Re: New old guy.
Sounds like you have a plan coming together! I have good luck with photobucket for this sight....
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
Re: New old guy.
Hmm, photobucket? If you dont mind elaborating a little, i'll try it. Computor wise (im not) relative might be here for Christmas, maybe she can help me.
OLD SCHOOL LOW: 78 Short Wide Heavy Half-Ratty Rod at moment. Old 4blt stroked to 383 Vortecs, Weiand, Scat, Hedman 1 5/8, Howards Roller, .495/500, Scorpion. Leaf flip, cut coils. Make do tires and wheels for now. Slip ahead a year? Sold GMC, bought Harley, got all obsessed doing the biker thing, now starting again w 65 SWB, 283,2bbl, 3 on tree. |
Re: New old guy.
Sorry it didn't help, fixed me right up. Usually there's a block to frame ground, then the block to battery. You pulled and cleaned all connections, incl. grounds and the mounting area for the starter and the bolts? Maybe just a weak starter. Sorry it didn't help. If it was out, did you get it load tested? Excited for your new engine.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
Re: New old guy.
I always like replies, thanks. Its 50% better, lol. Sounds EXACTLY like timing off, that hesitation, then it turns over good and starts. But ONLY when its warm, 2deg morn and it cranks over fast??? So screw that for now, i can live w it for another month when new engine goes in. Ill check or replace the little wires and everything. New problem yesterday. 2 tank gas valve switch. Messed up when I bought it, so IVe been pulling directly out of drivers side tank but pass side is 3/4 full so I want to use it up. Plumbed directly to it, ran for 10 min then no gas. That gs could be a year? old. No part store yesterday so just got Quad Jet filter, hope didnt plug fuel pump, does that ever happen? So in a minute I;; plumb back to drivers tank, change filter and I think Ill pull pass tank, drain it and maybe not even hook it up, Im scared now its all contaminted, 16gal is enough for me anyway, I like hot blonde at gas station too. Its 20deg and foggy, damp, (no garage) but Ill get out there in a little bit. Yeah, Im excited about new engine too. Guy building it off till Monday. I'll be posting. Dam! Just trtied to post u pic but it hasnt let me for past week? It says 'Request Time Out" whats that about? Edit----New starter did same thing so I put old one back in and save new one for 383
OLD SCHOOL LOW: 78 Short Wide Heavy Half-Ratty Rod at moment. Old 4blt stroked to 383 Vortecs, Weiand, Scat, Hedman 1 5/8, Howards Roller, .495/500, Scorpion. Leaf flip, cut coils. Make do tires and wheels for now. Slip ahead a year? Sold GMC, bought Harley, got all obsessed doing the biker thing, now starting again w 65 SWB, 283,2bbl, 3 on tree. Last edited by Old School Low; 12-26-2013 at 02:37 PM. Reason: forgot something |
Re: New old guy.
Your warm start hesitation is likely caused by your timing being slightly too far advanced. That is if you're absolutely sure that all of your grounds have good clean contact with the frame and block. Try easing off the timing ever so slightly and see if the problem persists. Let us know.
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE |
Re: New old guy.
Thanks for the info, first thing tomorrow. We've 'sort of' tried this before but Ive got feeling that timing could still be the answer. 'Hand timing", we'd get it to start great but ZERO power or visa versa, Ill dbl check wires/grounds and tweek timing. An hour ago, new carb filter, back to drivers side tank and all good. Gonna take bad tank out and drain etc. This 350 motor is decent, Id give it to someone for rebuilding my th350. Any tranny guys around SE Wash state?
Re: New old guy.
I had an old blazer do that exact same thing, harder start when it was warm. I messed with it for a while and found out it was the battery....
Re: New old guy.
Might as well check it out. Auto Zone Store is...500ft from my house, they'll test it for me. Got my headers from Jegs today, 69090 Hedmans. Not like generic pic in Jegs or Summit, (i knew that) #1cyl tube goes straight back horizontaly OVER top of 3+5 before turning down behind #5 cyl. CAN'T IMAGINE being able to get to #5 plug. I dig the radical look but it sure looks congested. Who's used them and how is the fit.? (other side is same) Still cant post pics.
Re: New old guy.
Finally... cam, lifters, rockers and timing gear set to builder. Next Fri he says. Ill bring it home and do intake, carb, fuel-water pumps, pan, dist,
paint etc etc. I have a lot to learn, but will have good help at every step. Lonnie-I ordered stroker relieved, 2pc rms, SUM G3500X pan. It was cheap, tell me I did good. Chrome junk yard pan fit up on my block but builder shook his head too. lol
Re: New old guy.
I have used that pan before on a 350, no problems, good fit. Degrease and paint it which ever color you want.
Re: New old guy.
Re: New old guy.
#13 |
Re: New old guy.
Not a show truck yet. My $1000 twin blade money maker going to dealer for Toro recall work. (one blade not exactly parallel to ground, cuts uneven, only about 1/8 in but noticicable. I told em months ago but they thought I was crazy)[IMG]
#14 |
Re: New old guy.
FelPro 375-1803 coming with it.
#15 |
Re: New old guy.
#16 |
Re: New old guy.
#17 |
Re: New old guy.
Pan picture isnt one I meant to post. Although it does show shallower opening.
#18 |
Re: New old guy.
Some body figured how to post pics....
#19 |
Re: New old guy.
Man, I tell ya. Gal spent an hour w me to learn all this, we posted the pics for practice, she left and Im lost again. Daughter in law, Ill get her back tomorrow. We did the photobucket thing Itll be good when I override my short term memory issues. lol I cant post **** right but do a lot of photos and videos that photobucket will help me have fun with. I appreciate your replies. HAPPY NEW YEAR
#20 |
Re: New old guy.
Yup, that's the ground! Sand everthing shiny, dielectric tune up grease over everthang, and slap that dude on there! might not fix it, but it can't hurt!
#21 |
Re: New old guy.
You gotta know by now Im a struggling mechanic, so here is what is happening. Everything sanded and shiny, made a cable out of good spare poss batt cable and 3/8 self tapper into frame. Didnt like ground going into firewall rubber coating. Anyway, nope, that wasnt it. So..turned distrib a hair back and forth a few times, now it starts everytime, hot or cold but Ive lost 20%? of power. So..no more hard sstarting when warm but it doesnt run right. Vacuum advance? dont understand it very well but someone, somewhere brought that up. And I broke left tail light lens taking it off for bulb replacement. Old and brittle and I swear it was glued on. Looks like 9.99ish new or I could check junk yard. I might as well get both and maybe the whole assembly. Its a good thing I love working on this truck every waking moment
#22 |
Re: New old guy.
You can sand those used lenses with 1500-2000 wet, and then buff with a buffer and some polish. Almost good as new. I always use Meguiar's polish. You can get a quart and it will last for several years. You can polish every piece of plastic, including dull headlights on newer cars/trucks.
http://www.autopia-carcare.com/megui...Faxr7Aod6gwAbQ
#23 |
Re: New old guy.
Sounds like a plan.
#24 |
Re: New old guy.
#25 |
Re: New old guy.
Oil pan drain plug pic above-------Pan threads had a little bugger. In and out from both sides many times finally went smooth before store trip for 1/2-20 tap. Ill get one anyway. Anyone want the chrome pan? Couple of dents but flat rails, good holes.
OLD SCHOOL LOW: 78 Short Wide Heavy Half-Ratty Rod at moment. Old 4blt stroked to 383 Vortecs, Weiand, Scat, Hedman 1 5/8, Howards Roller, .495/500, Scorpion. Leaf flip, cut coils. Make do tires and wheels for now. Slip ahead a year? Sold GMC, bought Harley, got all obsessed doing the biker thing, now starting again w 65 SWB, 283,2bbl, 3 on tree. Last edited by Old School Low; 01-07-2014 at 01:04 PM. Reason: Clairify |
