Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Closed Thread
Old 11-11-2014, 11:15 AM   #51
wayno
Re: 67-72 Chevy Truck fuel gauge diagnostics 101
fantastic write-up TBone.. now if I can get you to do a similar write up for TACHs lol
64 Step Side - The Mistress
wayno is offline
Old 11-11-2014, 12:27 PM   #52
jjzepplin
jjzepplin's Avatar
Oh yeah! I'm in for that too!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline
Old 11-14-2014, 03:04 PM   #53
TBONE1964
Cluster King
TBONE1964's Avatar
I am slowly working on getting the tools together to help me diagnose the factory tachs and figure out a way to repair them. I can currently fine tune the calibration and check function but no repair yet.
I have heard about some aftermarket kits that replace all of the insides to a modern style tachometer but allow the tach to look original.
I am always looking for ways to help people out with these things but limited to what I can invest.
I will always keep everyone updated with new developements.
Take care and have a good weekend,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline
Old 11-23-2014, 06:20 PM   #54
jjzepplin
jjzepplin's Avatar
So I went and filled it up today. Bad news. Reads just over 1/4 tank. More than before but dagnabit! And as an added bonus now it burps gas upon fillup again for some stupid reason. SHAZAM! On the other hand the new front sway bar makes it ride fantastic. Think a rear is on the way.
I did not do any testing yet but will keep you all posted.
Old 11-23-2014, 06:28 PM   #55
TBONE1964
Cluster King
TBONE1964's Avatar
Man, you sure are having the luck with this. I would bet the fill hose is kinked somewhere, maybe?? That would cause burping problem.
Do you have another fuel or temp gauge laying around? If so, change the resistor with your current one on the back of the fuel gauge. If you do not have one, PM me your address and I will ship you one. A bad resistor can cause the 1/4 tank issue. If you can, ohm check the resistor removed from the fuel gauge. It should be around 100 ohms give or take a few. Don't worry about the color code on them. I have all different colors of these, red, orange, yellow and blue and they all ohm check around 100 ohms.
If I don't hear back from you, have a great holiday. Keep me posted,
Take care,
Tom
Old 11-23-2014, 09:00 PM   #56
jjzepplin
jjzepplin's Avatar
Have a great holiday yourself sir. And I will as well. I checked the gauge against the sender before installing and all checked out. I am thinking there is some sort of baffle in the tank that is interfering with the float or something. ARGH! AHJKVP*OTUDYHVBO{U"FJLGBULJF!!!!!!
Old 11-23-2014, 10:10 PM   #57
undertaker72
undertaker72's Avatar
tom, excellent tutorial thanks for your time in posting , and the others that have chimed in , this is what make this site better than the books super job
undertaker72 is offline
Old 11-23-2014, 10:18 PM   #58
TBONE1964
Cluster King
TBONE1964's Avatar
Originally Posted by undertaker72 View Post
tom, excellent tutorial thanks for your time in posting , and the others that have chimed in , this is what make this side better than the books super job
Thank you very much Kevin. It is my pleasure to be able to help someone diagnose there issues. Sometimes these things can throw us for a loop and we need to break it down and diagnose it, piece by piece. Sometimes it takes a lot of patients but I believe most of us have the ability to fix there gauge issues with some pointers.
I also appreciate all who chime in with there own experience and yes, it is not always reading the books that we get the most help from. I learn a lot myself from the members on this forum and that is one of the things I love about being a member.
Take care and have a great holiday,
Tom
Old 11-26-2014, 12:54 PM   #59
jjzepplin
jjzepplin's Avatar
Allrigty. Went out and tested the sender today to find it is reading 90 ohms-hmm. Went inside the cab and pull the sender wire and it reads 90 ohms- hmm. Pulled what I thought was the ground clip for the gauges and nothing happened to the gauge.
Is there more than one ground clip?
This gauge and sender tested fine out of the tank. Why would it be any different inside the tank?
The only difference I can find is the tank sender ground was a jumper wire.
I have a ground wire on the tank that previously was not hooked up but it is now.
Sound like a ground issue?
Old 11-26-2014, 01:13 PM   #60
TBONE1964
Cluster King
TBONE1964's Avatar
JJ,
The tank is full? If you are reading 90 ohms testing the sender, that would tell me the tank is full and the float is up all the way. If you were reading 22.5 ohms, then I would say the float is stuck at 1/4 tank or the sender is not working correctly
The little ground clip for the cluster is just an extra ground as a back up. The ground for the cluster is in the connector I believe with out looking it up is in the number 7 location. It is a black wire.
If you have a ground issue at the cluster, the temp gauge and/or lights would not work correctly. They all share a common ground.
What will happen now if you hook your jumper ground back up? Try it and see what happens. Are you still reading 1/4 tank? That would indicate to me that your ground is good. If you pull ground, the gauge should roll over to 3 o clock.
Keep us posted and have a good holiday,
Tom
Old 11-26-2014, 01:27 PM   #61
jjzepplin
jjzepplin's Avatar
The tank is indeed full.
The ground clip removed does not change the gauge reading.
Maybe pull the big cluster plug and jiggle around?
I am going to try the jumper wire at the tank.
Is that what you mean?
I tried the ground clip to a known ground and nothing.
Old 11-26-2014, 01:37 PM   #62
TBONE1964
Cluster King
TBONE1964's Avatar
Are you talking about the ground clip near the cluster? It is always good to have it hooked up but I don't think it is related to your problem.
Yes, the jumper ground at the tank but like I said, If you have a bad ground there, that will make the gauge read past full.
It sounds like you have confirmed the sender is good and the test worked.
Do you have another loose fuel gauge with the resistor on it? If you do, try to give it 12v and a ground and unplug the tan wire from the fuse panel and hook it directly to your other gauge and see what that gauge does. This is going to tell you if the gauge resistor is keeping the gauge from reading past 1/4 tank. Let me know if you need help figuring out where to hook the jumpers on the back of the gauge.
I know this is a PITA but think you have/had multiple problems with your fuel gauge not reading correctly.
Old 11-26-2014, 01:38 PM   #63
jjzepplin
jjzepplin's Avatar
I put a jumper on the tank ground and tested it with the meter to make sure it was grounded and still no change.
I am thinking it is a ground issue somewhere though.
Am I right?
Old 11-26-2014, 02:11 PM   #64
jjzepplin
jjzepplin's Avatar
Tested two unknown gauges with jumpers and both read full.
Cluster in truck might be the issue.
I pulled the main cluster plug and put jumpers on the gauge in the cluster and same reading as before. Not full.
Must be the gauge even though it tested good right before I replaced the sender.
Sumbeotch.
Old 11-26-2014, 02:20 PM   #65
TBONE1964
Cluster King
TBONE1964's Avatar
Sumbeotch.
I feel a celebration coming soon. Although you will need to pull the cluster again. While it is out, take a good close look at the circuit board as well and also where the connector plugs in. Make sure there are no burn spots and the tabs where the connector plug in are all in place. You can use super glue on those if they are loose.
I will be waiting for a big YEEEEEEEHA
Old 11-27-2014, 02:07 PM   #66
jjzepplin
jjzepplin's Avatar
Ok so I pulled out the cluster and checked the gauge removed. Tested perfect. Right up to full and no further.
Swapped out the printed circuit and checked again.
Right to the full mark and no further.
Cleaned all the harness contacts and plugged in.
Checked out good.
Almost YEEHHAAA!
Installed completely and checked. Goes over full (further than ever before).
Not much maybe 1/8 tank or so.
I guess I will drive around with a gas can till I can confirm
the levels. I know it is way full right now and has maybe 3-5 gallons before it should start registering anything on the gauge.
But it is NOT at the lower end of the gauge which is where it has spent most of it's years.
If I disconnect the sender wire it acts as it should.
Thank You so much and I hope this helps someone.
Will keep you all posted with long term results.
Happy Thanksgiving!
Old 11-27-2014, 02:22 PM   #67
TBONE1964
Cluster King
TBONE1964's Avatar
Checked out good.
Almost YEEHHAAA!
Happy Thanksgiving!
Sounds like the chapter is going to end soon. Go have some Turkey and relax.
You have a good Thanksgiving as well JJ,
Take care,
Tom
Old 11-27-2014, 04:05 PM   #68
jfultz1971
Where can you buy the resistor? My sons truck is a 72 c20. All new complete wire harness and fuel gauge and sending unit complete.
jfultz1971 is offline
Old 11-27-2014, 04:09 PM   #69
TBONE1964
Cluster King
TBONE1964's Avatar
I can help you with your needs. I will send you a PM (private message) after the holiday and we can discuss exactly what you need.
Have a good holiday,
Tom
Old 11-27-2014, 04:14 PM   #70
jfultz1971
Ok, sounds good. Thanks, happy gobble gobble.
Old 12-07-2014, 03:44 PM   #71
jfultz1971
Never got a pm from you, on resistors.
Old 12-07-2014, 03:56 PM   #72
TBONE1964
Cluster King
TBONE1964's Avatar
My apologies. PM coming right up.
Thank you,
Tom
Old 12-30-2014, 07:30 PM   #73
Fasteddieb
Best fuel gauge explanation anywhere. Just got a 69 c10 and it had fuel gauge issues. Turn the key on and the needle went straight to full - and past! Bed mounted fuel cell made things a LOT easier. Took out the sender and it read way over the ohm range. problem is, there was an aftermarket fuel gauge in the dash. Did the PO get the 0 to 90 ohm version? I dunno!
Then I had a brain flash. Went to Radio Shack and purchased a 47 ohm resistor. Hooked it up between the sending wire and ground and turned on the key. Needle went right to 1/2 tank!
Ordered a 0 to 90 ohm sender yesterday. I'll have a working fuel gauge by the weekend!
Thanks guys!
Now I need to work on my wiper motor. It's always something!!!
Fasteddieb is offline
Old 12-31-2014, 08:13 AM   #74
jjzepplin
jjzepplin's Avatar
Checked out good.
Almost YEEHHAAA!
Happy Thanksgiving!
Update-so far gauge is functioning. Now on to that tachometer since you were so nice s to furnish some much needed parts. Thank You!
Old 01-01-2015, 09:51 PM   #75
zicc1835
zicc1835's Avatar
subscribed
zicc1835 is offline
Closed Thread
