#51 |
![]() Join Date: Oct 2013
Re: '87 tank/fuel pump supplier
Supply is a 16mmx1.5 and the return is a 14x1.5. Earls part #s are in the pics...
#53 |
old thread I know. but this is the setup I want to run, and I had a few questions. I see the 87 sender has 4 ports. one is pressure, one is return from the corvette regulator/filter. what are the other two for? I ask because instead of running a second complete tank/sender/pump, My thought was to simply (or not so simply) run a small transfer pump from the old talk to the new tank using one of those ports on the new sender. does anyone see a problem with doing this? I have twin tanks now, and originally I wanted to run two complete setups with new tanks, senders, and walbro 255's, but I was thinking this might work too, and cheaper.
second question, how does the walbro 255 hook up in the sender, anyone have a photo? again, sorry to bump a year old thread. but since this had the info I needed, it seemed fitting. |
#54 | |
I'm just glad to be here!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#55 |
bump good info
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
