Old 09-21-2014, 05:30 PM   #51
rusty76
rusty76's Avatar
Re: Low buck? More like no buck. The poor mans build.
Looking good.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 09-21-2014, 10:39 PM   #52
twangismythang
twangismythang's Avatar
Really liking your build, I was thinking earlier today that I might go with the white wagon wheels. May be cheaper and easier to find then the steelies.
Victory will only be achieved through superior firepower and trusting in the Lord.
SOLD 68 C-10. http://67-72chevytrucks.com/vboard/s...d.php?t=560975
SOLD 2000 Silverado...http://67-72chevytrucks.com/vboard/s...=1#post6492671
87 V-10 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=643898
twangismythang is offline   Reply With Quote
Old 09-27-2014, 12:44 AM   #53
Just call me Sean
Just call me Sean's Avatar
Having issues with the way it runs, been messing with it today. I wanted to check the fuel pressure, but it requires a special adapter. $60 for a gauge I don't need but with the adapter. I would rather put a new pump in the tank that doesn't work and test it that way, that's $50. I did neither. I attempted to gather parts to make my own test port. I was unsuccessful. It was raining all day anyways, couldn't pull the tank. I put a high concentrate of Seafoam in the gas, maybe it will help. Had a grounding issue also so I added another battery cable from the battery to engine. Can't have too many grounds. I have to check for codes again, see if anything came up.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 09-27-2014, 06:45 PM   #54
rusty76
rusty76's Avatar
Hope you get it figured out. Sometimes it's the small things....grrrrr.
My build thread
Crossmembers CC
Old 10-06-2014, 10:52 PM   #55
Just call me Sean
I pulled the passenger tank today. The rubber hose that connects the pump to the pickup was mush, so even if it did pump it wouldn't make it to the injectors. Tested the pump, it worked. Pulled apart the tank selector switch and cleaned the contacts, now it was getting power. Put a piece of fuel hose on the pump with some clamps and put it back in. Put it all back together and went to the gas station to put some gas in. The truck has two working tanks now, only cost me $3 for clamps and $9 for a strainer, the old one was toast. The gas gauge doesn't work the greatest (it's on the list) but it appears to register each tank. They both have about the same amount of gas in them right now. I have to test drive more to see if it runs differently on each tank to see if the other tank may have a problem.
Old 10-06-2014, 11:00 PM   #56
y5mgisi
Second Chance Program
y5mgisi's Avatar
Nice!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-06-2014, 11:38 PM   #57
twangismythang
Great progress, I have to drop both of mine also.
Old 10-07-2014, 04:53 PM   #58
rusty76
rusty76's Avatar
Sounds like you are making progress!
My build thread
Crossmembers CC
Old 11-01-2014, 08:41 PM   #59
Just call me Sean
I was getting tired of seeing wires and an ugly cut hole so I made a radio delete plate. I was making pieces for my conversion van so I made it while I had everything out.
Old 11-09-2014, 10:21 AM   #60
Just call me Sean
I touched up the paint around the plate so it looks better.
Old 11-09-2014, 07:29 PM   #61
rusty76
rusty76's Avatar
Looks mucho better.
My build thread
Crossmembers CC
Old 12-12-2014, 02:52 PM   #62
Just call me Sean
Finally got the damn thing running well. Had fuel leaking around the injector. Fixed that and it was back to running odd. Turns out the throttle body base gasket was leaking, found it with carb spray. Changed the regulator too as it came with the throttle body rebuild kit I had to buy. $30 fix for a long annoying problem.
Old 12-16-2014, 12:12 AM   #63
Just call me Sean
Sold it. Oh well, still have the '83.
Old 12-26-2014, 01:55 AM   #64
Hankster
Hankster's Avatar
Can I ask why you sold it?
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 12-26-2014, 02:13 AM   #65
Just call me Sean
I'm buying a house and wanted to have some extra cash on hand just in case I needed it.
If anyone's curious I sold it for a grand.
Old 12-26-2014, 02:17 AM   #66
Hankster
Hankster's Avatar
Oh ten four! Well good luck on your house!
Current Build
Old 12-26-2014, 02:27 AM   #67
Just call me Sean
Thanks. It's been ten months but it's finally supposed to happen by the 23rd.
I did keep the one with the good body. I'll have to start a build thread on it when I start doing stuff to it.
Old 12-26-2014, 10:18 AM   #68
rusty76
rusty76's Avatar
Congrats on the house and keep us posted up.
My build thread
Crossmembers CC
