#51 |
Re: SB 2wd exhaust manifolds
I would like the plugs out please. I will take it then. No rush. When you are back from holidays let me know the total and ill settle with you. Do you have any good inner A.I.R. tubes? The ones that go inside the manifold and head? I need 4 if you have any. Rod.
#52 |
Please pm payment info, thank You.
#53 |
Any info on the manifolds? Inner tubes? just checkin in. Rod.
#54 |
"Junkyard Dog"
![]() Join Date: Jan 2008
Rod, I have the manifold on the work bench a waiting time to remove the plugs. I've been struggling with time to get them out. My work has me doing 13-14 hour days as this is a very busy time of year for me. I try to get to it this week. Thanks, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
#55 |
Hey Tom, I know you've been really busy but I'm looking for a 4WD SBC center dump LH manifold.
#56 | ||
"Junkyard Dog"
Thanks, Tom
#57 |
I sure am. Sorry but I need them out or it doesn't work for me. Rod.
#58 |
any luck getting the plugs out?
#59 |
"Junkyard Dog"
Ok..I've pulled 3 manifolds and finally one that the plugs came out of and looks goodwith no cracks. It will go in the acid tank monday and should have some pics Tuesday. Thank, Tom
#60 |
Awesome. I bought 2 with plugs in as well and could not get them out before destroying the manifold. Thanks. Looking forward to pictutes. Rod.
#61 |
Any pictures yet? I know youre busy. No pressure just checking. Let me know. Rod
#62 |
"Junkyard Dog"
Rod, here's the pics. As the pic shows it does have what I call "heat checked" in the center. It also would need to be surfaced. I would do this one for 45.00 plus shipping. Send me your postal zip again and I'll get a shipping cost. Thanks, Tom
#63 |
The one i have right now looks the same. Is this something that will crack out shortly? Or leeak? I know these are prone to cracking out. Postal code is S0K2T0.
#64 |
![]() Join Date: Aug 2013
is there a difference on a 292 exhaust exit i.e. down or angled simular to the ram style?
#65 |
"Junkyard Dog"
Rod, I see these like this all the time. I don't think the heat check will promote a crack. Yes, these are prone to crack especially the RH side. Shipping is 45.00. Thanks, Tom
#66 |
"Junkyard Dog"
292's came with 2 bolt and 3 bolt header flanges. The angle of the dump was angled must like the V8 manifold pictured above.
#67 |
![]() Join Date: Jan 2013
As far as coatings go...Tech Line Coatings have really nice products.
Black satin & cermakrome are the 2 most popular. Be aware that these SHOULD be oven cured before put into service. Jamie 71 ![]() Longhorn |
#68 |
thanks you for the help but I am going to pass on this manifold. It looks the same as mine and am going to with any luck find one with a little less of that heat check. If you do find another one let me know. Thanks for you time, I do appreciate it. Rod.
#69 |
"Junkyard Dog"
No problem, I fully understand. I have more still on trucks so when I get to them I'll keep you in mind. Thanks, Tom
