Old 01-30-2015, 12:57 AM   #51
Root2812
Root2812's Avatar
Re: 1948 Chevy project
I think you did a good job. A floor is a great place to start learning metal work. You made it good and strong and any imperfections in the welding are covered by carpet so no one will ever know. Keep doing it and you'll be a pro in no time.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 01-30-2015, 07:50 AM   #52
J48chevy
J48chevy's Avatar
Thanks guys. Oldman3 I purchased the floor pan from classic industries.
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end.
http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670
J48chevy is offline   Reply With Quote
Old 01-30-2015, 11:55 PM   #53
99 to Life
99 to Life's Avatar
good job man, patches can be fun to do actually. If you grind down your welds, throw a skim coat of duraglas over them. There may be tiny pin holes you missed or can't see etc, so its always good security. Its all about practice, learning how to bounce around and stitch weld, not burning through and letting metal get so hot it warps. I like to use .023 or .030 on sheetmetal.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-31-2015, 12:08 PM   #54
focusedontheprize
focusedontheprize's Avatar
Your truck is coming along great. No need to rush and it sounds like you are learning a lot from this. I installed the TCI rear leaf springs in my '49 with lowering blocks and a Ford 8.8...you will love it.
focusedontheprize is offline   Reply With Quote
Old 01-31-2015, 09:04 PM   #55
52'5window
Just curious. What is your new over all wheelbase now that you have moved the rear end back?
I think stock is 115" so you are probably closer 119" now right?
52'5window is offline   Reply With Quote
Old 01-31-2015, 09:16 PM   #56
J48chevy
J48chevy's Avatar
I will measure it tomorrow and let you know. Good question. Also thanks everyone for the comments on floor.
Old 01-31-2015, 11:59 PM   #57
99 to Life
99 to Life's Avatar
1/2 ton AD is 116" WB but the wheels are offset almost 2" maybe less. My guess the kit will put you about 118"
Old 02-01-2015, 11:09 AM   #58
J48chevy
J48chevy's Avatar
Just measured it. 129 inches. Now remember this is a 3/4 ton not half ton.
Old 02-01-2015, 01:13 PM   #59
99 to Life
99 to Life's Avatar
oh ok, yeah missed the 3/4 ton! stock 3600 is 125.25" so I'v found. seems like a big change.
Old 02-01-2015, 06:14 PM   #60
Dan in Pasadena
Dan in Pasadena's Avatar
J48,
Just found your thread and I'm enjoying it.
How experienced a welder are you? I ask because I have an IFS kit to install and I am an inexperienced welder with a little 110v Hobart Handler 140. Supposedly I can weld up to 3/16 plate with it but I am hesitant to try. Thinking of tackng it in and having a certified welder run the beads. I've also thought of just finding a local shop to install it that won't charge me an arm and a leg.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 02-01-2015, 06:23 PM   #61
J48chevy
J48chevy's Avatar
Originally Posted by Dan in Pasadena View Post
J48,
Very new at it myself. I have the same welder also. Luckily my dad is a welder for a living and had him look over my stuff. Mine may not be as pretty as a professional, and at times I over weld stuff, but it will stay. So far doing replacement panels is all about taking my time and making sure to not burn thru with the welds. On the Hobart, I actually had it at the lowest point to do the floor so far. For the frame components it was between the 2 highest set points. In the end it is what you are comfortable doing. I would not think a shop would charge you that much to do if you went that route too.
Old 02-02-2015, 08:40 AM   #62
AZDavid
J Nice job on the 48. I am on my first build too and wanted to thank you for the info on your suspension. My build is also a 48 3600 5 window. I just picked up an explorer rear yesterday and have a TCI kit coming. looking forward to seeing your build come together.
AZDavid is offline   Reply With Quote
Old 05-15-2015, 10:31 AM   #63
lower50's
lower50's's Avatar
Great job so far keep up the good work.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-15-2015, 05:34 PM   #64
J48chevy
J48chevy's Avatar
Very slow build. Here is a pic of my tank and motor/trans mocked up. Making some progress. 😁
Old 05-15-2015, 05:36 PM   #65
J48chevy
J48chevy's Avatar
Tank pic
Old 05-15-2015, 05:38 PM   #66
J48chevy
J48chevy's Avatar
Motor/trans mock up.
Old 05-15-2015, 09:36 PM   #67
99 to Life
99 to Life's Avatar
very nice
Old 05-15-2015, 11:34 PM   #68
oldman3
oldman3's Avatar
Looking good...Jim
oldman3 is offline   Reply With Quote
Old 05-22-2015, 10:53 AM   #69
J48chevy
J48chevy's Avatar
Well frame is all boxed and painted with chassis saver. Motor/trans mock up done also. Now time to focus on the cab. Making some progress and not too shabby for a rookie. 😎
Old 05-22-2015, 10:54 AM   #70
J48chevy
J48chevy's Avatar
Frame with chassis saver paint.
Old 05-22-2015, 10:32 PM   #71
99 to Life
99 to Life's Avatar
nice and clean, feels good to have roller
Old 05-22-2015, 11:28 PM   #72
J48chevy
J48chevy's Avatar
Thanks everyone for the words of encouragement. I did post a question in the general forum about my panel replacement on the cab. More headaches but still enjoying the build. Here is a few pics of my issue. New hinges, and new outer panel. Now when mocked up there is about 1/4 inch gap. Has me baffled.
Old 05-22-2015, 11:30 PM   #73
J48chevy
J48chevy's Avatar
With this bolt wedged in the outer door and new panel match up great. Without bolt the door sticks out. Nothing was bent when removing and door adjustment is maxed out.
Again I am brand new to this and would appreciate any insight on what I may be missing with this.
Old 05-23-2015, 11:19 AM   #74
J48chevy
J48chevy's Avatar
Could this be due to new door hinges? The part that has me most confused is the top and bottom of the door align with the new panel but the middle part of the door is bowed out unless I gap it with the bolt as shown in the pic. Don't know if I should do something to build up the cab area in place of that bolt to fill the gap. Again nothing is tweaked as it was a simple rust removal and put the new piece on. Don't want to start welding until I can get this gap issue figured out.
There has to be someone on here who has run into this issue. Ideas and thoughts would be appreciated.
Old 05-24-2015, 10:40 AM   #75
99 to Life
99 to Life's Avatar
gap looks really good. I'v seen new hinges and they seemed really hard to open/put alot of strain on the door hinge pocket. I'd reinforce that hinge pocket since you have that outter cowl already off.
as for your gap, I'd do what you gotta do to add or relief metal. Esp on new patches. I'v seen several guys cut new fenders to help with gaps. Its hard to say if its the new patches or the trucks from the factory. They weren't gapped from factory at all and one truck is going to vary alot from others sometimes.
adding some filler in that area, I don't foresee a problem with. I'd suggest putting your inner door rubber on as it often effects door gaps.
