Old 02-16-2019, 10:28 PM   #51
Dewey72
Re: 72 Cummins swap
Got the pump apart and found it just sticky. But while apart why not put a fuel pin in and gov spring. Just got it off the stand and finish installing it tomorrow
Dewey72 is offline   Reply With Quote
Old 02-17-2019, 01:35 PM   #52
COS399
COS399's Avatar
Re: 72 Cummins swap
Looking good. Glad to hear that you got her going.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 02-18-2019, 04:01 PM   #53
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 Cummins swap
Very nice! Yeah, this low sulfur diesel varnishes and can really cost ya a lot of coin. I've had a couple of p-pumps that I was saving that done this. It sucked for sure.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-19-2019, 11:42 AM   #54
Dewey72
Re: 72 Cummins swap
Thanks Dieselwrencher. Have you ever found any additive that really works?
Old 02-19-2019, 03:45 PM   #55
DieselSJ
Re: 72 Cummins swap
2 stroke oil. 1oz per gallon. Read a lubricity test a while back where this worked better than most of the commercial "additives" out there. Run the cheap TCW3 rated stuff from Walmart.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 06-13-2019, 11:51 PM   #56
catch2otwo
Re: 72 Cummins swap
what are you using for fuel pickup? factory sender and pickup tube? what about pump?
catch2otwo is offline   Reply With Quote
Old 06-14-2019, 04:06 PM   #57
Dewey72
Re: 72 Cummins swap
Ya running the stock pickup and sender. I got the factory lift pump on the engine and the Bosch VE pump with the 3200 gov spring and the hungry diesel fuel pin.
Old 06-16-2019, 09:44 AM   #58
catch2otwo
Re: 72 Cummins swap
do you get any fuel starvation at the lower tank levels?
Old 06-17-2019, 04:15 PM   #59
Dewey72
Re: 72 Cummins swap
Haven't driven it enough to tell. Runs and drives fine on 1/4 tank.
Old 08-13-2020, 09:50 PM   #60
HKanada182
Re: 72 Cummins swap
Sorry to bring this post back but what trans did you use? What engine mounts and crossmember as well? Im looking at doing a swap like this in my '72 K20 so 4x4 may change things. Id like to have an NP3500 or 4500 to my np205 tcase but not sure what adapters and all that I will need.
HKanada182 is offline   Reply With Quote
Old 08-14-2020, 04:32 PM   #61
Dewey72
Re: 72 Cummins swap
I ran a mount and cross member from Autoworldmt. And am running a nv4500 with a 205. Had the t case bored to the big bearing and installed the larger input shaft and redrilled the 4500 rear housing to clock the t case correctly. And running the Dana 60 front and 70 rear.
Old 08-14-2020, 04:35 PM   #62
Dewey72
Re: 72 Cummins swap
Got to take it to work and a show awhile back
Old 08-14-2020, 06:39 PM   #63
Dieselwrencher
Re: 72 Cummins swap
Dewey, glad to see you back on and the truck turned out beautifully! How does she ride as a short wheel base nose heavy rig? I have a guy that wants me to take his 69 D100 and convert it to a 4x4 and put a 12 valve in it. I'm leery he'll hate the ride afterwards.
Ryan
Old 08-15-2020, 08:35 AM   #64
gmikkels
Re: 72 Cummins swap
Dewey,
Truck looks awesome, what size tire did you go with?
Thanks,
Gene
gmikkels is offline   Reply With Quote
Old 08-17-2020, 10:38 AM   #65
Dewey72
Re: 72 Cummins swap
Thanks! For the most part it drives fine but some of these country roads its like hearding cats trying to stay in your lane. Thinking about cross over steering. The worst part about the truck is the old man wants it back!1
Old 08-17-2020, 10:38 AM   #66
Dewey72
Re: 72 Cummins swap
Originally Posted by gmikkels View Post
Dewey,
Thanks,
Gene
Thanks! I put 315/70/17 toyo MT
Old 08-17-2020, 08:03 PM   #67
Dieselwrencher
Re: 72 Cummins swap
Dewey,
Thanks,
Gene
Gene, nice to see you around !
I get that. My orange truck needs cross over steering. Due to the air ride in the rear and the push pull steering box, the motion of the rear suspension creates extra movement in the steering wheel. If you're used to it, it's no big deal. But if you let someone else drive it they are like WTF?
Ryan
Old 01-22-2021, 11:53 AM   #68
Dewey72
Re: 72 Cummins swap
My door handle fell off the other day the thumb button. Anyone know of the best quality handles you can get aftermarket?
Old 01-27-2021, 02:12 PM   #69
Dieselwrencher
Re: 72 Cummins swap
For the window crank, or?
Ryan
Old 01-28-2021, 11:37 AM   #70
Dewey72
Re: 72 Cummins swap
Sorry my bad. Passenger side outside door handle.
Old 01-28-2021, 01:39 PM   #71
Dieselwrencher
Re: 72 Cummins swap
I've had GSI door handles on my truck since they started making them and I like them. I've had 0 issues with them.
https://www.gsimfab.com/1967-1972-ch...es_8_4299.html
Ryan
Old 01-29-2021, 11:39 AM   #72
Dewey72
Re: 72 Cummins swap
Thanks! Those are some awesome looking handles.
Old 06-27-2021, 02:35 PM   #73
gmikkels
Re: 72 Cummins swap
Hello,
Is there much movement in the top of the engine with the auto world mounts?
Thanks,
Gene
Old 06-28-2021, 10:32 AM   #74
Dewey72
Re: 72 Cummins swap
Not much movement
Old 06-28-2021, 11:37 AM   #75
gmikkels
Re: 72 Cummins swap
Thank you,
Gene
