#51 |
Junior Member
![]() Join Date: Apr 2013
Re: 70 lwb parting out this week..
Can you PM me a shipped price on the ash tray assembly (ash tray and mount) and cigarette lighter assembly (wires and all)? Thanks.
Posted via Mobile Device |
#52 |
So,, what else you got???
![]() Join Date: May 2010
Hey there. I like to keep things out in the open and respond in the thread. I will do $28.00 shipped on the ash tray assembly and cigarette lighter. Thanks, Fred.
#53 |
Junior Member
#54 |
PRICE REDUCED.... Inner door handles with escutcheons. $17.00 shipped. Thanks, Fred.
#55 |
#56 |
Junior Member
PayPal $$ sent. Thanks!
#57 |
#58 |
![]() Join Date: May 2013
Interested in throttle linkage and gas pedal
#59 |
Thanks Fred! Did you check to see if the key worked for the passenger door lock? Doesn't matter as long as I can unlock the drivers side.
Thanks again! Rich |
#60 |
#61 |
Hey Rich. Yes, the passenger side works as well. The waspers were not too pleased with me ventilating the group condo they had established, but,, oh well. Thanks, Fred.
#62 |
One of the First
![]() Join Date: Jan 2000
Looking for a TB 350 kickdown cable and the tranmission/FW cover. Needs to be OE to a 69-72. Thanks
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#63 |
#64 |
I have the throttle rod and the firewall mount assembly. The old plastic pedal will probably break when I try to remove it from the mounting studs. $25.00 shipped if you can use it. Thanks, Fred.
#65 |
Do you have any photos on the Instrument cluster and the heater controls? Price on each please w/ shipping.
Thanks, Doug |
#66 |
#67 |
Thanks Fred
Doug |
#68 |
Are you going to cut up the cab, I would be interested in the metal that goes around the lower cowl to firewall for the kick panel vents
#69 |
#70 |
PRICE REDUCED.... Hey Doug. Here is the heater control panel. Typical, two of the control levers are broken off. if you can use it, $15.00 shipped. Thanks, Fred.
#71 |
Fred, I will pass on the heater controls since two are broken off.
Thanks, Doug |
#72 |
Hey Doug. We have this instrument panel, it is not the one out of the 70 but from a 69 we parted out a while back. I would do $38.00 shipped on it. Tell you what, if you can use the heater control at all, I would sell them both to you for $46.00 shipped. Thanks, Fred.
#73 |
Thanks Fred! Great to hear, but I was sure it worked for the passenger lock as well. I found the exact bumper here locally in FL.... how's that for luck!?
Thanks, Rich |
#74 |
Looking for both trailing arm brackets that are riveted to the crossmember ?
#75 |
You are living right. I think bumpers like that come from Tractor Supply Company, stores like that. Thanks, Fred.
