Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 10-19-2013, 08:37 AM   #51
Green Hornet
Re: 71 4X4 Frame off Restoration
Very interesting build. Subscribed
69 Chevy C10 Fleetside Long box
Green Hornet is offline   Reply With Quote
Old 10-19-2013, 08:53 AM   #52
JayB331
JayB331's Avatar
Really nice work on the A pillar. Looks like the pizza and beer helped!
'67 K10 SWB
350, SM465, NP205, 12 Bolt & Dana 44 w/ 3.08's
My Project
http://67-72chevytrucks.com/vboard/s...d.php?t=602684
JayB331 is offline   Reply With Quote
Old 10-19-2013, 04:35 PM   #53
DWilbur
I used 4.5" grinder to cut the outside of the cab and plasma cutter to do the cutting on the inside. I over cut the inside so I can trim what I need to fit the floor and roof area. It took about 3 hours to cut it off.
DWilbur is offline   Reply With Quote
Old 10-19-2013, 04:44 PM   #54
Vova
Let me know if you need any parts.
http://67-72chevytrucks.com/vboard/s...d.php?t=599412
I'm local.
Vova is offline   Reply With Quote
Old 10-19-2013, 05:15 PM   #55
DWilbur
I have most of the parts I need for now. I have been selling the extra parts I don't need on Craigs List. I will need to replace the right front door and I'm looking for a fleet side short bed. most of the beds I have found they want $1,500 or more. I can get a long bed for $500 and it is in good shape very clean. I could cut it down.
Old 10-19-2013, 05:17 PM   #56
Vova
I have a door but its got rust on the bottom part.
Old 10-19-2013, 10:07 PM   #57
DWilbur
Rust I can deal with. Rot I would like to avoid. Could you send me a picture of the bottom.
Old 10-19-2013, 10:10 PM   #58
DWilbur
I finished out the day welding and grinding the fire wall, floor pan and cowl. I stil have about 4 hours of welding and grinding inside the cab.
Old 10-19-2013, 10:53 PM   #59
Vova
I'll take some tomorrow.
Old 10-20-2013, 12:21 AM   #60
swamp rat
swamp rat's Avatar
Great looking work!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-20-2013, 08:01 AM   #61
sboris
sboris's Avatar
Man that's good work for sure! That would scare the hell outa me!
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 10-20-2013, 12:13 PM   #62
chev3600
chev3600's Avatar
This is going to be a great truck! I can't wait to see it rolling.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 10-20-2013, 08:42 PM   #63
DWilbur
Hello sboris/ chev3600
It was a scary 3 or 4 weeks cutting out the A pillar and replacing it. I'm glad it turned out so well. Did some more work today? My nephew and his friend Brian stopped by today and helped my test fit the engine and it did not go so good. The LS 5.3 oil pan bolts are hitting the cross member motor mount. I have read that it works maybe it works on 2 wheel drive frame and the cross member is different. The engine need to drop about 2.5" and slide back about 2.5" from were it is in the picture. I'm not sure if the big blocks cross member is wider or not I will call Vintage Chevy Truck Monday and see what I can find out. We test fit the back of the cab and I have some sheet metal to cut but it look like it will fit with some massaging.
Old 10-20-2013, 11:39 PM   #64
swamp rat
swamp rat's Avatar
It will be interesting to hear what they have to say.
On my truck the engine mounts are bolted to the rear holes in the frame but never really understood why GM uses both forward or rear frame holes in the first place. so wondering if that could play into your situation?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-21-2013, 01:23 PM   #65
DWilbur
My cross member was bolted in the rear holes with the 305 small block. I removed the cross member last night and its soaking in my cold tank to clean off the grease.
Old 10-21-2013, 02:39 PM   #66
DWilbur
I searched the site and by chance I found a link to Dirty Dingo wed site. http://dirtydingo.com/store/product_...oducts_id=1408
They make a cross member to install LSX motor into 67 to 72 4X4. So I ordered the set up. The good thing is they are in Arizona and should take about 3 day to ship.
Old 10-21-2013, 09:59 PM   #67
swamp rat
swamp rat's Avatar
Awesome!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-22-2013, 07:33 AM   #68
sboris
sboris's Avatar
That's awesome for sure. That thing looks knarly as hell. Never fails though, always end up spending another 300 ya hadn't planned on!
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 10-22-2013, 02:31 PM   #69
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Very nice work, I will very much enjoy watching this build. And glad you found a solution too your oil pan problem. You know thats got to make you feel better when you run into problems and theres a fix. Nice job so far.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 10-22-2013, 02:59 PM   #70
DWilbur
Hello Mr Chevorlet
I was lucky I found the part I need thanks to this forum and web site. I did a internet search several time and never so any thing like what Dirty Dingo is building for this engine swap. Now if I can find an 6L80E transmission for a cheep price to replace my SM465 I would be a happy camper.
Old 10-26-2013, 02:37 PM   #71
DWilbur
I received my cross member from Dirty Dingo Motorsports Thursday. everything was well packed in 2 boxes. only thing no instructions but they have pictures on there web site that explains alot. If my nephuew stops by this week end we will install the mount and engine check the fit of the engine to fire wall, headders and power stearing pump. I'm going to work on fitting the floor patch panel today.
Old 10-26-2013, 02:38 PM   #72
DWilbur
Hi VOVA any chance I could see picture of the door bottom.
Old 10-26-2013, 05:10 PM   #73
Daddy'O
Daddy'O's Avatar
Suscribed........Very nice work DWilbur.
Cheers - Wayne
Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966
'55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157
1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy"
1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55
Nothing sucks more than that moment during an argument when you realize you're wrong.
Daddy'O is offline   Reply With Quote
Old 10-26-2013, 06:46 PM   #74
swamp rat
swamp rat's Avatar
Cant wait to see it installed and the engine in as well.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-27-2013, 12:15 AM   #75
rusty knuckles 5
very nice i am wishing you all the best and thanks for all your picture support
rusty knuckles 5 is offline   Reply With Quote
