Old 01-22-2014, 09:05 PM   #51
Bagged3100
Re: LS1 Bagged 52 Chevy 3100 Build
Its been a while since I updated my build, I finished the cab corners and also the lower cowl panels. Then I picked up my seats, the main thing i wanted was the seat belt built into the seats that way its easier and stronger then attaching to cab. I made the floor supports very strong to hold it incase of an accident. But when i got the seats the inside track was about 3.5 inches higher then the outside track. So i had to make new seat frames to level the seat out and to bolt down to the floor supports.
Bagged3100 is offline   Reply With Quote
Old 01-22-2014, 09:14 PM   #52
Bagged3100
It was simple fabrication work but took lots of time mainly from all the holes drilled and installing sleeves in every one
Old 01-23-2014, 12:46 AM   #53
oldman3
oldman3's Avatar
What year and make were the seat from???, look good and can easily remove the headrest if needed...Jim
oldman3 is offline   Reply With Quote
Old 01-28-2014, 09:17 PM   #54
Bagged3100
Look what FINALLY showed up on my porch today. Exactly 1 year and 10 days after I ordered them, my control arms from suicide doors / thorbeck bros showed up. Now its time to really get to work!!!!
Old 01-28-2014, 09:45 PM   #55
99 to Life
99 to Life's Avatar
nice stuff, but yeah as I'v always heard, long turnaround. Seriously though for any company to make you wait that long, you should have gotten them for free. they look great and I'v only heard good things but dang, talk about a project buzz kill.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-01-2014, 10:43 PM   #56
Xdk5
Nice work
Xdk5 is offline   Reply With Quote
Old 02-02-2014, 07:10 PM   #57
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
1 year and 10 days!! WOW, I would have ordered something else a long time ago. You have great patients. Look forward to more progress.
--Josh
Old 02-04-2014, 08:52 PM   #58
Bagged3100
Yeah a year and 10 days is a crazy long time to wait. It seriously did hold my project up big time. I wasnt very happy. But now that I do have them ive been going at it with all my spare time. Here is some pics with my first attempt at cutting the spring pockets
Old 02-04-2014, 09:02 PM   #59
Bagged3100
After several times of cutting pocket and installing bags and recutting.... I finally got the pocket cut big enough to clear the big 2600 bags. Also I put my 2 inch drop spindles on it just to see what it looked like and have a little fun with it. LAYIN FRAME!
Old 02-04-2014, 09:59 PM   #60
99 to Life
99 to Life's Avatar
nice, def layin low. your upper arms gonna clear your manifolds? How about your tires with the front fenders? Cutting out the pockets for 2600lb kinda suck. I'm on my second dime frame and I'm looking forward to doing an OG frame next. Was gonna drop axle my 52' but I think I'm just gonna bag it, its up after my current build. I still think thor bros shoulda gave you that order for free, thats just bad turnaround. Coming along nice man. congrats.
Old 02-04-2014, 10:03 PM   #61
Xdk5
Why 2600 bags instead of 2500
Old 02-04-2014, 10:13 PM   #62
99 to Life
99 to Life's Avatar
most s10 350 guys recommend 2600 over 2500 because of the weight and you can run lower air pressure for a smoother ride.
Old 02-05-2014, 08:17 AM   #63
Xdk5
I'm scared I have 2500 bags on a camaro clipped 58 with a big block I think I really need 2600's
Old 02-05-2014, 09:08 PM   #64
48ChevBagged
48ChevBagged's Avatar
Yes the bigger the bag the better the ride and you can run lower air pressure like 99 said for a better ride. The best thing to do is make sure the pocket is cut plenty big enough you do not want any rubs. This project should start coming together now. Looking good with the front end installed.
48ChevBagged is offline   Reply With Quote
Old 03-06-2014, 07:52 PM   #65
Bagged3100
Thanks for all the comments guys. But its been a really rough last couple of weeks. I messed up my bars for my rear 4 link so I had to order new bars and wait for them to get here. Then as soon as they got here my welder crashed. So I had to order a new liner and wait some more for it to get here. But while I was waiting I figured I mise well fabricated my own air bag top mounting brackets instead of buying them. Im very happy with how they turned out!!!
Old 03-06-2014, 08:00 PM   #66
Bagged3100
And here is my triangulated 4 link setup. It is a very tight fit but I did end up getting my top bars at the minimum of 60 degrees and also am at 75% top bar to lower bar ratio. I have my lower bars level at ride height and the top bars angled down slightly. The air bags are gonna be on the lower bars. Let me know what you think?
Old 03-07-2014, 09:33 PM   #67
53ChevyKevin
What radiator set up are you gonna use?
53ChevyKevin is offline   Reply With Quote
Old 03-10-2014, 05:52 PM   #68
HUSSEY
HUSSEY's Avatar
Those seats were a nice choice, what are they out of?
HUSSEY is offline   Reply With Quote
Old 03-17-2014, 10:59 PM   #69
Bagged3100
Hey guys 53ChevyKevin I honestly do not really know what for radiator im going to use yet. If I cant find one to fit I was thinking about maybe mounting it up more into the grill space but not sure yet. And Hussey the seats worked out really nice. I am really happy with them. They came out of a 2003? Chevy Trailblazer.
Old 03-17-2014, 11:23 PM   #70
Bagged3100
Ok so I got impatient waiting for my welding liner so I decided to load my truck up and take it to my paps place to weld my step notchs on. First time its seen sun in a long time. But I got them all done now I just have to cut the bottoms of them off flush with the frame but im just gonna wait till I tear it apart and flip the frame over cause im tired of standing on my head to do any work
Old 07-08-2014, 10:14 PM   #71
Bagged3100
WOW its been a really long time since ive posted my updates on here. Sorry its been very hectic, I started a new job and relocated away from where im keeping the truck so now im only working on it on the weekends and to top it off theyve been sending me out on buisness the past several weeks. So i havent had much time in the garage to work but im back now and things are going to start moving forward... I hope.
Old 07-08-2014, 10:23 PM   #72
Bagged3100
So since I last posted I had to cut up my bag mounts I made to make them narrower because they stuck out into my C notch area
Old 07-08-2014, 10:32 PM   #73
Bagged3100
When I ran the air ride up and down the bed sides were sitting on the rear tires so it stopped it from going all the way to the ground so to fix that problem I picked up some brand new 2 inch wheel spacers real cheap off of craigslist and also bought some 180 degree bent tubing which I shortened and welded together to make a driveshaft loop.
Old 07-08-2014, 10:36 PM   #74
99 to Life
99 to Life's Avatar
nice to see you back on the wagon. yeah the wheel spacers make life alot easier, hey you don't like 2" get 1" get 1.5" etc. We are spoiled these days with cnc's and all the info we need online!!! can't wait to see more.
Old 07-09-2014, 08:09 PM   #75
Bagged3100
hey 99 the 2 inch wheel spacers could not have worked any better. they were spot on perfect, atleast with the wheels im using for mock up purposes. The tire clears the bed side and the outer fender lip so right now I dont even have to make wheel tubs in bed. But since I last posted all my updates I also made running board mounts and cut the orginal brackets and welded them onto s-10 chassis
