02-17-2014, 06:20 PM | #51 |
Old and crusty
Re: Project 1966 C-10 LSx
That's a great price. The only ones I've seen out here at that price are shredded or incomplete. Post up some mounting pics when you get them installed.
65 Chevy long wide daily driver - SOLD! 64 Chevy Short Step LS |
02-17-2014, 10:31 PM | #52 |
Will do... i'll be fabbing up some spacers etc but... won't be too bad I think
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
02-19-2014, 12:16 AM | #53 |
For reference for other LS swappers...
2-1/2" exhaust Hedman headers offsets.... P/N# 18804
02-19-2014, 08:50 AM | #54 |
Nice work on the transmission linkage.
1961 C60 Viking 8' Dump 261 SM420 2-Speed Rear 1966 C10 Fleetside 350 W/ Saginaw 4 speed 1985 K10 Chevy 6.2 diesel 700r4 longbed 2001 Dodge 3500 Dually 24v NV5600 4x4 USMC Reserves Jason |
02-19-2014, 09:06 PM | #55 |
Awesome idea on the gas pedal. I may have to redo mine.
02-25-2014, 10:35 PM | #56 |
Spintech Pro Street 6000's (PN# 6331)
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB Last edited by 66LSx; 02-25-2014 at 11:03 PM. |
02-26-2014, 09:11 PM | #57 |
Got my 67-72 C10 Boyd Fuel tank in today on the 66'..... looks/fit GREAT!
Enjoy (fit good.. only had to do a slight relief on the angled crossmember) mocked in.. need to add 1 more bolt and swap out to grade 8
02-26-2014, 11:33 PM | #58 |
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
02-27-2014, 10:15 AM | #59 |
Love this build. Subscribed!
02-27-2014, 10:21 AM | #60 |
Great job...those headers are top notch products. Looking good.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
02-27-2014, 11:27 AM | #61 |
That tank is sexy. Make me second guess putting the tank back behind the seat.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
02-27-2014, 10:26 PM | #62 |
Love the build and the progress. Looking forward to future updates.
02-27-2014, 10:48 PM | #63 |
what are you doing for the heater control as a member is looking for the screw that holds it all together....ps kick a** shift rod!!!!
02-27-2014, 11:48 PM | #64 |
More exhaust mock up...
drilled some holes thru the OEM crossmember (to eventually be replaced by a dropmember) Enjoy! How its going to dump... still need to connect to the Spintech mufflers though yet... and add the H-pipe beforehand.
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB Last edited by 66LSx; 02-28-2014 at 12:17 AM. |
02-28-2014, 01:42 AM | #65 |
Creative! Have you cycled the trailing arms and do you think if you go with a drop member ,it may interfere with the tubes hitting the arms?
GOD BLESS AMERICA! |
02-28-2014, 01:58 AM | #66 | |
Right now I cycled it as much as I could (jumping on the tailgate when its down....) wasn't even close. (still had an 1" + which means I had another 10+ degrees of trailing arm travel.... aka 8+ inches of axle travel)
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB Last edited by 66LSx; 02-28-2014 at 01:59 AM. Reason: spl |
02-28-2014, 07:35 AM | #67 |
I thought you had cats at first but now I see they are flex parts?
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 Last edited by bj383ss; 02-28-2014 at 07:38 AM. Reason: Answered my own question. |
02-28-2014, 10:08 AM | #68 |
Yup... just some short braided mesh flex pipe to isolate engine movement from the rest.... especially since the truck isn't chassis stiffened.... theres so much flex potentially in these frames I decided to run them.
02-28-2014, 10:02 PM | #69 |
Pounded it out tonight.... its done... just needs to be welded.
The H-pipe i wanted closer to the collectors... but quite frankly its only 32" away vs. the normal 12-24".... and its better than no H pipe. Really excited how it all came out... suspension travel clearances, driveshaft clearances etc. Enjoy!
03-04-2014, 12:13 PM | #70 |
todays picture
03-04-2014, 10:52 PM | #71 |
Looking great! What did you use to cut a hole in the crossmember? I'm thinking about doing my exhaust in a similar way to keep it tucked up. Love the idea of the flex piping. I have an X pipe, but not way to separate the exhaust after the header, so it's impossible to get it out with the bed on. Thinking of using some flex after the muffler and clamp it on one size for easier removal and the ability to flex with frame/motor shifting.
Are you going to use a floor shifter with the bench seats? See any fit issues with the cupholders? |
03-05-2014, 10:03 AM | #72 | |
If you go to page 2? you'll see I converted the three-on-the-tree column to run the automatic 4L60e... I will have NO floorshifter whatsoever.
03-17-2014, 09:16 PM | #73 |
Dash Concept 3D....(Solidworks)
03-17-2014, 10:07 PM | #74 |
I like your dash concept. Only think I would do different is put two gauges in the far right part.
Bret
03-17-2014, 10:10 PM | #75 | |
From left to right: Fuel, Bat, Tach, Speedo, Oil Press, Water Temp Heater Panel: Toggles for Fuel Pump and Elec Fan Override as well as Econo fan control Radio Bezel is now Fuel Pressure, Vacuum, Trans Temp Blank Panel on far right is clock Glove box
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB Last edited by 66LSx; 03-17-2014 at 10:32 PM. |
