#51 | |
Re: '57 Stepside road-race build
We use MasterCam X8 at work. We also have SolidWorks and Autodesk, but we all prefer X8. However...its about $12k for the software license. ![]()
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292 1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987 Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker |
#52 | |
going to see if i can find a rack and pinion that has the right width for the stock gm crossmember from wat understood the frt... ffffrt.... f o r d thunderbird rack is just wide enough to avoid bumpsteer issues will need to adapt the steeringballjoints on the spindle side not sure yet about that either i go ream the holes to the propper coneshape and run thunderbird stuff or adapt the tread on some gm stuff so the screw ontoo the rack
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#53 |
Here is a brief update.
I finally got the lower control arm plates finished for the bags up front in the Jag IFS. I cut out the middle portion of the spring perch, because it had a weird oval cutout that wasn't going to align with any part of the bags. ![]() I also cut out some plates that will work with the bags and also allow for a few degrees of misalignment. ![]() Mocked up and welded in: ![]() ![]() And attached to the control arm with a bag stuffed in. It looks like it will work!! ![]() ![]() ![]() I will spend most of the weekend powder coating suspension pieces and wheels, so that I can start getting this frame back together to get my cab back on. Maybe I'll even take some pics and post them...
#54 |
Looks good.
Kim |
#55 |
Agree with Kim, looks really good!
Maybe I go with bags in the future.... ![]()
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#56 |
![]() Join Date: Jul 2011
Nice welding wish I could do that! Grinder is my friend!
Build for my 1959 Fleetside... http://67-72chevytrucks.com/vboard/s...d.php?t=518308 |
#57 |
yeah mine too , at least i still have a steady hand
#58 |
I did a little more work yesterday, most of which was powder coating.
My power steering pump leaked all over the garage floor, and since it was a junkyard pump anyway, I decided that it needed rebuilt. I already had the pulley off for powder coating, so it wasn't a very big step to just take it apart and do all new bushings, o-rings, and seals. While it was apart, I powder coated the fluid reservoir, because it used to be pretty rattty looking. ![]() ![]() Rebuilt and reassembled. ![]() Reunited with the motor. I just need to go back to a parts house to rent a pulley installer again to press on the pulley. ![]() Once I was done with the pump, I prepped and powder coated a bunch of suspension parts. I originally wanted to do a red wrinkle on all of my suspension parts, but a buddy of mine talked me out of it. So I decided to go with a color called Silver Artery. I'm glad I went with this, because it looks cool, should hide grime fairly well, and won't be too flashy on this old rusty truck. Camaro trailing arms, Jag upper a-arms and steering link, rear sway bar, and air tanks. ![]() Here is a close-up of the texture and color on these parts. ![]() After those parts were done, I did the lower A-arm plates from my last post as well as the other set of upper a-arms and a bunch of smaller brackets. Today I plan on doing the front disc brake shields, the rotor hats, and finish the rest of the 'Vette wheels.
#59 | |
Thanks, Shadow! I TIG weld everything because it really is a superior process. Best part is no spatter, so if you're working on something upside-down, you don't get little burns everywhere.
Thank You! Quote:
Steady hands are good, but good eyesight is the key, as is hand-eye coordination. Especially when TIG welding.
#60 |
A320 Pilot/USAF Retired
The finished powder looks amazing and nice job on the bag mount!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#61 |
Really sharp looking.
I like the color choice. If I had the funds that's the way my frame would look. Kim |
#62 | |
https://www.eyejusters.com/home/ i have a set and they work great for reading fine print and focussing on a certain distance
#63 |
Just the boxing plates, both front and rear. I am in the process of getting another frame and going a little different. Thanking you in advance
Rude Dude - The files should work on a plasma. We have both at work and they run off of the same workstation. Exactly which parts are you needing the files for? Front boxing plates, rear boxing plates, airbag mounts, etc?[/QUOTE]
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
#64 |
Well, I spent another day in the garage powder coating parts. This was just about the last session for that until I change my garage around again and get back to fabrication mode. (It's just a little bit too small to do both at once.)
I finished the wheels. They are a pearl gunmetal that I shot a flat clear over. You will see flat clear as a staple in the rest of my build. I'm not a fan of shiny. ![]() I also did my brake rotors in black. I figure this will cut down on any rusty buildup in the future from the weather and salt air here at the oceanfront. ![]() ![]() Finally, here is a decent shot of the 355 that I recently rebuilt. I painted the block and heads, and all the rest is powder coated in a wrinkle black. I think she looks just dandy. The carb is powder coated too. On the floor are the rotors before I coated them...so you can see why i did it! ![]() ![]()
#65 |
That stuff is really sharp looking.
Kim |
#66 |
![]() Join Date: Aug 2010
So I noticed in the first page you had mocked up a 5.3 and now your using a 5.7 , What prompted the change ?
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
#67 | |
The main thing that prompted the switch is that the Jag IRS doesn't fit the stock frame, so I decided that I will build a new full tube chassis and when I do that, I will build it to package the twin turbo setup that is planned for the 5.3. So basically it came down to time and ease. I'll build the other chassis with the 5.3 while still driving the truck with the modded stock frame and 5.7, and once it is done I'll swap the frames and hopefully have less down time.
#68 | |
Pretty cool, Alot of work but pretty cool lol...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#69 |
I've been busy lately, but not enough on the truck. I'm definitely not going to meet my deadline of driving her late February, but I knew that about a month ago, so I haven't been too aggressive in building. I'm getting deployed in a few weeks, so I have a lot of other things to get squared away instead of the truck. BUT, I have been putting in work.
The torque arm needed a mount. Stock mounts in the f-body consisted of a rubber-lined clamshell that mounted to the trans. This was not going to be feasible on the truck, because the trans doesn't have the provisions, and the arm is too short. ![]() So...I fabricated something that should work. ![]() ![]() These show that it is adjustable to set pinion angle depending on which ride height I use, and you can see how low the trans crossmember is with the bags fully deflated. The torque arm pivot is also at the u-joint pivot and can still handle some fore-aft movement with suspension articulation. Using the high-misalignment rod end will also provide no binding when one wheel goes up and the other doesn't, which may happen a lot while autocrossing. ![]() ![]() ![]() I also had a facepalm moment after I welded in the rear boxing plates because now I couldn't access the nuts to bolt down my second bed cross-sill. So, I enlarged the hole with a step bit and welded a flanged nut there, so I can now have my cross-sills. ![]() ![]() I still have a lot of work to do on the frame, but it can all be accessed either without the bed or without the front clip, so for now I'm going to call it quits on the frame and start some work on the cab so that I can get this thing put together into a rolling shell before I deploy. Then I can get back into it when I come back later this year.
#70 |
![]() Join Date: Jul 2012
Nice fabrication and love the powdercoating! Do you do the powdercoating in your shop?
And you mentioned being deployed...guessing you are in the military and thank you for your service! |
#71 |
Nice fab work.
Kim |
#72 |
![]() Join Date: Mar 2011
Very nice work, thanks for your service, be safe and hurry back...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#73 |
I got my cab into the garage to do a few repairs while it is off the frame. I didn't really get too far, but here is what I did today:
Before taking any pictures, I cut out the driver's side floorboard. That took most of the day, which I wasn't really expecting. The worst part of any of this is what I did to the truck over 10 years ago...I used a cheap rubber undercoating spray all over pretty much everything that had pinholes in it back then, and it doesn't come off very great. So I will be fighting that for longer than I want to admit. The lip on the driver's side was very beat up and cooked, so I spent some time with a hammer and dolly and got it lined up a little better. I'll work it some more after I get the floor completely welded in. ![]() ![]() After a little persuasion: ![]() And the entire firewall, full of holes. I have a lot of work ahead of me. ![]() And this is the massive beating that my dad and I gave the firewall many many years ago to clear an HEI distributor. I tried to hammer & dolly this as well, but it didn't want to budge. I think I'll just cut it out and weld in fresh steel. ![]() Got the new pan mocked up. Fits OK ![]() This bead isn't the same width as the original ![]() And this lip doesn't extend down the step as far as original ![]() One more comment about this particular floorpan: There was a part that should have folded down at the toe board, but it didn't fold at all, it just extended toward the hinge pocket. I trimmed it and bent it to align like the factory one. (but I bent it little short) I forgot to measure twice before I cut once... ![]() I prepped the cross-sills with some stuff that Boeing makes, and it seems to do a fair enough job on the rust that was there. This was treated after grinding. ![]() ![]() ![]() And I finally got it mostly welded in. I still have some of the bigger gaps to fill, and a lot of grinding to do. I did not weld the lip that meets the step, because I think I'm going to replace the entire rocker and step on both sides as well. ![]() ![]() ![]() This is the part that I mentioned earlier that is not folded down on the part as is comes. I folded it down and trimmed it, but didn't quite get it right. It will hold and will be covered by the inner fender, but I still hold myself to a higher standard than this, and it irks me. ![]()
#74 |
You're doing a nice job on the repairs.
I tend to be anal about things also and end up doing some things over that would be just fine. Kim |
#75 |
Nice work and thank you for your service! What are you using for an oven? Did you build one?
Rick |
