02-23-2014, 12:50 PM | #51 |
Re: Easy factory bench to "factory buckets" !
You're a smart muth... Subscribed!
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
02-23-2014, 10:37 PM | #52 |
Great idea, I thought of buying original buckets and buddy buckets just to copy the frame work. The idea of cutting bench seats never crossed my mind. Can't wait to see what you end up with. Great idea!!
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
02-24-2014, 07:41 PM | #54 |
Here are a couple pictures showing the outside seat track lined up with factory mounts and how th inside seat track sits level and easy to mount thru the floor panel .
http://http://http:// Last edited by Grumpy old man; 02-25-2014 at 06:08 AM. |
03-28-2014, 09:17 AM | #55 |
Awesome work! I do have a couple of questions:
1 are you cutting them in such a way that factory bucket upholstery would fit? 2 how much did you remove to achieve the proper width? Keep up the good work!
I may have too many Chevys... Is that possible? 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
03-28-2014, 11:19 AM | #56 |
Any updates on this project? I would love to see the finished product.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
03-28-2014, 11:21 AM | #57 |
I'm in also.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
03-28-2014, 11:40 AM | #58 |
Yeah, What happened?
03-28-2014, 05:52 PM | #59 |
I have been out of town for a family emergency ,And will post more pictures when I return home .
the easiest way to get a good measurement is to remove all the seat material and padding and bolt the seat frame back into the truck use a straight edge to get a line directly down thru the middle of the steering wheel and mark the seat frame once you have that measurement you can measure in on the other side and that should give you the correct amount to remove from the center and still have the seat centered in the middle of the steering wheel reweld the now cut frame and take them to your local upholstery shop for new custom upholstery , no need for expensive replacement foam or covers ! |
04-13-2014, 09:39 PM | #60 | |
Thanks for the info!
04-14-2014, 08:31 AM | #61 |
Subscribed
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
04-14-2014, 08:53 AM | #62 |
subscribed
Being self employed means nobody answers when I try to call in sick. |
04-14-2014, 11:00 AM | #63 |
Subscribed
04-14-2014, 02:06 PM | #64 | |
"Now all I need is a shop to go with my shop vac!" |
04-14-2014, 02:23 PM | #65 |
nice idea!
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
04-14-2014, 02:39 PM | #66 |
nice
04-14-2014, 03:14 PM | #67 |
Genius!!
04-14-2014, 07:58 PM | #68 |
Sweet!
Buckaroo Buckets!
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
04-14-2014, 10:00 PM | #69 |
Sub
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio ..... 1971 CREWMAX Build.....at body shop for couple more years |
04-14-2014, 11:31 PM | #70 |
Subscribed !!! Great Idea !!
04-16-2014, 01:15 PM | #71 |
What is the part number of that dual regulator and what does it fit? I see part of a web site link but nothing beyond the http. Where did you find it, please.
Great thread! |
04-17-2014, 09:05 AM | #72 | |
1. wiring and switch 2. regulator 3. glass 4. water drain system inside the truck 5. regulator mounting brackets 6. window glass run and gaskets 7. very detailed measuring and removal of existing glass supporting metal 8. very confident body working skills 9. the ability to weld without distorting the cab sheet metal 10. The cash and time for such a custom project I have never seen or heard of this being done and plan to be the first but giving away information is what this board is about , if someone else is planning on this mod let me know and we can exchange notes and sources . I will be posting more pictures on the bucket seats later today ! Last edited by Grumpy old man; 04-17-2014 at 10:01 AM. |
04-17-2014, 09:33 AM | #73 |
Welcome back Mr Grumpy old man ,looking forward to more on your plans .
04-17-2014, 09:40 AM | #74 |
Subscribed.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
07-12-2014, 07:26 AM | #75 |
Ok , Well Today I finally have time to get on these seats and start cutting the cab for the power rear window after building several interiors for my friends who are ready for the local shows , I've gathered all the seat and window parts and will be posting heavy pictures on how "I" decided to build them there are always more than one way to skin a cat so add any comments good or bad (I have thick skin ) and we'll see how this all works out , Pictures coming this evening ...
