10-08-2014, 07:21 PM | #51 | ||
Re: Just finished cutting my TREX bed wood!
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
10-11-2016, 08:46 PM | #52 |
Moderator
Two year update...
Bed still looks the exact same. TREX is holding up fine. No expansion, no cracking, no shrinking, no warping. I drilled a couple holes in the front corners for drainage. |
10-11-2016, 11:12 PM | #53 |
60-66 Nut
Thanks for keeping us informed of the long term durability
10-12-2016, 10:17 AM | #54 |
I do a lot of decking and TREX as well as other engineered wood products are quite heavy. Did the weight of this effect your ride/suspension?
10-12-2016, 11:54 AM | #55 |
ON a fleet side TREX ONLY adds about 63 pounds to the bed weight (assuming you you 3/4 TREX).... I dont think you would notice the difference.... yellow pine at #39 per cubic foot and Tex at #60 per cubic foot
10-13-2016, 09:47 AM | #56 |
I just took my old wood bed out last night, that was fun, and so I have to ask how you were able to get your new flooring under the lip of each box side? And how did you get your cross members stable before you laid down the Trex? As from what I found the cross members are only held up by the floor. To me it looks like the entire floor and cross members must be assembled then brought up from below the bed to meet those box side lips and the rear box support.
10-13-2016, 01:27 PM | #57 |
Moderator
I assembled the complete box off the truck. If you're doing it on the truck, raise the bed up on some stands at each corner. Crossmembers in place on the frame. Wood on top of crossmembers, then drop bed on the wood. Drill holes in wood around the perimeter of the bed and wheel tubs, and the holes that go through wood/crossmembers and frame.
09-25-2022, 11:03 PM | #58 |
In your Finished photo the wood looks black, is it just the angle/lighting or did you change it from the gray weathered look? It looks great
-Pickman (Mike) 1964 C10 Fleetside LWB “George” 1963 C50 “Green Machine” 2019 Silverado 2500HD My story (Welcome Page) |
09-27-2022, 06:16 PM | #59 |
Moderator
Just the light. Bed still looks the same 8 years later. Truck gets used for truck stuff all the time, and sits outside 24/7.
07-24-2023, 08:57 PM | #60 |
Wow, an eight year review! Appreciate the updates, and that's a big endorsement for TREX, kinda wish I went that route now! A lot of prep and maintenance of normal wood probably should be weighed up in the overall decision of what material to go with. My truck sits outside 24/7 too. If the past is an indicator of the future, I probably won't have my truck in eight years' time to do a review of how my bed wood is holding up!
07-25-2023, 11:54 AM | #61 |
Moderator
Still sitting outside, still looks the same. I use it constantly. I'll take a pic later today.
As promised. I sweep it out once or twice a year. I've hosed it out a couple of times. Last edited by jayoldschool; 07-26-2023 at 06:48 PM. |
