 350 700r4 and vaccum booster swapped in. I got the wiring mostly sorted out and then fired it up for the time as a fuely small block. Very happy with that for sure.
Plus picker up an 86 3/4 ton suburban 2wd for parts. Its rusty in the rockers and quarters but the interior is near perfect. I am on the frnce about swapping the 86 front clip on to the crew cause the fenders on the 78 are aftermarket and fit like crap. Hoping to be driving it again in a couple weeks.
Old 11-28-2013, 04:32 AM   #25
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Really liking your build. I'm building something very silmilar, but a single cab dually. Post some pics when you get the rear done.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
