02-20-2015, 09:12 PM | #1 |
Re: Simple '49 Truck
Great job, inspiring.
02-20-2015, 09:43 PM | #2 |
Killer build!
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
02-22-2015, 01:22 PM | #3 |
What's your plan on fixing the rusted area where the upper and lower cab meet. Sorry I don't know the correct name for that area.
02-23-2015, 01:53 AM | #4 |
Plan is to just weld them up and grind them smooth. Shoot primer and get it solid for paint.
02-23-2015, 10:53 AM | #5 |
What would be the correct way to go about replacing g that area. Mine is beyond repair. Is there an older post I can look at?
02-23-2015, 12:58 PM | #6 |
Not sure why but these made me really happy when they should up this weekend. I also tore into laying out the wiring harness.
03-13-2015, 05:34 PM | #7 |
Noticed I haven't updated in a while. Got all of the rust fixed. Things have been a little slow but all of the plumbing has been figured out except the power steering which is proving interesting.
For the power steering, looking like I’ll probably end up using the Borgeson kit to reduce pressure and then a new flow regulator for reducing the gpm. I’ll be getting the lines built locally to save some money. |
02-23-2015, 12:54 PM | #8 |
Tough to say. I would probably look for a donner truck you could cut out the areas you need and graph them in. You could probably buy re-pop stuff but you might have to buy the whole cab which would be expensive.
03-17-2015, 11:05 AM | #9 |
very nice build so far. that area you patched is called the beltline. guy on here named shannon has made dies to roll out patches for that area.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
03-25-2015, 11:57 AM | #10 |
New shoes
03-25-2015, 12:13 PM | #11 |
those look nice, what did they come off of? they look a little wider than most I'v seen like that.
03-25-2015, 11:46 PM | #12 |
They're new came from Wheel Vintiques. 17x9s will be running 255/40 on all four corners.
03-26-2015, 10:51 AM | #13 |
those are awesome, luv that style. how much those run?
03-26-2015, 05:32 PM | #14 |
Not cheap but they're what I wanted.
04-06-2015, 11:06 AM | #15 |
Newest update. Everything’s blown apart for paint.
04-06-2015, 07:17 PM | #16 |
Everything looks good...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
04-06-2015, 08:09 PM | #17 |
Very efficient parts painting! Looking good.
04-06-2015, 09:37 PM | #18 |
Great work!
04-20-2015, 10:12 AM | #19 |
Here's a few more update. Back to a roller and did some minor body work on the cab. Should be shooting the sealer, color, and clear this week.
04-20-2015, 10:56 AM | #20 |
looks great, nice progress.
04-20-2015, 09:22 PM | #21 |
SAVING ONE TRUCK AT A TIME
I was out there this weekend. Chassie is looking really good. Cab was in the booth getting body worked. Shouldn't be to much longer now.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
05-04-2015, 11:05 AM | #22 |
Got quite a bit done in the past couple weeks. The drive train is completely back together just need to get the fuel lines ran. Hoping to get on that this week. I also got the power steering pressure regulator shimmed and installed the flow reducer. Need to get the P/S lines made and installed. Also hoping to do that this week. The brake lines might happen this week but probably not. The radiator hoses are in and got the steam vent plumbed. Also working to get the trans cooler hooked up.
I wasn’t going to have the entire truck blasted but it turned out to be quicker as some of the grey primer from the previous owner was starting to flake off pretty bad. After everything was blasted there were about 5 minor pin holes in all of the fenders. I was pretty happy with that. Everything has since been filled, primed and color flew yesterday. I’m a little torn because when I set out to on this build I wasn’t going to paint it. The wife, and others, talked me into it and I love what it looks like but it definitely doesn’t look like an old truck anymore. |
05-04-2015, 11:06 AM | #23 |
couple more
05-04-2015, 12:33 PM | #24 |
very nice. I'd be torn too. I like and appreciate both paint and patina. Just gotta have both!!!
05-04-2015, 12:39 PM | #25 |
Looks really good! Coming along nicely.
