Old 12-11-2013, 11:22 PM   #51
Artikgrau325is
Re: My build thread- 67 C10 SWB
Thanks a ton for taking additional pictures of the cab lifting apparatus, you have no idea how much that helps me. When I ask buddies if they can help me out, they're suddenly busy, can't even entice them with beer haha.
Artikgrau325is is offline   Reply With Quote
Old 12-12-2013, 04:59 AM   #52
checkmate211e
checkmate211e's Avatar
No problem. I am the same way, happy to help any way I can.
My 67 Chevy C10 SWB build: http://67-72chevytrucks.com/vboard/s...30#post6406130
Hydroboost conversion: http://67-72chevytrucks.com/vboard/s...22#post6405622
checkmate211e is offline   Reply With Quote
Old 12-12-2013, 06:54 AM   #53
Bennett68C10
Bennett68C10's Avatar
Nice looking build, I really like your cab lift as well
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 12-17-2013, 09:23 PM   #54
checkmate211e
Well, looks like the 94 Buick Roadmaster driveshaft is a perfect fit! $80 on Ebay (free shipping). I did some research on wheelbase and found that the Roadmaster is 115.9", and our SWB is 115", so I figured the Roadmaster was powered by an LT1 and 4L60E (electronic 700r4). I may have an issue with the rear u-joint, but will take another look at it tomorrow night.
Old 12-17-2013, 10:00 PM   #55
checkmate211e
I believe this is probably the U-joint I need for the rear, but I'm not sure. Maybe someone with experience can chime in?
http://www.dennysdriveshaft.com/p161...re+Information
Old 12-17-2013, 10:06 PM   #56
duallyjams
duallyjams's Avatar
I have had Dennys build a couple of drive shafts back in the day ( would recommend ) sure if you have any doubt you can give them a call.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-17-2013, 10:33 PM   #57
67chevy1
67chevy1's Avatar
I wish I was a little closer to MD, I think I could learn several things from your build. You have defanately put a lot of forethought into this before you started. P.S. When you get board with yours you could come to IL. and start on mine.
67chevy1 is offline   Reply With Quote
Old 12-18-2013, 12:06 AM   #58
FRANKENSTEINC10
FRANKENSTEINC10's Avatar
I love the build!! great work.
FRANKENSTEINC10 is offline   Reply With Quote
Old 12-18-2013, 08:42 PM   #59
checkmate211e
Thank you! Update on the drive shaft..... story of my life.... too short (approx. 3/4") looks like I have to have a new tube cut, along with needing a combination u-joint for the rear. Well, I guess it was worth the gamble and it gives me a visual aid for mocking up the x-pipe.
Old 12-19-2013, 03:59 PM   #60
vsoree
vsoree's Avatar
Originally Posted by checkmate211e View Post
Sure T, ask and you shall receive. I am still currently in build mode but this pretty much how it sits
Nice build, what kind of fuel cell is that, where did you get it?
Stay blessed not Stressed!
vsoree is offline   Reply With Quote
Old 12-19-2013, 05:58 PM   #61
checkmate211e
Thank you. I got it from Classic Performance Products (6372AGT-20BF is the part #), but shop around, you may be able to find it cheaper.
Old 12-20-2013, 03:37 PM   #62
checkmate211e
Update: had a new 1 piece driveshaft made today. Took a slip yoke and dimensions to Accubuilt here in Salisbury, MD at 9:00am this morning, and around 12:30pm I got the call that they had finished. $260 for maintenance free ujoints and spicer weld yokes. I recommend using this worksheet when measuring for a 1 piece driveshaft: http://www.dennysdriveshaft.com/app/...iagrams/b.html
Also managed to get the electric fuel pump mounted last week, just didn't get a pic posted.
Old 12-22-2013, 11:41 AM   #63
checkmate211e
Work on the Transmission crossmember has begun. Trying to make more clearance for the Pypes X-pipe.
Old 12-22-2013, 12:46 PM   #64
checkmate211e
I would love to build another after this. Dad wants the next one to be a Chevelle but I wouldn't mind another mid 80's Monte.
Old 12-24-2013, 03:31 PM   #65
checkmate211e
Work in progress.... Still more grinding to do. Just noticed this crossmember (pre-modified) on sale at Performance Online $65.99.
Old 01-04-2014, 09:16 PM   #66
checkmate211e
Finished modifying the transmission X-member. Still working on the exhaust, using wooden blocks to hold up the pipes to get a general idea. The plan to use Pypes Street Pro mufflers has been scrapped due to the length of the case (14"), so I have ordered a pair of Spintech Pro Street 6334 mufflers (12" case). The 14" case was going to be a very tight fit between the trailing arms and the frame. The Spintech mufflers should be here around Wednesday.
Old 01-06-2014, 09:19 PM   #67
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Nice build checkmate looking forward to the dash being finished. I think it will look fantastic.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 01-06-2014, 09:37 PM   #68
checkmate211e
Thank you, thank you very much
I hope this exhaust sounds as good as it is a pain in the A**. I need to get back to work on the dash, but for some reason I keep on procrastinating on it. The dash is probably the make or break on this project. Either it ends up looking great, or it looks like crap and that's all that people notice. Due to the exhaust routing and the Transmission crossmember, the original E-brake cable system idea has been scrapped. Scouring Ebay, I came across a very good looking 2004 Subaru Forrester E-brake handle and picked it up for $27 (free shipping). Its much cheaper than $130 for the Lokar handle. I guess its official, I'm building a rat rod (as if it wasn't already shaping up that way).
Old 01-06-2014, 10:02 PM   #69
checkmate211e
X-pipe progress. Mufflers are supposed to be here Wednesday, provided "global warming" doesn't cause them to get stuck in transit....
Old 01-06-2014, 10:22 PM   #70
Bennett68C10
Those mufflers will sound awesome, I have Spintech Super Pro Streets on mine and they sound great. Nice job on the exhaust so far.
Keith
66 Suburban
IG: bennett68c10
Old 01-06-2014, 10:23 PM   #71
checkmate211e
Thanks Keith. Do you have a sound clip of yours?
Old 01-06-2014, 10:31 PM   #72
Bennett68C10
Yeah here is a link to the post on my build thread with the YouTube clip. It's a lumpy big block but you get the idea
http://67-72chevytrucks.com/vboard/s...&postcount=503
Keith
66 Suburban
IG: bennett68c10
Old 01-06-2014, 10:55 PM   #73
jhama78
jhama78's Avatar
If you didnt already know it, a sure fire way to prevent leaks on the band clamps is to wrap the pipe joint with a doubled over piece of aluminum foil before putting the band clamp on it.
Build is looking good man, hopefull the 'global warming' doesnt turn delmarva into an iceberg... haha
I still need to get up your way and check this thing out.
Cheers!
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 01-06-2014, 11:56 PM   #74
checkmate211e
Cheers!
I did not know, thanks for the tip! I probably won't keep the clamps there, have decided to weld all pipes except for the mufflers, which will be clamped. Yeah, its starting to feel like a iceberg out there, the cold "winter vortex" (because the media won't admit they are participating in the hoax) is bringing the chill for sure. Would be cool to meet up with other C10 peeps, its fun to chat about these awesome trucks.
Old 01-07-2014, 03:15 PM   #75
67cheby
67cheby
67cheby's Avatar
WOW, impressive amount of sheet metal work in that cab !
67cheby is offline   Reply With Quote
