#51 |
Re: 67-72 C-10 Parts
Any luck finding a headlight ring?
1972 Custom 10 LWB 1973 V8 Vega wagon 1925 Model T Wrecker 1913 Model T Speedster http://s181.photobucket.com/albums/x...07/72skoolbus/ |
#52 |
![]() Join Date: Feb 2008
Re: 67-72 C-10 Parts - Lower Price
67-72 Chevy C-10/C-20 Parts; make me offer...stuff needs to go.
Door Vent Window Assemblies Left and Right - 100.00 for pair Vent Window Gaskets New - 35.00 for pair Rear Glass - 25.00 Trailing Arm for Rear-end with new u-bolts - 100.00 pair SOLD Stock Automatic Cross-member - 40.00 Stock Front Disc Brake Spindles - 40.00 for pair SOLD Brake Booster - 35.00 came off big block truck Disc Brake Proportioning Valve - 35.00 SOLD Fan Shroud V8 with AC - 40.00 Gas pedal with throttle control..rare option 25.00 2 barrel Air Cleaner Assy with riser - 25.00 4 barrel Air Cleaner Assy with riser - 45.00 2 core radiator retainer/upper mount - 10.00 pair 4 core radiator retainer/upper mount - 20.00 pair and other misc parts Last edited by Gulf Rat; 04-02-2014 at 08:49 PM. Reason: lower prices |
#53 |
those arms are for a 1970 C10?
#54 |
Will take them if you take paypal
#55 |
Door Vent Window Assemblies Left and Right - 100.00 for pair Vent Window Gaskets New - 35.00 for pair Rear Glass - 25.00 Trailing Arm for Rear-end with new u-bolts - 100.00 pair SOLD Stock Automatic Cross-member - 40.00 Stock Front Disc Brake Spindles - 40.00 for pair SOLD Brake Booster - 35.00 came off big block truck Disc Brake Proportioning Valve - 35.00 SOLD Fan Shroud V8 with AC - 40.00 Headlight bezels, driver quality - 15.00 Glove compartment door - 50.00 Wiper bottle - 10.00 Gas pedal with throttle control..rare option 25.00 2 barrel Air Cleaner Assy with riser - 25.00 4 barrel Air Cleaner Assy with riser - 45.00 2 core radiator retainer/upper mount - 10.00 pair 4 core radiator retainer/upper mount - 20.00 pair and other misc parts Last edited by Gulf Rat; 04-02-2014 at 08:48 PM. |
#56 |
Recived the brake lines today. Thank you!
Also do you still have the E brake assembly you have pictured? |
#57 |
#58 |
![]() Join Date: Mar 2014
Do you have a pic of lower control arms. thanks
#59 |
#60 |
![]() Join Date: Oct 2012
Is the fan shroud for small block or big block, from pic looks like small block.
Thanks |
#61 |
#62 |
hi,you still have the Trailing Arm for Rear-end and Stock Automatic Cross-member, also the control arms.. If you do please PM me thanks..
#63 |
Door Vent Window Assemblies Left and Right - 100.00 for pair Vent Window Gaskets New - 35.00 for pair Rear Glass - 25.00 Trailing Arm for Rear-end with new u-bolts - 100.00 pair Sold Stock Automatic Cross-member - 40.00 Stock Front Disc Brake Spindles - 40.00 for pair Sold Brake Booster - 35.00 came off big block truck Disc Brake Proportioning Valve - 35.00 Sold Fan Shroud V8 with AC - 40.00 Headlight bezels, driver quality - 15.00 Glove compartment door - 50.00 Wiper bottle - 10.00 Gas pedal with throttle control..rare option 25.00 2 barrel Air Cleaner Assy with riser - 25.00 4 barrel Air Cleaner Assy with riser - 45.00 2 core radiator retainer/upper mount - 10.00 pair 4 core radiator retainer/upper mount - 20.00 pair and other misc parts Last edited by Gulf Rat; 04-02-2014 at 08:47 PM. |
#64 |
btt....check it out
#65 |
Are your spindles for hd 1.25 rotors or the 1 inch and is brake valve for disc drum or disc disc
#66 |
Are your spindles for 1 1/4 ROTORS
#67 |
How much can you do the booster for shipped to 08854?
#68 |
still have the 4 barrel air cleaner and spacer and hose?
I will take it if so. thanks, james@endeavorcustomhomes.com can do paypal.
![]() 70chevytruck |
#69 |
#70 |
Pic of Trailing Arms and Spindles
#71 | |
Still got air cleaner, PM me with zip |
#72 |
Interested in the small block fan shroud......shipping to 07838 ??
#73 |
#74 |
Door Vent Window Assemblies Left and Right - 100.00 for pair Vent Window Gaskets New - 35.00 for pair Rear Glass - 25.00 Trailing Arm for Rear-end with new u-bolts - 100.00 pair Sold Stock Automatic Cross-member - 40.00 1971 C-10 Stock Front Disc Brake Spindles - 40.00 for pair Sold Brake Booster - 35.00 came off big block truck Disc/Drum Brake Proportioning Valve - 35.00 Sold Fan Shroud V8 with AC - 40.00 Headlight bezels, driver quality - 15.00 Glove compartment door - 50.00 Wiper bottle - 10.00 Gas pedal with throttle control..rare option 25.00 2 barrel Air Cleaner Assy with riser - 25.00 4 barrel Air Cleaner Assy with riser - 45.00 2 core radiator retainer/upper mount - 10.00 pair 4 core radiator retainer/upper mount - 20.00 pair and other misc parts Last edited by Gulf Rat; 04-05-2014 at 09:56 AM. |
#75 |
Cab corners and rocker bits still available?
