Old 01-30-2016, 11:13 AM   #51
Kim57
Kim57's Avatar
Re: SA 56 build
Glad you're back at it.
Looks good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-08-2016, 02:28 PM   #52
BlairmNZ
Re: SA 56 build
Fantastic Build. I have a 55 Task Force and a Series 3 Jag front lying on the floor (arrived last night). I notice you don't seem to have had to notch the top of the frame rail to clear the top A arm mount. Did you move the rails in? I am trying to decide if it I should soft mount or hard mount. As the rails are so wide it does not look like I raise it much more using soft mounts. Have you any profile photos showing how your stance looks?
Sorry for so many questions, but your dash conversion. I assume the main dash shape is fairly symmetrical and once you diced it it all went back together fairly well?
Appreciate any comments.
Thanks Blair
BlairmNZ is offline   Reply With Quote
Old 02-08-2016, 10:27 PM   #53
Nev68
Nev68's Avatar
Re: SA 56 build
Thanks Blair
We didn't move the rails but it did take a while to get it the position right to avoid any clash.
I'll put a profile shot up later this evening. It look low at the moment as I don't have any shocked in. I have it supported with square tube bolted where the shocks mount.
A friend helped with the dash. It took a few more cuts than I expected as the dash isn't as symmetrical as it looks at first glance.
Nev
Need a bigger garage so I can keep more cool cars alive
My build, a long way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=595909
Nev68 is offline   Reply With Quote
Old 02-09-2016, 04:43 AM   #54
Nev68
Nev68's Avatar
Re: SA 56 build
Here you go Blair, I am not sure what the final ride height will be.
As mentioned it doesn't have shocks fitted.
Nev
Old 02-09-2016, 04:51 PM   #55
BlairmNZ
Re: SA 56 build
Thanks Nev,
Do you know what height the centre of the cross member is off the floor as it currently sits? Looks good if you can get it to sit as it is when finished.
I need to strip the top A arm off and sit under the chassis to see if I can get it to clear. If you did not move your rails then it must work :-)
Blair
Old 02-09-2016, 06:37 PM   #56
RockinKees
RockinKees's Avatar
Re: SA 56 build
Nev, good to see some updates again!
Nice work on the inner fenders!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 02-09-2016, 10:34 PM   #57
Nev68
Nev68's Avatar
Re: SA 56 build
Thanks, just gotta keep chipping away to keep progressing.
Nev
Old 02-09-2016, 10:37 PM   #58
Nev68
Nev68's Avatar
Re: SA 56 build
Thanks Nev,
Blair
I am sure I have some close up photos of the ifs and chassis. I'll look for them and send to you if I find them.
Nev
Old 02-10-2016, 05:01 AM   #59
Nev68
Nev68's Avatar
Re: SA 56 build
Thanks Nev,
Blair
Height at the centre & lowest point of the Jag cross member is 100 mm (4") with 225/60 R15 tyres (but I suppose it would be exactly the same as a Jag )
Nev
Old 02-10-2016, 05:05 AM   #60
Nev68
Nev68's Avatar
Re: SA 56 build
Blair, I am not sure if this photo will help but have a look anyway.
If you need any further information just ask and I will assist where I can.
You can see there is not much clearance, but there is clearance
Nev
Old 02-10-2016, 04:14 PM   #61
BlairmNZ
Re: SA 56 build
Excellent. Travelling this week, but looking forward to having a measure up when I get home. Thanks for your help. Blair
Old 02-18-2016, 03:45 AM   #62
Nut Case
Nut Case's Avatar
Re: SA 56 build
Nev, just read your thread, I had started an online computer support company, going great. Then the Google B!+(h banned my business. Long story short lost boo koo bucks. So I'm starting over again. Thought I would share this "Life Sucks and then You Live!" Didn't mean to Hi-jack this thread, I was just getting started on a 57 GMC C-4 496 BBC. No I'm on perma hold. Maybe be able to get rolling by the end of the year, great to see the LH drive to RH drive. I Spent about a month in Manchester several years back driving on the wrong side of the road cause me a lot of fear and discord. Keep on keepin on. Nut Case
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 02-18-2016, 07:05 AM   #63
Nev68
Nev68's Avatar
Re: SA 56 build
Hi Nutcase,
Good luck with the 57. I look forward to seeing some updates when you get back into it.
You know even though my 56 had to stop for a while due to my job situation (i.e. lack of a job ) I ended up getting a couple of great opportunities I never would have been exposed to.
Now I think I am in a better position from a life perspective and as a result I can get back into my build (even though I am very busy now).
I know what you mean about driving on the other side of the road.
My wife and I spent 3 months in the US (best vacation ever) and it was a little daunting driving on the other side of the road for the first few days.
Nev
Old 03-12-2016, 03:24 PM   #64
BlairmNZ
Re: SA 56 build
Hi Nev
Getting closer to grabbing the cutting wheel and getting stuck in on mine. The photo was great thanks. Did you notch the cross member of the frame? I meet a guy in Hamilton last week who had his very low and had cut the frame away.
Looking at the wheel in the arch it looks like you have used the original centre line? Or did you sneak it forward a little.
Regards Blair
Old 03-15-2016, 05:48 AM   #65
Nev68
Nev68's Avatar
Re: SA 56 build
Sorry I took so long to get back to you Blair.
Now I have a job it is taking up lots more time (probably a good thing as those bills don't stop)
Here are some more photos of the front end.
To be honest I don't remember if we notched the frame, it was so long ago.
I do remember we kept the wheel base as per standard.
Looking toward front on drivers side
Looking from above (driver side) i.e. Right hand side
Driver side looking toward the rear
Driver side
Just ask if you need any more photos.
Nev
Old 03-15-2016, 06:10 PM   #66
RockinKees
RockinKees's Avatar
Re: SA 56 build
Sorry to break in Nev68!
@ BlairNZ:
There are a few who uses Jaguar IFS and IRS.
I have it done too, from page 7 on my build.
About the same as Nev68 has done this.
My IFS is 3/4" more to the front, to get the wheel better alined, but I have a '59, don't know if that makes a different.
The more you know, the better you get
Cheers!! Kees.
Kool Guyz CC
Old 04-04-2016, 10:53 PM   #67
steampunk c1
Re: SA 56 build
Great info guys I to are working on xj front and rear ifs into 55 long bed. I plan on doing a bolt in so will post pics when I have the body off the frame in a few weeks.
steampunk c1 is offline   Reply With Quote
Old 04-26-2016, 04:11 PM   #68
BC Toy chest
BC Toy chest's Avatar
Re: SA 56 build
Nice work please keep the photos coming truck looks GR8.
Nev believe it or not there are a few here in the USA that convert their rydes to right hand drive too. Here's one example I took pics of recently here in my city Los Angeles.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 04-26-2016, 11:28 PM   #69
Nev68
Nev68's Avatar
Re: SA 56 build
What do they use to convert to Rh drive? Jag or something else?
I have a Lh drive 68 Camaro that I don't mind driving on the Lh side of the road, not sure I would be a good passenger though.
Nev
