Old 12-10-2013, 12:12 AM   #51
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: What exhaust are you guys running with your swap?
Originally Posted by ls1nova71 View Post
I found this out myself about a month ago, TBSS manifolds won't clear a 4l80.... Looks like headers are in my future.
Corvette or Cadillac would most likely work for you
dwcsr is offline   Reply With Quote
Old 12-10-2013, 10:52 AM   #52
Wasted Income
Boosted Member
Wasted Income's Avatar
I just cut the ears off the bellhousing. I do that on EVERY 4L80 I install. Makes routing stuff so much easier, and those ears are only used to hold on the dust cover, which I also don't install.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 12-10-2013, 11:34 AM   #53
ls1nova71
ls1nova71's Avatar
Yeah, I thought about cutting them off, but the cover is cast aluminum and really finishes off the underside of the transmission, so I don't really want to do that. I have a set of F body manifolds that will fit with very minor trimming of the frame, but I guess I'm really just looking for a good excuse to buy a set of high dollar headers.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-10-2013, 11:43 AM   #54
solidaxel
solidaxel's Avatar
What are you looking at for "high dollar" exhaust, besides stock is there any other cast aftermarket ones?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-10-2013, 12:03 PM   #55
Matt Cramer
5th generation Camaro manifolds exit straight down and fit the block pretty closely. I'd expect they'd work with a 4L80E, too. That's what I'm using, although I have a TH350.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 12-10-2013, 01:15 PM   #56
Wasted Income
Boosted Member
I can appreciate that!
Turbo diesel
Old 12-10-2013, 09:34 PM   #57
stevenbear72
stevenbear72's Avatar
I want headers on my truck, but have those damn CPP tubular mounts which don't allow anything but the Doug Thorley tri y's. Would you all recommend I just swap the tubular perches for a set of their sheet metal perches or just get some ECE mounts?
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's
Project "Huckleberry"
68 GMC K1500 1/2 ton L83/6L80e
stevenbear72 is offline   Reply With Quote
Old 12-10-2013, 10:15 PM   #58
crazy longhorn
Fabricate till you "puke"
If you don't mind the short tubes...Hooker street rod short/tight tuck? IFRC, 225 on the painted headers, & 90 on the mandrel bent /stainless down tubes (cut/weld to fit)? The long tube try -y's will be the best on performance. I my build, I needed the shorties to clear the gen I clutch linkage. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-11-2013, 02:09 AM   #59
dwcsr
Hollister Road Co.
dwcsr's Avatar
Here is a picture of the Cadillac CTS manifold. For 47-53 Chevy trucks Camaro doesn't work.
