10-27-2013, 08:58 PM | #51 |
Re: Trouble codes
I'm thinking about purchasing the Greg Banish EFI Tuning videos. Is it worth the money? Does anyone have any experience with them?
http://www.summitracing.com/parts/sme-dvd-1/overview/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-27-2013, 10:18 PM | #52 |
Truck and auto performance nut
Re: Trouble codes
I haven't...just pick up what I can here and there but it certainly couldn't hurt. I know enough that I know NOT to try and tune my own yet.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
10-28-2013, 09:57 AM | #53 |
Re: Trouble codes
I do have the disks, they are pricey but you will pickup some good information from them. Is it worth it? that is hard to say but I did learn and feel more confident in what I am doing. I decided I better learn to tune mine was getting harder to get it right with mail order tunes. I was able to take my time and make adjustments in smaller steps till I got it right.
There is tons of info out there and you will pickup most of what you need on the internet www.hptuners.com has a good site and good forum. Plus tons of examples of tunes to sort thru. Good luck Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
10-28-2013, 10:01 AM | #54 |
Re: Trouble codes
I also just helped a buddy get his DBW 6.0 running. He didnt get a pedal assembly when he got the motor, he found one at a yard that was a year or 2 off and it is working. His is still a gen 3 so once you jump to these newer ones it get more complicated.
10-28-2013, 02:20 PM | #55 | |
meowMEOWmeowMEOW
Re: Trouble codes
Torrents are a wonderful thing.
10-28-2013, 04:10 PM | #56 |
Re: Trouble codes
let me do some digging...
10-28-2013, 04:22 PM | #57 |
meowMEOWmeowMEOW
Re: Trouble codes
IF you need a place to go with them, or you don't want to upload them yourself, I can seed them without an issue.
Anything further move to PM with me until we can get it up....I"m not sure how close this comes to a site TOS violation.
10-29-2013, 08:17 AM | #58 |
Re: Trouble codes
I got my HPTuners last night and started playing with it ....man I have lots to learn... I may need another E38 computer. Where is the cheapest place to get one and what is required to make sure I get the correct year and operating system on it?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-29-2013 at 09:50 AM. |
10-29-2013, 09:23 PM | #59 |
Re: Trouble codes
I thought you'd have something newer....I think mines (for '07-'09) a E38? And I run a TCM 40 I think.
10-29-2013, 11:23 PM | #60 | |
Re: Trouble codes
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
10-30-2013, 08:11 AM | #61 | |
Re: Trouble codes
10-30-2013, 08:20 AM | #62 |
Re: Trouble codes
Did a lot of reading/researching last night. Here's what my plan is on the "tune". Basics first:
Delete: VATS rear O2 sensors and DTC's VVT and associated DTC's DOD and associated DTC's Emmission stuff Next: Make changes for the 80lb injectors Try and start and see what codes pop..... I've ordered a couple of books on tuning basics that should be here soon. Until then, I'm just going to play with stuff that won't get me in trouble, . I'm thinking about starting another thread that document my process on tuning. Thoughts?
10-30-2013, 08:56 AM | #63 |
Re: Trouble codes
Rob, I think you better get the data for the injectors in on your first tune. That will make a HUGE difference.
Oh never mind you were going to do that before you started it I didn't catch that the first time. Good luck Dave
10-30-2013, 09:11 AM | #64 | |
Re: Trouble codes
Here's the data on the injectors or at least what I found online: http://fuelinjectorconnection.com/sh...?productid=285 "Siemens 80lb High Impedence Injectors, Full Length with USCAR (ev6) plug Introducing the new 80 lb/hr high impedance fuel injector from Siemen Deka! The 80lbs/hr @39.15.psi or 84lbs/hr @ 43.5 EFI fuel injectors function at 11-12 Ohms, These new injectors offer users the increased benefit of an optimal fuel spray pattern once placed following installation inside the vehicle engine. These injectors work exceptionally well with any of the new Ford Mustang engine types, along with many other engine types capable of utilizing MORE POWER! -No jumper harness performance when operating your EFI vehicle. -Optimal fuel spray pattern allows engines to utilize MORE POWER!!! -Allows for naturally aspirated engines to operate at power increases up to 1200 hp! NA (8) -SIEMENS new injectors offer a high impedance rate of 11-12 Ohms. -These new Siemens EV6 fuel injectors are compatible with any Ev6 wire harness Product Specs Injector Advertised Flow Rate (lbs/hr) 80lb/hr @ 39.15psi - 84lbs./hr. @ 43.5 Injector Advertised Flow Rate (cc/min) 646 cc/min Injector Impedance 11-18 ohms - High Impedence Seat to Seat Height 60mm Manifold O-Ring Outside Diameter 14 Fuel Rail O-Ring Outside Diameter 14 Injector Plug Style uscar (ev6) "
10-30-2013, 12:16 PM | #65 |
Re: Trouble codes
Just make sure to "save" your changes each time. You'll wind up with a bunch of files you may never use....but at least you can back track.
10-30-2013, 02:40 PM | #66 |
meowMEOWmeowMEOW
Re: Trouble codes
Damn, I never noticed those nozzles were 84@43psi.....that means at our 58psi operating pressure you probably squeak out 90lbs... I can say that you won't be running out of fuel anytime soon lol.
10-30-2013, 04:06 PM | #67 | ||
Re: Trouble codes
10-31-2013, 01:53 AM | #68 |
Re: Trouble codes
I second the save thing. My understanding also is that when you make changes you should rewrite all to the ECM, or there is a high possibility that it won't save correctly to the ECM. That is how the VATS didn't get saved the first time by the first tuner. Somehow he didn't rewrite all after he changed the VATS and saved it.
11-18-2013, 07:10 AM | #69 |
Re: Trouble codes
Ok, I've been chasing what I thought was an injector setup/tune problem for a couple of weeks now. I can get the truck to start and idle, but will die when you put it in gear. From the first time I got then engine to start and run, I was getting some misfires on the right side (Bank 2) that were causing the short term and long term bank2 fuel trims to go extremely high. I thought it was just a problem with the injector data I had in the tune for the SD80 injectors I have. From everything I've read online, they are a hard injector to get dialed in. So I just assumed that was what my problem was. After much research, I'm pretty confident that I have that part of the tune setup correctly, but I still have the problem on the right side.
So last night I decided to do some trouble shooting to try and eliminate as many possible causes as I could. First, I swapped the O2 sensors from side to side, but no change. Next, I swapped the fuel injectors from the passenger side to the drivers side, still, no change. Finally, I swapped the the coil packs from side to side, but still, no change. The only other thing I can think of is that the the wiring to the coil packs on that right side is messed up. The engine sounds like a couple of plug wires are crossed on that side. It's probably been doing that since the first time I fired it up, but its been hard to detect because of the open headers. I even tried unplugging the individual coil packs on that side to see if you could isolate the miss, but it almost seems random. All of the headers pipes on that side are getting hot, so I know everyone of them are firing. This is very frustrating and I've got to figure this out first before I go any further with the tune. Sorry for venting. Rob EDIT: I checked all the pins on the computer to make sure nothing was damaged and they all look fine. Here's a list of trouble codes I have been getting: [] P0174 - Fuel Trim System Lean Bank 2 (Immature) [] P0300 - Engine Misfire Detected (Old) (Immature) [] P057C - (SES) (Pending) (Old) (History) (Current) (Immature) [] P0621 - Generator L-Terminal Circuit (Pending) (History) (Immature) [] P219A - Fuel Trim Cylinder Balance Bank 1 (Old) (Current) (Immature) [] P219B - Fuel Trim Cylinder Balance Bank 2 (Old) (Current) (Immature) [] P2537 - Ignition Switch Accessory Position Circuit Low (Pending) (Old) (History) (Current) (Immature) [] P057C - Continuous Tests Misfire: Complete Fuel System: Incomplete Comprehensive Component: Complete
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 11-18-2013 at 07:44 AM. |
11-18-2013, 10:29 AM | #70 |
Re: Trouble codes
Rob, I didn't get your package in the mail but will today.
Things got pretty busy for me anyway I dont know how different things will be since you are the newer stuff. If you have not logged anything yet that would be what I would do first. You can check to see if your O2 sensors are cycling correctly. I had a blown fuse and didn't know it for a long time I kept chasing O2 sensors and even my MAF I ended up shutting all that off not knowing what was going on. At some point a month or 2 later I found the fuse and was able to turn the sensors back on otherwise I was running in open loop all the time, my tune was good enough that it didn't matter. I did end up switching to a 2 bar setup and went without my MAF with my turbo. Moral of the story is to make sure your fuses are all good but also log some data and look it over. You can post over on HP tuners with a log and your tune and will get some good feedback I believe. Good luck
11-18-2013, 10:41 AM | #71 | |
Re: Trouble codes
11-18-2013, 08:37 PM | #72 |
Re: Trouble codes
I did a scan of the misfires today and it misfires like crazy on 2/4/8 when I give it the gas. Some on 6, but not much. Nothing NADA on 1/3/5/7. Seems like electrical to me, not sure what else it could be. I guess I need to figure find a wiring diagram and start checking stuff...
11-18-2013, 10:12 PM | #73 |
Re: Trouble codes
'11 Camaro 6.2L Even Coil diagram....
11-18-2013, 10:37 PM | #74 |
Re: Trouble codes
Thanks CB. Any thoughts on the possible problem?
11-19-2013, 12:20 AM | #75 |
Re: Trouble codes
Look at your grounds again. I've read over and over misfires on a bank keep coming up as ground issues.
