03-31-2014, 02:01 AM | #51 |
At the body shop.
Re: My 88 crew cab dually 12v cummins/nv4500 swap. If anyones done this please come i
P chassis or step van coils ought to stiff enough for a Cummins.
" That didnt make it any newer " " Dont antique the equipment " |
04-03-2014, 04:27 PM | #52 |
you need to get to work, and get this done.
77 CHEVY - SHORT BED STEP SIDE 2WD 02 CHEVY - EXT CAB SHORT BED Z71 7 INCHES OF LIFT |
04-03-2014, 05:31 PM | #53 |
Thanks bro, but I'm hopping to get it over next week to get it finished up
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
04-03-2014, 06:42 PM | #54 |
6>8 Plugless........
Nice project and that is one clean crew square to start with!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-03-2014, 07:05 PM | #55 |
Thanks, its not as nice in person as the pics make it look but still a pretty nice start for a truck from mid Missouri
08-16-2014, 10:50 PM | #56 |
KIDHLR
Any updates?
Christopher Johnson Project - Grafted In AKA the "KIDHLR" Conversion - KIDHLR Meets LPG KIDHLR 2.0 Rise of the diesel(a 6.5 powered 6 Door pickup) Romans 11:17-22 "Branches were broken off so that I could be grafted in" |
08-17-2014, 01:07 AM | #57 |
Not yet, been to busy with work to get anything done, but I do have some credit built up at my buddy's mechanics shop for some body repairs and paint work on his car so I plan on getting it over there pretty soon to get the motor dropped in and all the wiring done.
01-08-2015, 09:13 PM | #58 |
how is it going black sheep? i started this same project about 3 months ago and i am working on starting my build thread. i went with a 96 motor and 95 nv4500 trans. just finished rebuilding my 12v yesterday. i will not be lowering mine however. i will be using it daily as a work truck with a dump bed and snow plow and other things so i opted for a 3 inch body lift. how far did the transmission stick up through the factory hump?
01-08-2015, 09:50 PM | #59 |
I haven't got to work on my truck in a year now, really need to get back to it, just been super busy with work. This is the best pic I have with the floor cut out before the high hump was put in. Best I can tell with the trans cross I built its around 2-3 inches.
01-09-2015, 12:32 AM | #60 | |
Ok thank you. That is good news. I was hoping mine would clear with a 3 inch body lift. Here is the link to my build thread: http://67-72chevytrucks.com/vboard/s...=1#post6991923 we will say i got inspired to start it tonight hah |
01-09-2015, 12:38 AM | #61 |
Ya should fit fine with a body lift
01-25-2015, 12:38 AM | #62 |
It fit perfectly with the 3 inch body lift
1930 Ford Model A coupe. Original. Black with apple green wheels. 1959 Chevy Apache 3100 stepside. Built 235 6, split header, true duals, s10 5 speed, 15x10 bullet hole wheels. 1986 Chevy C30 3+3 Camper Special. 12v p pump cummins, nv4500 5 speed. http://67-72chevytrucks.com/vboard/s...d.php?t=655695 |
01-25-2015, 12:59 AM | #63 |
Good deal, figured it should
01-25-2015, 08:31 PM | #64 |
Just found your tread,looks good so far,I'm watching I want to do the same thing.
07-27-2018, 03:11 PM | #65 |
Its been a few years, but did this ever come together?
_______________________________________________________ 79 Crew Cab Chevy C20 454/TH400 Previously Owned: 77 Crew Cab Chevy C20 454/TH400 with lots of rust. Long gone. 77 1/2 ton long bed 350/TH300. Dismantled for parts. |
07-27-2018, 03:28 PM | #66 |
It's made some progress but hasn't gone together yet. Got the rockers and cab corners replaced and all the body work done on the cab, new to this truck doors, and fenders. It's all ready to final sand for paint. Next step is to get the rest of the parts I need to get the motor/trans in then paint.
07-27-2018, 03:47 PM | #67 |
Cab work
07-27-2018, 03:50 PM | #68 |
Doors
07-27-2018, 03:53 PM | #69 |
Old doors back on to push back out side. Dont have pics of fenders
07-27-2018, 07:00 PM | #70 |
Awesome thanks for the update. Glad to hear its still going. I found this when looking in to doing this swap myself. Mines 2WD so gotta decide if I'm ok with that, among many other things!
07-30-2018, 04:44 PM | #71 |
Very nice work on the rust repair and body work!
07-30-2018, 05:13 PM | #72 |
Thanks, I do paint and body for a living so I hope I'm good at it, lol
02-17-2021, 05:21 PM | #73 |
How about some updates.
Currently doing pretty much the same swap into my 88 crew cab dually. Was wondering if you had it running/driving yet. I have the Dodge/Cummins slave and master cylinder. My truck was already converted to manual with an early GM NV4500. Is the Dodge/Cummins clutch master cylinder rod at an angle compared to the clutch pedal? The stock GM master is at a near 45* angle to keep the rod parallel to the clutch pedal pivot. Thanks!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
02-17-2021, 05:37 PM | #74 |
I haven't worked on the ole girl in a few years, hopefully this year I can get back to work on it. As far as your question I cant remember and there is a foot of snow outside so I cant really go look.
02-17-2021, 05:45 PM | #75 |
No worries.
