Old 12-19-2013, 01:52 PM   #51
woodridge
woodridge's Avatar
Re: Replaced intake gaskets now ticking/knocking?? Help
All looks good to me. I have torn many sbc down and found the oil pump sleeve missing, not a biggie. Without a bore scope, the only option aside from pulling the heads would be a spy cam. Good luck.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 12-19-2013, 02:10 PM   #52
csdineley
csdineley's Avatar
Zoomed in area. where it looks like some cracks to me.
csdineley is offline   Reply With Quote
Old 12-19-2013, 03:36 PM   #53
csdineley
csdineley's Avatar
Passenger side head off. Think I found the source.
#8 piston
Old 12-19-2013, 03:56 PM   #54
woodridge
woodridge's Avatar
Ouch! Could you tell what it was? I don't think your flywheel is cracked, not common for a SS, probably just an oil track. See if it will wash off with some brake/parts cleaner.
Old 12-19-2013, 04:34 PM   #55
csdineley
csdineley's Avatar
Nothing else was in the there. And the head looks fine.
Old 12-19-2013, 05:11 PM   #56
monte0185
monte0185's Avatar
I second this.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 12-19-2013, 05:36 PM   #57
mrolds88
On the flywheel, take a wire brush to it. See if that takes it away. On the piston. Ouch!! One thing I find odd is the amount of damage at the top of the piston. You going to rebuild, swap engines or just repair #8? Also I noticed a sliver of something on the oil pump, what was that?
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 12-19-2013, 09:09 PM   #58
csdineley
csdineley's Avatar
Not sure where to go from here. Guess I need options and or opinions. Originally my hopes and plans were to keep it going, until next year. So I could have time to rebuild my spare motor.
Old 12-19-2013, 10:45 PM   #59
Jake Wade
Jake Wade's Avatar
#8 piston
Ah, yeah, that will do it, looks like something fell into the intake port while the intake was off.
Jake Wade is offline   Reply With Quote
Old 12-21-2013, 12:19 AM   #60
woodridge
woodridge's Avatar
Find a used piston and rod, buy a single ring kit and put it back together.
Old 12-21-2013, 12:36 AM   #61
csdineley
csdineley's Avatar
So if I pull a piston and rod out of my spare motor. Re ring it, it should work???? Should I hone that cyl? How about the bearings?
Old 12-21-2013, 12:54 AM   #62
INSIDIOUS '86
INSIDIOUS '86's Avatar
If it didn't crack the cylinder and score it then yes. New piston and rod will work. But measure the rod bearing dia and the rod throw dia and make sure the bearing clearances are in check. Get a deglazing home and deglaze the cylinder and get the crosshatch in there so the new rings will seat and seal. Clean up any dust with brake clean.
And that flexplate/flywheel is stress cracking. Replace that sucker. Check the valves and valve seats on #8 to be sure. Then go ahead and throw it back together and pray
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-30-2014, 10:34 PM   #63
csdineley
csdineley's Avatar
So I guess I should give you guys an update. I took the holidays off from getting the truck back on the road. And after doing a bunch of reading and thinking. I've decided to either send the motor to get rebuilt, or buy a crate engine. I should have my taxes back soon. And I talked the wife into a budget of about $3000 max.
If I rebuild the motor I'd like to do a mild 383. This truck is just a daily driver with some towing once in a while. It's been 20 years since I had an engine rebuilt so can I build one with my budget?
If I go with a crate motor I was thinking about the Vortec 5700 GM L31-Rhttp://www.summitracing.com/parts/nal-12530283 Any thoughts about this motor? I know I'd need a vortec intake manifold.
Old 01-30-2014, 11:14 PM   #64
buddy_1
buddy_1's Avatar
Wouldn't need an intake, I used a cut-off wheel to slot the center holes on my intake. That lets the 60 degree bolt holes work.
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 01-30-2014, 11:21 PM   #65
csdineley
csdineley's Avatar
That works for the swirlport heads from 87-95. But the Vortec heads are different and need a different intake.
Old 01-30-2014, 11:33 PM   #66
buddy_1
buddy_1's Avatar
OK, when I followed your link the pic they showed was like a TBI head.
Old 01-30-2014, 11:41 PM   #67
csdineley
csdineley's Avatar
True I didn't notice that. They say it's designed to fit 1996-2000 full size Chevy/GMC trucks. So it should have true Vortec's. Guess I should double check that.
