Old 09-08-2014, 04:39 PM   #51
resto newbie
resto newbie's Avatar
Re: Project "DV8ED" 67 Chevy SWB
Nice clearance.
Chad
1967 Chevy C10 "Project DV8ED"
1994 Nissan 300zx convertible
2004 Chevy 2500HD crew cab 4x4
resto newbie is offline   Reply With Quote
Old 09-08-2014, 04:41 PM   #52
resto newbie
Cpp modular 2 inch drop spindles and 73-87 disk brakes.
Chad
Old 09-08-2014, 04:43 PM   #53
resto newbie
Put on some old roll around wheels and tires.
Chad
Old 09-08-2014, 04:47 PM   #54
resto newbie
Last one. After the install I can't express enough how great a product Porterbuilt has come out with. The installation was absolutely trouble free. Everything lined up and if you follow the instructions it's pretty simple.
Only thing left to do is clearance the rack and pinion and bolt it up.
Chad
Old 09-08-2014, 10:43 PM   #55
Hardesty454
Hardesty454's Avatar
Looks good buddy!
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 09-08-2014, 10:46 PM   #56
nlped
nlped's Avatar
SwEET!!! Love it
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-09-2014, 10:01 AM   #57
resto newbie
Thanks guys!
Chad
Old 09-09-2014, 11:47 AM   #58
jlaird
jlaird's Avatar
Originally Posted by resto newbie View Post
I've always heard "it's the journey not the destination".
You've got that right! Or at least that's what all us guys that are SLOW tell our selves. Lol. Looks great so far though!
-josh
jlaird is offline   Reply With Quote
Old 09-15-2014, 02:06 PM   #59
resto newbie
That's what we have to tell ourselves to keep our minds on the project I guess.
Chad
Old 10-07-2014, 07:24 PM   #60
resto newbie
For at least the third time I have decided on my wheels. They are Foose Knuckle 22x9 fronts and 22x12 rears.
Chad
Old 10-07-2014, 07:27 PM   #61
nlped
nlped's Avatar
Do they make a good wide 22" tire for that 12" wide wheel? The wheel is sexy, btw.
Carter
Old 10-07-2014, 07:31 PM   #62
resto newbie
Well it's either 295/25ZR22 or 315/series. The 295's are 1/2 inch narrower than the wheel and are about $225 each. The 315 is 1/2 inch wider than the wheel and cost $500 each. I think with the contour of the bed its a good idea to try the 295. I hope it works because its going to be hard for me to roast a $1000 set of rear tires.
Chad
Old 10-07-2014, 07:40 PM   #63
nlped
nlped's Avatar
Yeah, a grand would be painful to toast. I have a 295/30r22 on a 22x10 but a bit more aspect ratio than the 25 series...that is LOW profile for sure.
Carter
Old 10-07-2014, 07:45 PM   #64
resto newbie
35 would be perfect for the sidewall and diameter I want, and 305/series would be perfect for the width, but they don't make them.
Chad
Old 10-07-2014, 07:47 PM   #65
boostedc10
boostedc10's Avatar
Love the choice in wheel. Let's see how long you stick with it lol!
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 10-07-2014, 11:48 PM   #66
rwade
rwade's Avatar
Hey chad,
Pirelli makes a 335/25/22 and a 315/25/22 in a "scorpion zero" for about $700-$750 for a pair. They are also available in the "p zero" but way more expensive. I had some 295/25/22's on some 10" wide intros before and they were stretched out.
Wade
rwade is offline   Reply With Quote
Old 10-08-2014, 05:43 AM   #67
Bennett68C10
Bennett68C10's Avatar
Frame is looking good, if you want a little more sidewall, I know some people run a 305/40/22 on 22x12's and they are inexpensive.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 10-08-2014, 08:02 AM   #68
resto newbie
305/40r22 is a 31.5 inch diameter tire. These PB kits can only lay frame on a 30 inch tire, right?
Chad
Old 10-08-2014, 08:13 AM   #69
Bennett68C10
I'm not sure, you might want to check with Porterbuilt on that. I know N2billet runs a 285/40/22 on both Hazel and Tiffany and that is a 31" tall tire. Also check out the build thread on project Lumberjack, that truck is running a 305/40/22 rear tire with Porterbuilt Dropmembers.
Keith
66 Suburban
IG: bennett68c10
Old 10-08-2014, 08:14 AM   #70
resto newbie
Thanks. I'll do so research.
Chad
Old 10-08-2014, 08:20 AM   #71
Bennett68C10
Link to quick description of Lumberjack with pic
http://67-72chevytrucks.com/vboard/s...40&postcount=4
Keith
66 Suburban
IG: bennett68c10
Old 10-08-2014, 05:53 PM   #72
resto newbie
Keith, you have billet aluminum wheels, I have a question. Do they come just polished? Are they also clear coated? If not, what harm would there be to get them clear powder coated right when you get them?
Chad
Old 10-08-2014, 06:16 PM   #73
boostedc10
boostedc10's Avatar
Resto my Intros which are billets came cleared if that helps you any.
Brandon
Instagram: DRVFSTR
Old 10-08-2014, 07:20 PM   #74
resto newbie
Excellent! Thanks. Good news.
Chad
Old 10-08-2014, 10:18 PM   #75
Bennett68C10
My Intros don't have a clear coat on them, just billet and a lot of polishing a lot of the companies have many different finish options now, you might be able to get them with a clear powdercoat straight from the manufacturer. I bought mine from Travis at AZProperformance, he should be able to point you in the right direction.
Keith
66 Suburban
IG: bennett68c10
