Old 07-29-2013, 02:25 PM   #51
_Ogre
_Ogre's Avatar
Re: JR's 55 3200
nice fix on the oil pump mount.
stock I6, rack and pinion steering. i like how your mixing it up
shaving the dash? or installing a big radio?
a word of advise from someone who dropped his cab...
check your door and windshield fit before you proceed with any work on the cab
those curved art deco A-pillars have no strength, i believe what holds the roof up is the windshield
my firewall was pushed in a bit, A-pillar bent and roof was down. purple line shows an exaggerated deformation.
here is an old skool body guy jacking the cab back into form
shop air compressor timer
Old 07-30-2013, 01:10 AM   #52
Rods57
Rods57's Avatar
Re: JR's 55 3200
Ogre, how true that is, i had to "old school" my cap two inchs to get the door to close. JR nice shifter, that will look great in there.
Rods57 is offline   Reply With Quote
Old 08-02-2013, 01:28 PM   #53
JR25
JR25's Avatar
Re: JR's 55 3200
Thanks guys. Ogre, i had seen the pics of you having this done on one of your threads and thought...... "Ouch! I hope mine dont need this, not so sure I would know where to start!"
When i removed the doors and the windshield, everythin seemed to fit ok, just worn out hinges on the doors.
1955 Chevy 3200
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=582898
JR25 is offline   Reply With Quote
Old 08-04-2013, 11:38 PM   #54
JR25
JR25's Avatar
Re: JR's 55 3200
The engine is finished and ready to set in the frame for start up........ I think!
1955 Chevy 3200
my build thread:
Old 08-05-2013, 12:42 AM   #55
Kim57
Kim57's Avatar
Re: JR's 55 3200
That looks real sharp.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-05-2013, 09:44 AM   #56
Baldeagle SR
Re: JR's 55 3200
Those 6s sound neat with a split manifold.
cool setup.
Rich
my build http://67-72chevytrucks.com/vboard/s...d.php?t=576185
Baldeagle SR is offline   Reply With Quote
Old 08-05-2013, 12:00 PM   #57
OrrieG
OrrieG's Avatar
Re: JR's 55 3200
[/URL]
I have a bodywork book from the 40's or 50's that shows how to jack these old cars and truck around like that. Back then stuff was fixed, not totaled and tossed like today. Denee encountered the same thing, bought the truck without the windshield installed and she found out why.
OrrieG is offline   Reply With Quote
Old 08-05-2013, 03:59 PM   #58
_Ogre
_Ogre's Avatar
Re: JR's 55 3200
you dropped the cab after removing the doors and windshield.
i'd recommend installing the doors w/ new hinges and windshield with new rubber to check.
just voicing what i had to go thru, take it for what it's worth.
Old 08-05-2013, 10:36 PM   #59
JR25
JR25's Avatar
Re: JR's 55 3200
I will check it out for sure! This picture is misleading though....... I gently rolled the cab up on its firewall in order to get the boards out from under it. I had boards under it to support it while moving it with the loader. Rolling it wouldn't warp anything would it? I have had it on its firewall a couple of times when getting to the underside of the cab, is this bad??
1955 Chevy 3200
my build thread:
Old 08-06-2013, 02:16 PM   #60
_Ogre
_Ogre's Avatar
Re: JR's 55 3200
miss understanding. i thought your son dropped the cab.
i rolled my cab forward and on it's back many a time with no damage
Old 08-06-2013, 10:58 PM   #61
JR25
JR25's Avatar
Re: JR's 55 3200
That's a relief! With all the other challenges I've had with this truck, I didn't want to face something like that!
Turns out, the flywheel that came on my engine is not original, and I can't seem to find a clutch kit for it, so I'm having to reuse the pressure plate and run a slightly smaller diameter clutch disk until I can find a period correct flywheel, that is not oversized, that parts can still be found for!
1955 Chevy 3200
my build thread:
Old 08-15-2013, 10:39 PM   #62
JR25
JR25's Avatar
Re: JR's 55 3200
Quick update......
I got the engine and tranny installed in the frame, and got the ole girl fired up! I did have one BIG hiccup, i bought an aluminum shroud and electric fan, made an aluminum frame to mount it to the original radiator, BUT....... Not enough room with the loooooong old time 6 banger! I went to 10 and 12 inch fans staggered, but still running a little hot. I might have to ditch the original radiator, and get a high efficiency one and then figure out what kind/type of fan to use.
Anyone out there out there putting a V8 in a Chevy and using the original radiator? Or would like an original radiator with a fan and shroud? The radiator was vatted and tested to 25 psi (it calls for a 7 psi cap). The set up would fit on a V8 because they are shorter! (Length)
1955 Chevy 3200
my build thread:
Old 08-16-2013, 12:44 AM   #63
arturo7
arturo7's Avatar
Re: JR's 55 3200
PM sent
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 08-30-2013, 01:11 AM   #64
JR25
JR25's Avatar
Re: JR's 55 3200
OK!!!! Here she is!!!!
1955 Chevy 3200
my build thread:
Old 08-30-2013, 08:53 AM   #65
JML55
JML55's Avatar
Re: JR's 55 3200
thats cool
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 08-30-2013, 09:25 AM   #66
Baldeagle SR
Re: JR's 55 3200
sounds pretty healthy .
Rich
Old 08-30-2013, 11:21 AM   #67
Kim57
Kim57's Avatar
Re: JR's 55 3200
Sounds great.
Kim
My build thread
Old 08-30-2013, 01:47 PM   #68
av8tr33337
av8tr33337's Avatar
Re: JR's 55 3200
Sounds nice and oh so purdy!
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 08-31-2013, 08:35 AM   #69
JR25
JR25's Avatar
Re: JR's 55 3200
Originally Posted by JML55 View Post
thats cool
Rich
Originally Posted by Kim57 View Post
Sounds great.
Kim
Thanks guys! This was definitely a milestone for me! Think I will take a little break, before getting to the sheet metal!
1955 Chevy 3200
my build thread:
Old 01-17-2014, 10:43 AM   #70
jcramsey
jcramsey's Avatar
Re: JR's 55 3200
How's it comin along JR?
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 04-04-2014, 03:03 PM   #71
JR25
JR25's Avatar
Re: JR's 55 3200
Been "busy" with the ARMY. I took a break after getting the engine running, then I found myself in another country! I have started looking things over again though, and hope to get back at it before too long. I have another "trip" that I have to be gone for about a month, but then......
1955 Chevy 3200
my build thread:
Old 04-04-2014, 07:04 PM   #72
_Ogre
_Ogre's Avatar
Re: JR's 55 3200
safe ''trip'' and thank you
Old 05-15-2014, 10:15 AM   #73
Jbm1956
Re: JR's 55 3200
What all did you have to do to use the no limit power rack? How does it work? Thank you nice build.
Jbm1956 is offline   Reply With Quote
