Old 07-25-2013, 01:56 PM   #51
1963c-10
1963c-10's Avatar
Re: Vinegar for rust removal
Those headlight buckets came out great. Glad it worked out for you.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-25-2013, 06:09 PM   #52
gofastnut
gofastnut's Avatar
I just did a new, but old and rusted thermostat housing in vinegar. I kinda forgot about it and it sat for a week. Took it out and rinsed it off, then got side-tracked. Man, that thing had a surface coat of rust in 2 hours! So I dropped it back in the vinegar!
Oh, and even without salt, I got a little bit of the black scum.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 07-27-2013, 04:21 PM   #53
jcramsey
jcramsey's Avatar
Anybody try this on a cast exhaust manifold? Any reason not to?
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 07-27-2013, 07:52 PM   #54
Wolfinthesnow
Wolfinthesnow's Avatar
I see absolutely no reason that this cannot be used on an exhaust manifold. I've used this trick on my radiator channels, some pulleys for my engine, and I've got some 6" PVC pipe with my bed sills soaking right now. It works great! But I will tell you this, I had my best results when I soaked the parts in a baking soda solution after I removed the parts from the vinegar. As mentioned before, the parts will need immediate attention or else they will flash rust. After my parts came out, I wet sanded them with 200 grit paper. After the sanding, I dried them and heated them with a hand held torch to eliminate any remaining moisture. The parts turned out great! I was not disappointed with the outcome. Just remember that it's a slow process. It takes about a week or so to get any real results!
I dont care how you did it in California!!!
Wolfinthesnow is offline   Reply With Quote
Old 07-27-2013, 08:53 PM   #55
jcramsey
jcramsey's Avatar
Sweet! Thanks wolf!
The Egg Hauler
The Government Mule
Old 07-28-2013, 07:30 AM   #56
bj383ss
bj383ss's Avatar
I'm going to try this on my gas tank I just got. It has some pretty bad rust in the bottom. Was also going to try the slushing around with chains and what not inside to help remove also.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 08-01-2013, 11:33 AM   #57
1963c-10
1963c-10's Avatar
Think I found a good candidate for whole body submersion....haha. Im actually shocked that the bumper still has chrome
Old 08-06-2013, 01:47 PM   #58
lasher78
lasher78's Avatar
i just did my tank with the whole chain thing worked pretty good but the sending unit looks like crap cant even see a hole in pick up tube(see blow). think the vinegar thing will work on it?
live like you are dying
lasher78 is offline   Reply With Quote
Old 08-06-2013, 01:49 PM   #59
1963c-10
1963c-10's Avatar
Worth a shot. There is an acid that can be had pretty easy that works good on gas tanks too....muriatic acid. It can be found at most home depots by the outdoor pool section. You can also use sodium bisulfate which is dry (can be made to liquid) and each pound of it is equal to 10oz of muriatic acid. I would try the vinegar 1st for cost effectiveness, but it would take probably 1-2weeks with the results Ive seen. The acid would probably be faster but cost more.
Old 08-06-2013, 01:55 PM   #60
1963c-10
1963c-10's Avatar
Quick search on home depot using "muriatic acid" shows quite a few results and starting at $13/gallon. I would probably go this route since it seems affordable and would give you faster results. It also etches the tank, which is a plus.
Old 08-06-2013, 02:14 PM   #61
lasher78
lasher78's Avatar
thanks for info. my tank came out pretty shiny after 5hrs of vigourous shaking (and cussing of coarse) and flushing out. just didnt know what to do with sending unit, wanted to try it bfore i commit to biy new one since they cost about $100 around here.
Old 08-06-2013, 02:50 PM   #62
1963c-10
1963c-10's Avatar
Id replace the sending unit...they can be found for around $30-40. The tank can probably be salvaged. Id dump the tank once the big stuff is broke free...replace w/fresh vinegar and let it soak for a few days at least. Might not be bad to do a final rinse w/the acid before reinstalling.
Old 08-06-2013, 03:01 PM   #63
lasher78
lasher78's Avatar
i already got the tank lookin like a new one on inside. i was talking about the sending unit costing $100 around here. i havent found any for 30-40. wish i could. so the soakin in vineager going to have to try.
Old 08-06-2013, 03:11 PM   #64
1963c-10
1963c-10's Avatar
Hmmm...let me look back through my receipts. I will let you know who I ordered it from.
Ok, back...got it from Brothers truck parts.. 60-66 trucks #GTS6066 $29.99 and burbs/panels GTS66PN $29.99
Check out this link:
http://www.brotherstrucks.com/prodin...number=GTS6066
Old 08-06-2013, 03:33 PM   #65
lasher78
lasher78's Avatar
thanks i looked at that link but that doesnt look like mine. up where you bolt it to tank mine is not flat like one shown it is on more of a angle like 45 degrees or more.
Old 08-06-2013, 04:07 PM   #66
1963c-10
1963c-10's Avatar
Mine is the same as yours. Its the correct part. I would call and talk with them 1st, but I ordered this part for my 63 in cab tank and had no issues.
Old 08-06-2013, 04:15 PM   #67
1963c-10
1963c-10's Avatar
Classic parts has them also for about the same price & their picture shows the slanted head. Im positive the Brothers part is correct also. Whichever dealer you go through, just make sure its for a 0-30 ohms system.
http://www.classicparts.com/1960-66-.../#.UgFZI7XD8dU
Old 08-06-2013, 05:58 PM   #68
lasher78
lasher78's Avatar
ok thanks. do u know how much shipping was from brothers? if i went thru classic i have to pay sales tax plus shipping hoping to avoid the extra cost
Old 08-06-2013, 08:03 PM   #69
1963c-10
1963c-10's Avatar
it was around $9 two years ago
Old 08-06-2013, 08:18 PM   #70
lasher78
lasher78's Avatar
i emailed them and they assured me that it was correct sending unit the photo was a generic photo. and shipping would be $15. so thanks if vineager doesnt work i will go wirh rhem.
Old 08-06-2013, 08:26 PM   #71
1963c-10
1963c-10's Avatar
sounds good.
Old 09-08-2013, 10:08 PM   #72
gofastnut
gofastnut's Avatar
Soooooo, if you forget you put a water outlet in vinegar for 2 weeks, then take it out, clean it off and wire wheel it for powdercoat prep, you might find, like I did, that underneath about .006 to .010 the vinegar had worked it's way in and I started wire brushing off THE SHELL!
So now, I'm debating whether or not to sand blast it to take the shell off, then clean it and coat it, or just chuck it.
I don't need the piece, I was just going to do it as a display.
Pics to follow after I find my phone.
Jeff
C-10 Club
Old 09-09-2013, 11:07 AM   #73
Rich 5150 69
Rich 5150 69's Avatar
Thermostat housings are pot metal, just about everything will just eat them up, its better to just buy new once the corrosion starts.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 09-09-2013, 07:16 PM   #74
gofastnut
gofastnut's Avatar
Sorry Rich, this is a Jen-u-wine cast iron thermostat housing. It's the fact that I left it in for 2 weeks that did it.
Still can't find my phone!!
Jeff
C-10 Club
Old 01-28-2014, 02:37 AM   #75
Captainfab
60-66 Nut
'scribin for future reference......
