10-31-2014, 02:03 PM | #51 | ||
Re: Another fuel economy check with my '65 one ton
The 14 bolt is a common rear end to swap in for people that want taller gears than 4.10:1. |
11-02-2014, 01:12 AM | #52 |
Okay, I took some video of the truck running with the new tach, and posted on youtube:
Video 1 - Just fired it up, cold; adjusting the choke Video 2 - Revving it up a bit (not sure what the "pop" is when I first depress the accelerator - I'm open to input) Video 3 - Hearing it from under the hood
Michael - 1962 C20 LB stepside (project thread) - sold - 1963 Chevy C10 LB stepside (donor) - 1963 Chevy C10 LB Custom flatbed (project thread) - sold - 1979 K20 LB fleetside (project thread) Favorite exchange on the board so far: ol_Curt: "Jason, do you have power steering?" jason65: "No, but I lift weights." |
11-02-2014, 01:34 AM | #53 |
I'll try to get some video of driving it tomorrow.
11-02-2014, 12:56 PM | #54 | |
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
11-02-2014, 06:07 PM | #55 |
Thanks TJ, I subscribed to your channel as well. Here are some videos from driving today:
Driving this morning, cold outside. Still driving but resting at a red light - RPMS are high again and the engine is louder/faster. Arrived at destination, RPMs high and engine is louder/faster. Driving this afternoon, all warmed up and doing better.
11-02-2014, 06:15 PM | #56 | |
11-02-2014, 11:41 PM | #57 |
Thanks TJ. I kinda suspected the vacuum as well but don't know enough about it to diagnose. Something I'll keep in mind certainly.
11-03-2014, 08:58 PM | #58 |
Much better!
The oil pressure warning light is only supposed to come on when the oil pressure is less than 5PSI (or something like that), so I'd guess the sender is bad or the wire running to it is shorting out. I personally really like also having an actual gauge to monitor pressure. The idle speed hunting/being high at times is probably carburetor throttle shaft wear. The throttle return spring pulls the bellcrank assembly back instead of the throttle shaft with an inline six, so when the throttle shaft is worn it sometimes won't return all the way to idle (IME). An easy way to see if this is what's happening is to just jiggle the pedal with you foot and see if the idle speed changes; you may notice just barely tapping it makes it return to the normal idle speed. Idle mixture and how hot the carburetor is (and was when it was set) can/will also have an affect on the idle. |
11-03-2014, 09:13 PM | #59 |
What do you mean? I agree that vacuum leaks are a potential issue, as they are with anything else (although the intake/exhaust manifold design probably doesn't help things), but the sixes pull plenty of idle vacuum when they are running like they should be. It's not like they came with radical cams or anything.
