Old 04-29-2014, 10:48 AM   #51
-hooch-
-hooch-'s Avatar
Re: The Apache
Originally Posted by -hooch- View Post
Thanks Kim. Well guys, I have questions... I have figured out some about the bags I've got, but I still don't know much. I'm looking for some schooling...
The bags that I got are Ridetech and they are shock waves I believe. They came off a really fancy '40 Ford, but the front ones are taller and the rears are the shorter fatter ones I always see on trucks. So if anyone could tell me if these will work on my set up? (just for reference I've got the '75 el camino front sub frame and not sure about the rear end).
Next question, is there any problem with reusing the entire system or parts of the system? I didn't think there would be with reusing the tank and compressors, but the bags?
Next question, any information on how to make the bag setup work on the front? I have been hearing some applications are bolt in for cars from the 60s, so I was assuming someone makes a bolt in kit for a '75 el camino. Any word on this or anything that would be better?
Next question...questions actually. I have been looking at a lot of trucks around here trying to figure out how to set up the rear end. Obviously there's the porterbuilt rear and others I'm assuming, but are there any systems where I can keep the leaf springs?
Is it just best to do a three or four link? I would like it be as simple as possible (and hopefully somewhat inexpensive).
I would like to keep as much of the bed as possible, so what do you all recommend for this?
I'm sure I have a ton more, but hopefully this will be a good start. My goal is to lay it low, but I don't necessarily care about laying frame. I suppose the end goal would be as low as possible while keeping as much of the bed as possible and maybe keeping the leaf springs? Just help me fellas...
Thought of another question... How low can I go on the front without having to change the inner fenders? I plan on running 20" centerline smoothies.
Any input for these questions? Any sponsors want to chime in either?
Geronimo Build Thread
-hooch- is offline   Reply With Quote
Old 04-29-2014, 11:02 AM   #52
Spblack
Spblack's Avatar
Re: The Apache
post some pics of the shockwaves. I have some for mine up front. they were really easy to fit in. I just had to cut into the subframe to make some room. bolted them to the top of the lower control arm and I was done. if you have the model number, its best to contact ridetech as they sell the adapters.
1959 Chevy Apache (sold)
1958 Fleetside Current
My builds:
http://67-72chevytrucks.com/vboard/s...d.php?t=606412
http://67-72chevytrucks.com/vboard/s...=1#post7560906
Spblack is offline   Reply With Quote
Old 04-29-2014, 11:06 AM   #53
Spblack
Spblack's Avatar
Re: The Apache
and you can use the air shocks in the rear if you take out some leafs, the will act like helper bags. I would notch the rear though to get the lowered look, other wise your gonna hit the axle. just raise your bed floor some. inner fenders will need to be trimmed around the control arms.
My builds:
Old 05-05-2014, 01:37 PM   #54
-hooch-
-hooch-'s Avatar
Re: The Apache
Thanks for the response. As soon as things wind down this next week, I'll be back on this project. This is the best picture I have of my bags right now. Let me know what you all think.
Old 05-05-2014, 01:38 PM   #55
-hooch-
-hooch-'s Avatar
Re: The Apache
There we go...
Old 05-05-2014, 10:02 PM   #56
Spblack
Spblack's Avatar
Re: The Apache
i don't see why these wouldn't work. The rear looks like its already set up for leaf springs (I could be wrong) but id would attempt to take some leafs out and bolt these up and the front should bolt right up. Ride tech sells adapters that should slide into the bottom mount to bolt to the shock mount of the lower control arm. look at the 70-81 Camaro oem shockwaves. you will see what I am talking about.
My builds:
Old 05-05-2014, 10:24 PM   #57
-hooch-
-hooch-'s Avatar
Re: The Apache
Thanks man! I'll see what I can figure out. I think I was just really over thinking it at first. I'm still going to do some more research, but I think I'm getting the basics figured out.
As far as leaf springs, we've already taken some out and it sits low the way it is. I just need to figure out how tall of a notch I need now. How deep was your notch to get it to sit as low as it is?
Then I just need to figure the bed floor situation...
Old 05-29-2014, 01:44 PM   #58
-hooch-
-hooch-'s Avatar
Re: The Apache
Talked to a guy this weekend, and I got some (what sounds like) solid information. Trucks that have some sort of trailing arm suspension can go lower than a leaf spring equipped rear end. Can anyone confirm this, and if so, what triangulated rears do people around here recommend? Or other setups?
Old 08-01-2014, 06:56 PM   #59
JakeDW
JakeDW's Avatar
Re: The Apache
You can use a parallel 4 link with a wats link in the rear that would keep the best pinion angle and keep the wheels centered in the wheel wells.Or a triangulated 4 link would be less work if you do it that way try to make the bars long and about or the same length.
Just wondering if you are going to lay the truck on the frame if you made sure the bottom of the cross was level or higher than the frame.
Cool truck to do.
Jake
JakeDW is offline   Reply With Quote
Old 08-04-2014, 02:04 PM   #60
-hooch-
-hooch-'s Avatar
Re: The Apache
Cool truck to do.
Jake
hey jake!
I will have to take a look at the crossmember.
Sorry for the lack of pics lately, it has been slow. We're down to the bare frame. Right now we are working on the notches, and we have decided on a parallel four link with panhard bar. We figured if we're going to bag it, we might as well put it on the ground.
I have also nailed down a color - velvet green from Volkswagen.
I also finished a really good drawing I hope to turn into a rendering... so get ready! Here's a sneak peek...
Old 08-05-2014, 07:41 AM   #61
made2drag
made2drag's Avatar
Re: The Apache
awesome work...love the detailed pics!
made2drag is offline   Reply With Quote
Old 08-08-2014, 10:02 PM   #62
-hooch-
-hooch-'s Avatar
Re: The Apache
Thanks man! I'll try to get some more up, but first I've got to get some stuff done
Old 08-08-2014, 10:22 PM   #63
-hooch-
-hooch-'s Avatar
Re: The Apache
Alright guys I have more questions:
1) what parallel four links are you guys running?
2) Is there a good place or better brand to get? Possibly a package that comes with all the hardware and panhard bar?
Sponsors you want to chime in?
Also, here's the start of our notch. Any ideas? Criticism? Tips?
Old 08-09-2014, 10:48 AM   #64
Kim57
Kim57's Avatar
Re: The Apache
Looks like it should work to me.
I used a TCI in my build.
Purchased years ago through Currie when I had them narrow my rear end.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-23-2014, 03:02 PM   #65
-hooch-
-hooch-'s Avatar
Re: The Apache
Updates: We got a triangulated four link from airbagit.com. Looks like good stuff!
Got one notch almost completely done, and the other one to come. Moving slow now that school has started. Pics to come soon.
Old 08-23-2014, 06:47 PM   #66
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: The Apache
I was looking through your build again today, and noticed Pic #7 in Post 9. It looks like you cut out a lot of the forward cab mount below the floor. Just thinking you might want to rebuild or replace it.
Looking forward to more progress pic's!
ChuckDriver is offline   Reply With Quote
Old 08-26-2014, 03:10 PM   #67
-hooch-
-hooch-'s Avatar
Re: The Apache
I went back and found what you were talking about. I can't remember exactly, but I want to say we beefed that up when we fixed the floor. I will have to look again though. Thanks Chuck!
Old 09-13-2014, 10:55 PM   #68
-hooch-
-hooch-'s Avatar
Re: The Apache
About time for some updates...
1) we sold the blue 64, so that will get some money coming through for this build. Set of wheels and hopefully most of the paint and body.
2) found a guy locally that seems to know everything about bags, so hopefully he'll come out soon and we'll see if we can get the suspension finished up
3) the rear notches are completely finished thank goodness. Grind and clean them up a little, and then it will be time for the rear end and triangulated four link to turn in.
Without further ado... here's some pics of the notches!
Old 09-13-2014, 11:30 PM   #69
JakeDW
JakeDW's Avatar
Re: The Apache
I like your notch concept.What wheels you going with.
Jake
Old 09-14-2014, 01:13 AM   #70
Kim57
Kim57's Avatar
Re: The Apache
Coming along real nicely.
Kim
My build thread
Old 09-15-2014, 11:20 AM   #71
-hooch-
-hooch-'s Avatar
Re: The Apache
Jake
Centerline smoothies, or maybe if I can swing it the delmo specials.
Old 09-15-2014, 11:21 AM   #72
-hooch-
-hooch-'s Avatar
Re: The Apache
Kim
Thanks! Can't wait to see them cleaned up and painted.
Old 09-15-2014, 11:40 AM   #73
JML55
JML55's Avatar
Re: The Apache
Cool truck
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 10-01-2014, 02:33 PM   #74
-hooch-
-hooch-'s Avatar
Re: The Apache
Originally Posted by JML55 View Post
Cool truck
Thanks JML55.
Ground on the notches, got the rear end set under the frame, and set the bed on top of it all. Pictures to come soon.
Also changed the name of the truck to Geronimo. He was an Apache, so I thought it was pretty fitting. Geronimo means one who yawns, and this will be a cruiser so it fits there too.
Old 10-01-2014, 02:55 PM   #75
-hooch-
-hooch-'s Avatar
Re: The Apache
Pics as promised
Ride height?
Close to aired out?
The notches will definitely let me go as low as I want. Now just need to figure out triangulated rear and crossmember. Then it's time for bags. Just one step at a time...
