Old 02-26-2004, 03:41 PM   #51
jhow66
jhow66's Avatar
Used to drag race alot in my 56 chevy-broke a rocker arm with no spare-removed both pushrods and sparkplug on that piston and drove it home on with a " V7". Sounded like a air compressor with the line off.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-26-2004, 07:01 PM   #52
botboy
In my '70 chevelle it flooded like crazy one day for no apparent reason (stupid F%^*&#ing POS 2-bbl) so to get it to NOT FLOOD so I could get home I pulled the clip holding the squirter rod off, drove it home that way. Had to mash the throttle every few miles cause it stuck WIDE OPEN with the rod just hanging there.
Pulling a parts ford BII home the t-case moved and the auto locked up SOLID. Pulled the rear driveshaft, duct taped it in place. Continued driving home at 75.
botboy is offline   Reply With Quote
Old 02-26-2004, 11:25 PM   #53
jimfulco
jhow66, I drove an old Pontiac like that for a year or so, but it was much quieter with the spark plug in it. I had a Fiat 124 & the thermostat (external) jammed due to some kind of stop-leak. They were hard to find, & cost close to $100. I cut several sizes of strips of corrugated cardboard a little taller than the radiator, & slid 'em down between the radiator & the support & bottomed out on the pan underneath. I just used how ever many of them it took to keep the temp gauge in the normal range. With my Nova, I was racing a Buick & when I hit 2nd gear, the shifter broke off where it had an S-curve in it & almost ended up in the back window. And dangit I was just starting to catch up, too. Drove it home shifting with vise-grips.
jimfulco is offline   Reply With Quote
Old 02-26-2004, 11:39 PM   #54
SS55
About 15 years ago I had a 59 stepside and was driving it down a busy street when it started drifting to the left and I had absolutely no steering control. The oncoming traffic all managed to avoid hitting me and I came to a stop in a wide driveway. I crawled underneath and found that the left tie rod had come apart. I put it back in place and used almost a complete roll of 3M electrical tape to hold it in place. Got it home safely, about 20 miles.
Be wary of the light at the end of the tunnel....It might be a gorilla holding a flashlight!
71 Blazer, ex-4WD...Bought it that way
55 GMC
55 Belair 2dr HT
67 El Camino
SS55 is offline   Reply With Quote
