Old 08-17-2014, 08:36 PM   #51
Mikes66ChevyC10
Mikes66ChevyC10's Avatar
Re: Mike's 66 C10 Short Step Build
Haven't posted in a while but I have been working on the truck here and there and got a lot done! Going together pretty good. Mounted up the door and the door gaps were great considering I had everything cut out. The hole for the body mount was in the wrong spot in the new floor pan so I cut it out and welded in a new piece. I'll drill up from the bottom of the body mount to make the new hole. Lots more welding and grinding to do!! LOL
1966 C10 Stepside swb
http://67-72chevytrucks.com/vboard/s...d.php?t=617778
Mikes66ChevyC10 is offline   Reply With Quote
Old 08-17-2014, 10:17 PM   #52
Bomp
Bomp's Avatar
Everything lined up nice and straight on the sheet metal work.
Lot of good work there.
Bomp is offline   Reply With Quote
Old 08-18-2014, 04:44 PM   #53
Mikes66ChevyC10
Thanks!
Old 08-18-2014, 05:13 PM   #54
step65
Awesome job on the sheet metal work looking forward to watching your progress.
step65 is offline   Reply With Quote
Old 09-21-2014, 08:37 PM   #55
Mikes66ChevyC10
Pass Side just about done. Started on the Drivers side today. Can't wait to get the cab done so I can start on the fun stuff this winter!!
Old 09-21-2014, 08:42 PM   #56
bj383ss
bj383ss's Avatar
Looking good man. I here you on finishing the cab. I almost have mine done. The roof and the back wall and then it is ready for some paint. I welded my gas tank brackets back in this morning.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 09-21-2014, 08:47 PM   #57
Mikes66ChevyC10
So after cutting out the "Patch" the original owner welded in under the pedals years ago to cover up the rust this is what I found. Believe it or not there is actually less work on the Drivers side then there was on the Pass side. I've learned a lot so the DS should go a lot faster.
Old 09-21-2014, 09:05 PM   #58
Mikes66ChevyC10
Bret
Thanks! I don't mind working on the cab but I'd much rather be working on the suspension, and the drivetrain. I'll be removing my gas tank brackets as I'm relocating the tank to the back. I have a very small patch I have to make to the back wall of my cab on the very bottom.
Old 10-26-2014, 08:41 PM   #59
Mikes66ChevyC10
Rust repair is almost complete on the cab. Still have to finish the lower A pillar patch and lots of grinding to finish off the welds. Can't wait to start on the fun stuff!!
Old 10-27-2014, 03:16 PM   #60
timmytimm3
Nice work.
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 10-27-2014, 04:54 PM   #61
Bigru
Bigru's Avatar
X2
1965 Short Fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=637478
1983 Short Fleet (Under construction for my 13 year old son)
2008 GMC Denali
2012 Harley Roadglide
Follow me on Instagram: Ru_django
Bigru is offline   Reply With Quote
Old 10-27-2014, 07:14 PM   #62
Mikes66ChevyC10
Thanks guys!
Old 10-27-2014, 09:38 PM   #63
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Very nice work!
So glad to be past all of that!
Modges'66 is offline   Reply With Quote
Old 11-01-2014, 07:28 PM   #64
Mikes66ChevyC10
My boy wanted to help me wire brush the frame on our C10 but he's a little too young yet. LOL He loves "his" truck!
Old 11-02-2014, 08:41 AM   #65
Bomp
Bomp's Avatar
Start'em young I say!
Looking good
Old 11-23-2014, 11:57 AM   #66
Mikes66ChevyC10
It's been almost exactly 10 months now in the build of my C10. Cab is structurally sound now. The bracing I welded in at the start of the cab repair can now be removed!!
Old 11-23-2014, 08:17 PM   #67
bj383ss
bj383ss's Avatar
Looks great Mike!
Old 11-23-2014, 09:36 PM   #68
Mikes66ChevyC10
Looks great Mike!
Thanks bud!!
Old 12-06-2014, 09:05 PM   #69
Mikes66ChevyC10
Support bracing all removed. Also removed all the wiring, steering column, and gauge cluster from the dash. Lots more work to do yet. Have to remove the gas tank mounts and lots of sanding.
Also pulled the engine and trans! My boy helped me pull the engine. This was his first time pulling an engine. He did a great job! We made a mess though... Here are some pictures.
Old 12-07-2014, 12:13 PM   #70
62 Barnfind
62 Barnfind's Avatar
Good job on the metal work!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 12-07-2014, 12:59 PM   #71
LT1 Burb
LT1 Burb's Avatar
Looks good, glad those parts helped you out,
LT1 Burb is offline   Reply With Quote
Old 12-08-2014, 07:54 PM   #72
Mikes66ChevyC10
Thanks guys!!
Yep LT1 Burb those parts made the job a lot easier!
Old 12-08-2014, 10:07 PM   #73
CRGRS 66
CRGRS 66's Avatar
Subscribed, nice work on the panels!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 12-09-2014, 03:50 PM   #74
rareform
I love the work you have done here....I have a very similar project as far as the rotted floors and rockers. Everybody always asks, so I'll be THAT guy who made your patch panels??? Any additional problems with fit aside from the holes in the floors??
rareform is offline   Reply With Quote
Old 12-09-2014, 07:17 PM   #75
Mikes66ChevyC10
Thanks again guys!!
Rareform all the panels came from Top Banana in Va. I have had good luck with them. All the parts they sell are also Keyparts. The only real fitment issue was the body mount holes and the holes where the support braces bolt to the lower A pillar. I had to replace the bottoms of the A and B pillars on both sides so I was able to make everything work and just opened up the bolt holes. http://www.topbananaparts.com/
Just be sure to take your time and take measurements before you start cutting. If yours needs as much rust repair as mine I would consider welding support bracing inside the cab to keep it square. If you have any other questions feel free to ask!
