#51 |
Re: 1970 C20 long bed Duramax, Allison, on a 2003 4x4 chassis
Installed AC, battery trays, inner fenders, ECM, fuse block, master cylinder, inner coolers, trans coolers, headlight buckets..
1970 Chevrolet + 2003 GMC Duramax 4x4 = Awesome |
#52 |
#53 |
#54 |
Installed BOLT lock cylinder into door to use new style ignition key vice multiple keys.
#55 |
Final metal work and prep of cab and primer
#56 |
2 coats DP 50 epoxy primer followed by K36
#57 |
#58 |
Install bed
#59 |
Primer bed this weekend then complete tear down to start painting firewall and jams.
If anyone wants to see anything more specific in detail just let me know.
#60 |
Upholstery is out being covered in custom leather
#61 |
I'm just glad to be here!
Very nice. The chassis looks great. I like how you used a lot of the interior controls switches and custom mounted them in the steel dash.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#62 |
Thanks. It makes using the 2003 wire harness easier because except the vintage AC unit everything else is direct plug in so should have hopefully very little issues.
#63 |
Loving it! Way to make it your own, or how GM should have made one! Good luck on meeting your deadline, I have faith you will do it, came along ways in fairly short time compared to some projects, especially mine.
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
#64 |
Resident Lurker
One word comes to mind...MORE!
The Rotten Mule: '72 Chevy Short Step Project- http://67-72chevytrucks.com/vboard/s...d.php?t=417252 "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats."- H.L. Mencken |
#65 |
Primered the bed this morning. Finally it's all one color again.
#66 |
#67 |
unbelievable
gotta be all Photoshopped ![]()
'68 C10 SWB '85 K30 Blazer |
#68 |
Looking real good!
#69 |
Made bumper brackets and fit the rear bumper. Working on the hitch now.
#70 |
#71 |
Subscribing.. Love the project!! How's the wiring going so far?? This is a dream project of mine..
61 apache |
#72 |
And now we have a hitch. Lots of cutting and reinforcing on the 2003 hitch to get it back and under the license plate holder.
#73 |
The wiring so far has bee no issue. The way I'm doing this project I am retaining all of the 2003 wire harness and using all of the 2003 components so it remains plug and play. The only thing that I need to Separate off the wire harness is the AC unit. This all required more fab work to fit all the 2003 components and wiring into the body but it retains all the functions. I think I'll have the only 70 Chevy with air bags. Lol
#74 |
Did you use the factory intercooler/ radiator and everything off the 03? I guess it all fit between the grill and fan?
61 apache |
#75 | |
I'll post lots of pics during assembly once I take it apart to paint jams and firewall.
