Old 09-02-2014, 09:33 AM   #51
Keith Seymore
Keith Seymore's Avatar
Re: Lowest production/serial number
One additional thought: I believe the number you all are imagining is the "PVI" (Primary Vehicle Indicator"), or the GA (General Assembly) Sequence number (sometimes called the manifest sequence number).
THAT is the number that increments up by one, in order, for every vehicle produced.
Said differently, the VIN is NOT the primary tracking number in the assembly plant. It is a part to be installed, just like a tune up label or a Mulroney window sticker. The PVI or GA sequence number is the primary way that a vehicle is tracked through the build.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-02-2014, 10:24 AM   #52
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
K
Good info. Are the PVI or GA numbers on the build sheet? I suppose thats our only hope of getting them?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 09-02-2014, 11:09 AM   #53
Keith Seymore
Typically - yes. (May vary by plant).
Attached below are a Fremont sheet, and a Baltimore sheet. The upper left corner indicates a "Job sequence number".
I wish I had saved the build information when I followed my red truck down the line. It was sequence number "87" as indicated by the crayon markings on the grille, rad support, fenders and hood; (I didn't even think of the missed opportunity until just a year or so ago).
K
1979-1986
1986 - 2019
Old 09-02-2014, 11:31 AM   #54
Keith Seymore
I thought I had mentioned this here, but apparently not:
For those wishing to go deeper the Camaro Research Group has an excellent overview of '67-'69 F car production, located here:
http://www.camaros.org/assemblyprocess.shtml
I have had no motivation to do a similar write up because this one is so well done (and because there are so many similarities to truck production).
K
1979-1986
1986 - 2019
