#51 |
Re: Looking for 1970 St. Louis VINs for Chevy Trucks built Jan/Feb/Mar '70
I have another 2wd Blazer tub that is pretty messed up and I looked at the VIN tag the other day and it's VIN is CE180S146997. I wish I had the original doors for it since it is so close to your VIN, but they were long gone before I found it.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#52 | |
I'm trying....
![]() Join Date: Oct 2013
...Keith please chime in and tell me how I'm absurd to suggest he's got the first 2WD BLAZER OF ALL TIME!!!!!!!! ![]() ![]() ![]() ![]() ![]()
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#53 |
Iron, it's just number 1000 to be assigned a build sequence number at St. Louis in the 1970 MY, and it happens to be a Blazer. 1970 MY build sequence numbers start at 100001, with the first number assigned, and go up from there.
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 03-19-2015 at 04:46 PM. |
#54 |
I'm trying....
I get that. My question is did they start at 101000 or 100000 at the beginning of the MY in St.Louis?
#55 |
I'm trying....
I wish you did too...that would totally put an end to this thread.
#56 |
Mines a 4wd, should have said that to begin with.
#57 |
I'm trying....
Well Gee Whiz...you sure know how to let the air out of the balloon...
#58 |
Iron, They started at 100001. The first truck built/assigned was number 100001, so his blazer is the 1000th truck/vehicle to be assigned a sequence number at St Louis in 1970 MY.
CHEVY/GMC VIN DECODERS |
#59 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#60 | |
I'm trying....
....more VINs please ![]()
#61 |
Yes, round numbers are cool, very cool. I have been checking numbers for you once a week. I haven't found anything that helps yet. But I did find a (0S) door sticker that was after 157xxx. 0S167532 5/70, No help, but sooner or later one of us will hit a number between 1389xx and 155xxx that will help. You have done a great job narrowing it down using your dash pad, gauge cluster, and transfer case. Have you checked the code on your rear axle. If original, it will have the month and day on it. Not definitive but it will add some info.
#62 |
Would it be safe to assume 100011 would be the 11th truck built, on the very first day of production?
#63 |
In short.. yes
#64 | |
I'm trying....
...kind of neat to think about trains coming from New York, New Hampshire and Michigan in late '69 and early '70 to build her. Pretty much the same thing UPS is doing for the old girl in '14 and '15.
#65 | |
Keep in mind if there were other nameplates with separate VIN sequences inserted in there that would push it back a job or two (so maybe number 13 or 14, allowing for a couple GMCs in there). Additionally, it might take a full day to build the first truck only, as production problems are ironed out or material issues overcome. Then the next day goes better, and you continue to ramp up as things smooth out. Probably not on the first day, but no way to know for sure unless you were there. Definitely very early, though. K
#66 |
I'm trying....
Numbers update:
September 102XXX October November 122XXX December 1389XX January February March 155XXX, 157XXX April May 167XXX Still on the hunt for some January and February numbers...
#67 |
Still havnt been able to check the parts truck or extra doors. Hopefully next weekend it comes home.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
#68 |
My Truck was MFD in June of 1970.
#69 |
I'm trying....
What are the first three digits of your six digit serial #? We'll add it to the list.
#70 |
#71 |
I'm trying....
Thanks.
Numbers update: September 101XXX, 102XXX October November 122XXX December 1389XX January February March 155XXX, 157XXX April May 167XXX June 173XXX Still on the hunt for some January and February numbers...
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 04-01-2015 at 09:13 PM. |
#72 |
In September of 70 would be the start of the MFD for 71?
#73 |
I'm trying....
Yep...maybe some August.
#74 |
#75 |
