#51 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Trailing Arm Mounts
I will be on vacation from 08-08-16 thru 08-25-16. If you wish to make a purchase you can post here in this for sale thread, send me a PM or an email to captainfab454@hotmail.com. I will reply to your inquiry when I return on the 25th. I do currently have a list of orders to build and ship when I return but I will add your name to the list in order of when received. Thanks for your understanding.
#52 |
60-66 Nut
I now stock trailing arm mounts for the 3.250" axle tubes found on some Ford 9" differentials.
#53 |
![]() Join Date: Jan 2015
I'll take a set of these trailing arm mounts for a 14 bolt. Please watch for a paypal payment of $68.60. Thanks
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
#54 |
60-66 Nut
Payment received and PM replied to. Thanks for the purchase
#55 |
![]() Join Date: Sep 2017
intrested in 10 bolt trailing arm mounts .. thank you
#56 |
60-66 Nut
I replied to your PM.
#57 |
60-66 Nut
I have the u-bolts back in stock again.
#58 |
60-66 Nut
I am officially notifying everyone that I will be on vacation from 02-05-18 thru 02-13-18. I will do my best to get all orders built and shipped before I leave, if placed by 01-31-18. Orders placed while I am gone will be built and shipped in order of receipt of payment once I return. Thanks for understanding.
#59 |
![]() Join Date: Oct 2017
PayPal sent for a set of brackets. Thanks again
“You boys like Mex-I-co?? Wooo-hoo!!” ![]() 91’ Camaro - 5.3/th400 project “street car” 62’ C10 swb fleetside..soon to be 5.3/4l60 04’ Silverado Z71 15’ Accord Sport |
#60 |
60-66 Nut
Payment received, Thanks
#61 |
Sent you a pm. I also need a set of bolts in addition to the coil pads please. Thanks brother!
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#62 |
60-66 Nut
#63 |
60-66 Nut
Here is one of the threads here on the forum that shows in detail how to weld on trailing arm mounts at the correct angle on a leaf spring differential.
http://www.67-72chevytrucks.com/vboa...d.php?t=624445
#64 |
Do you make anything to adapt the trailing arm u-bolt holes/mounts on the C20
with an HO 52 when swapping in a 12 bolt with a smaller axle tube? |
#65 |
60-66 Nut
The spacing of the U-bolt holes thru the trailing arms are the same whether they are under a C10 or a C20. So absolutely nothing special required. If you need a set of trailing arm mounts for a 12 bolt, I have those.
#66 |
Maybe I'm not seeing something clearly but the axle tube on the HO52 is bigger than the axle tube on the 12 bolt. Accordingly the U-bolts and corresponding trailing arm holes are wider than the 12 bolt axle tube. Right?
#67 |
I suppose it's not critical if the U-bolts and holes are wider if the mount cutout is the correct circumference for the 12 bolt. Is that how you see it?
#68 |
Do you make panhard bar mounts as well?
#69 | ||
60-66 Nut
As I said above.....the trailing arm holes for the u-bolts are the same spacing whether they are for a C10 or a C20.....no difference. I have made and sold a lot of trailing arm mounts and they all have the same u-bolt hole spacing.
No I do not yet make a panhard bar mount. I have been trying but working 80 hrs/7 days a week every week every month doesn't leave much time to develop new products. Quote:
#70 |
60-66 Nut
Due to an increase in the cost of having my parts laser cut, I have been forced to raise my prices. I'm not making any more money, just trying to stay in business with these increases in my costs. Thanks for understanding.
#71 |
on a h052 Swap to 14 ff 72 c20 rear coil truck will the truck arms need the hole moved for a wider axle tube fit ?
#72 |
60-66 Nut
No the holes remain exactly the same as original. With the 14 bolt, there needs to be a slight groove put into the axle tubes on both sides so that the u-bolts will pass by and line up with the holes. This groove does not need to be more than probably 3/4" long. The 14 bolt axle tubes are 3/8" thick, so this does not present an issue.
I do now offer a panhard bar mount for the 14 bolt.
#73 |
Hi I’m in need of a set of perches for an HO52/72 axle. If you can give me a lead time and an email for payment, I’d like to get a set on the way
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
#74 |
60-66 Nut
PM sent.
#75 |
60-66 Nut
Here is a link to my new website and online store where you can see and purchase all of the products that I fabricate for the '60-'72 GM trucks.
https://customfab-cda.com
