Old 07-19-2013, 03:41 PM   #51
88Jimmy4x4
88Jimmy4x4's Avatar
Re: Major leak issue with new engine install, need any and all help guys
Originally Posted by UATahoe View Post
Got a big update. Finally got the oil pan dropped and replaced the oil pan gasket. Put 30 miles on the truck this afternoon. Hasn't leaked a drop!!!!!!! Man did it run great! And the gas/tach combo is working perfectly! I am so stoked! Dropped it off at the tranny shop to get the tv cable adjusted properly. After that, just gotta figure out why the thermostatic switch isn't kicking the fans on. Just upping them now to make sure it doesn't overheat.
But it definitely feels good to have a running truck again!
congrats....what gasket did you use and was it hard doing it under the truck with engine installed?
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 07-19-2013, 03:49 PM   #52
UATahoe
I used a GM performance parts one piece gasket. It wasn't horrible but it definitely tested my patience. A lot of the bolts are extremely hard to get to and keeping everything lined up was a pain. Took a good half day to get done. That was of course taking it slow with a lot of heat breaks. LOL
UATahoe is offline   Reply With Quote
Old 07-19-2013, 09:58 PM   #53
88Jimmy4x4
88Jimmy4x4's Avatar
I used a GM performance parts one piece gasket. It was horrible but it definitely tested my patience. A lot of the bolts are extremely hard to get to and keeping everything lined up was a pain. Took a good half day to get done. That was of course taking it slow with a lot of heat breaks. LOL
got a part number?
I hear you on the heat, Im in Houston and its dang near 100deg every day
1991 GMC Jimmy 4x4
Old 07-19-2013, 10:02 PM   #54
UATahoe
The part number is 10108676. Very good quality. Got up around 94 but the humidity was awful. Lol.
And should have read that it wasn't horrible. Just tedious.
Old 07-19-2013, 11:06 PM   #55
Sodell
Sodell's Avatar
I am glad to hear it is running great. Can you possibly explain in detail the TBI set up you used, I am very interested in going this route with my 87. Are you running 91 octane? I am pretty good with the stock TBI, but would live to be able to put a bit more power to the tires...
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 07-20-2013, 12:51 AM   #56
mud.man.rj
mud.man.rj's Avatar
Great news, good you got the leak figured out.
mud.man.rj is offline   Reply With Quote
Old 07-20-2013, 08:27 PM   #57
UATahoe
Gave the wrong part number earlier. I edited the post but wanted to post it here too. 10108676
Old 07-20-2013, 08:29 PM   #58
UATahoe
Sodell, give me some time and I will get the details together and post them up. As well as some lessons learned. There were a lot of those. Lol.
Old 07-21-2013, 08:45 AM   #59
88Jimmy4x4
88Jimmy4x4's Avatar
Thanks, does your engine have those separate support plates on each side of pan?
1991 GMC Jimmy 4x4
Old 07-21-2013, 03:49 PM   #60
UATahoe
They did not.
