06-22-2014, 03:27 PM | #52 |
Re: 1971 k30 LS3 500hp 4l80e, 205, Dana 70f, 14bff,
Thank you nlped, I agree.
06-22-2014, 04:18 PM | #53 |
That would be very nice!
Here is a concept ride for my dogs of a 4x4 converted 1-ton frame, under a panel with the 133" wheelbase, resulting in a short rear overhang. It really needs a Con-Ferr Porthole to finish it off though.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 06-22-2014 at 08:37 PM. |
06-22-2014, 04:26 PM | #54 |
Tim that is sweet looking
06-22-2014, 07:14 PM | #55 |
What is a ConFerr porthole. I dont recall ever hearing about one.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
06-22-2014, 08:28 PM | #56 |
Sorry to be cryptic. Con-Ferr was a big off road parts supplier here in Burbank, CA. One of their signature products was the HD porthole roof rack. So named for the round holes in the upright plating.
They are long gone as a company but the racks live on as Diamonds. http://www.diamondrax.com/
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 06-22-2014 at 08:36 PM. |
06-22-2014, 08:31 PM | #57 |
I was off in dog land thinking of those windows for the dog to stick his head through
06-22-2014, 08:59 PM | #58 |
I was thinking it was a hole for the dog too... Lol
06-22-2014, 09:02 PM | #59 |
I will have to see if the 73-87 suburban full size safari rack will fit the 71 burb as I have one.
06-22-2014, 10:34 PM | #60 |
The 1971 burb as a k30 with full length safari roof rack, 6" lift, 35" bfg's, a snorkel, rock grinder front and rear bumpers and rock grinder side bars. With my k30 running gear... Bad to the bone!!!!
06-22-2014, 10:53 PM | #61 |
. This not my truck, but this is very much like I would want one.
06-23-2014, 02:35 AM | #62 |
Funny. I remember those racks, and the shackles they made from back when i could only think about kaiser trucks with buick engines... but in this case I was scratching my head (since I forgot about those racks) thinking "i dont recal con-ferr making portal axles"
Btw this thread has a lot of good ideas in it. Thanks for posting. And I would love that burb/panel in a 69 70 M/Y.
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" |
06-23-2014, 03:16 AM | #63 |
Good enough starting point for you?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
06-23-2014, 03:29 AM | #64 |
Yes I would start with that... But I'm poor... Lol
06-23-2014, 03:32 AM | #65 |
Tim, I too am a dog lover. Very Sorry to hear your husky is missing. Godspeed to you and your dog.
06-23-2014, 10:46 PM | #66 |
more parts came in over the wkend. I will start posting pics of them soon
06-25-2014, 03:06 AM | #67 |
06-25-2014, 03:07 AM | #68 |
06-25-2014, 07:40 AM | #69 |
I have the 14bff with disc conversion already... But ran across a Dana 70hd rear srw with my same gear ratio 4.10 for 100.00. I have read the specs on both and the 70 is a bit beefier but 14bff are plentiful and cheap too. Any thoughts? Yes the 70 will cost me a grand by the time you put new spicer bearings seals and Detroit in it. I would reuse the disc kit from the 14b and just make new brackets from some .500 but then I would have dana 70's front and rear. Any thoughts?
06-25-2014, 08:24 AM | #70 |
It would sure be beefy, but isn't the 14 already ready to roll? Maybe you could sell it and make back some of your $ to build the rear 70?
06-25-2014, 12:55 PM | #71 |
Dana 70hd, 4.00" axle tubes, .500" thick, axles 1.500" thick no neck down, 35 splines, pumpkin is 15/16" thick walled.
06-25-2014, 01:20 PM | #72 |
Vintage 4x4s
As far as the gears go, the eaton HO52 is stronger than the 14 bolt and a standard dana 70 but not sure about the HD. Its hard to beat the eaton pinion bearing support design but that 70HD sure seems nice and the way to go if you have huge payloads but not huge torque. It has the beefy tubes. At least with standard 70,s the weak point seems to be the gears. There is a thread on pirate4x4 that really made me respect the HO52/72 even more. They concluded the HO52 was stronger, lighter, better ground clearance than the 14 bolt ff. Ive got a Dana 70 here with destroyed gears that was in a 90 stockish cummins. Dodge abandoned the 70 and went up to the 80 in later years as the disel torque got crazy. If the gears arent stronger than a reg duty Dana 70, I,d stick with the 14bff or HO52. Id still buy that HD 70 since the price is so good! Any way you go, they,re all good axles for a gas application. Just my opinion.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 06-25-2014 at 01:26 PM. |
06-25-2014, 01:55 PM | #73 |
For inspiration, a while back there was this Suburban for sale on eBay. IIRC, it was sporting 1 ton drivetrain.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
06-25-2014, 06:33 PM | #74 |
bigdave that is bad to da bone!
06-26-2014, 10:49 PM | #75 |
. Made a deal on this today... Supposed to pick it up Sunday. 1971 3/4 ton k20 4x4. 350, th350, np205, Dana 44 front, ho52 rear.
