Old 11-03-2013, 05:39 PM   #51
881ton
881ton's Avatar
Re: project rust bucket
This is how the truck sits today. I still have some things to do, but for the most part its done.
ROB
881ton is offline   Reply With Quote
Old 11-03-2013, 06:00 PM   #52
chevak20
It is so beautiful, makes me want to go out to my built even it is bed time...
I am speechless.. wow!
How long time did it take?
How did you mount the bucket seats? What reinforcements did you do to the floor?
chevak20 is offline   Reply With Quote
Old 11-03-2013, 07:37 PM   #53
tekin112000
Great build
I hope you are able to enjoy this classic for years
tekin112000 is offline   Reply With Quote
Old 11-03-2013, 09:04 PM   #54
Greenlee
Greenlee's Avatar
Looks great! I agree, cheaper than a new one and a lot cooler truck!
Greenlee is offline   Reply With Quote
Old 11-03-2013, 10:16 PM   #55
Flatlandsurfer
Flatlandsurfer's Avatar
Wow man! Nice build, beautiful truck!
1984 Sierra Classic SWB
1986 Sierra Classic LWB
1987 Silverado LWB
1991 Suburban 2500 454
1993 Sierra Ext. SWB 6.2
2012 Silverado Crew Dirtymax!
Flatlandsurfer is offline   Reply With Quote
Old 11-04-2013, 07:19 AM   #56
madcow75
madcow75's Avatar
Very nice... How long did it take you to build.
madcow75 is offline   Reply With Quote
Old 11-04-2013, 10:37 AM   #57
881ton
881ton's Avatar
Thanks for the feedback, I appreciate it. This project took approx. 3 1/2 yrs to complete. I was only able to work on it in the winter when I am laid off.
It was a lot of fun and a ton of work as most of you know. I would like to do another project specifically, an 86 -91 crewcab v30 pickup. This would also be a cummins swap w/ Allison 1000 trans. This would not be built to plow but a daily driver. If I had to do it again I would try to find a rust free truck to start, because it would save so much time.
ROB
Old 11-04-2013, 12:39 PM   #58
Jonboy
Slots go on anything!
The truck is stunning, Rob! Great work!
1974 Jimmy- 5.3/4L80e/NP241
Old 11-04-2013, 01:34 PM   #59
881ton
881ton's Avatar
Thanks again for all the kind words. The seat install was a project in itself. I had to remove most of the tracks on the new seat and then build a frame out of angle iron to mount the entire seat . basically a rectangle w/ bracing to mount the seat and center console. then I bolted the original tracks from the factory bench seat to the seat frame. The seat slides manually back and forth. It works ok, but it sits a little higher than it should b/c of this. I didn't want to cut the floor pans so I had to compromise a little headroom. I'm 6'2" and I have enough room.
ROB
Old 11-04-2013, 01:38 PM   #60
brimc
brimc's Avatar
I bet you wish it would snow now eh?
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 11-04-2013, 02:03 PM   #61
881ton
881ton's Avatar
Brian I'm hoping for a good winter, not quite ready yet but when I am Let it snow!!
ROB
Old 11-07-2013, 07:53 PM   #62
crashz
crashz's Avatar
Wow - I'm hoping to get my 1 ton in that kind of shape!
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 11-07-2013, 10:02 PM   #63
y5mgisi
Second Chance Program
y5mgisi's Avatar
Damn! Great work!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 11-10-2013, 09:57 AM   #64
Wrecked1982
Wrecked1982's Avatar
really nice truck you may have changed my mind about the cummins swap maybe ill ditch the 454
nice shop to work in
Wrecked1982 is offline   Reply With Quote
Old 11-10-2013, 07:52 PM   #65
881ton
881ton's Avatar
Thank you all for the compliments. the cummins swap was not too difficult. I would do it again in a heartbeat. I just need to finish up some odds & ends then I can start driving it. I've only run it around the neighborhood to shake it down, I want to check everything thoroughly before it goes down the highway.
ROB
Old 11-10-2013, 08:42 PM   #66
MTCK
MTCK's Avatar
Awesome build! I just spent 2 hours shoveling and a plow sounds like a GREAT idea at the moment. That thing looks ready to work! Love the stance with the new springs.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 11-13-2013, 11:21 AM   #67
881ton
881ton's Avatar
Need Opinions !
I have a LUND visor all painted and ready to be put on. I'm undecided if I should put it on or not. I've had them on other chevy's in the past, I just don't know if I want it on this truck.
ROB
