Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 08-14-2016, 11:33 AM   #51
67ChevyRedneck
67ChevyRedneck's Avatar
Re: '67-'72 Power Brake Booster Bracket With Hydraulic Clutch Conversion
Originally Posted by Captainfab View Post
The total cost for one '67-'72 hydraulic clutch conversion with just the base plate and in bare steel with shipping is $191.85.
I see that you're on vacation, have fun! When you get back I would be interested in this kit as well, without the brake booster bracket.
Can a different style wildwood MC be used? I don't really like that the line has to be run out of the back on top? So I have to go up and loop the line down?
I also have to ask... why is the 67-72 clutch pedal linkage so complex, but when I click on your 60-66 link it's just this:
I mean, I can do that easily.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-14-2016, 02:57 PM   #52
Captainfab
60-66 Nut
Depending on what bore size of master you need, a different style of clutch master may add to the cost.
That picture is of the original linkage that I started with. It did not allow full pedal travel and is no longer used in any of my hydraulic clutch convetsions.
Old 08-14-2016, 03:23 PM   #53
67ChevyRedneck
Gotcha!
I'm installing a 2001 4.3L S10 NV3500 in my 67 C10, the trans has the internal slave. I've seen several people us this one: 70174-750? But if that won't work with your pedal, that's OK. I want the best combo that will work. That MC bowl looks tiny... is there enough fluid to push the slave cylinder that I need it to?
Jesse James
Project "On a Dime"
Old 08-14-2016, 03:46 PM   #54
Captainfab
60-66 Nut
I don"t have good enough wi-if right now here in Fredrickstad, Norway to look up that part number. I have not had any complaints with the clutch masters that I typically supply. I believe that internal slave needs a .700 bore master. I will have to verify that later.
Old 08-14-2016, 06:17 PM   #55
67ChevyRedneck
No problem, NOT in a hurry at all. Enjoy your trip, we'll figure it out when you get back.
Jesse James
Project "On a Dime"
Old 08-15-2016, 03:08 PM   #56
Captainfab
60-66 Nut
That number you gave does not show up in Wilwood's line.
Old 08-15-2016, 04:37 PM   #57
Captainfab
60-66 Nut
I was able to find that Wilwood clutch master. The number you gave is an old outdated number. I can supply that master at an additional cost. I will have to check and see where I can get the best price.
Old 08-15-2016, 09:46 PM   #58
low70c10
do you have to have the the mounting plate (outside of locating where to drill the hole for the clutch master) im running a wilwood manual brake set up and would rather not have a plate if possible
low70c10 is offline   Reply With Quote
Old 08-16-2016, 02:51 AM   #59
Captainfab
60-66 Nut
Aside from locating the clutch master, the plate does stiffen the firewall. I can sell you everything except the booster bracket if you like.
Old 10-08-2016, 09:32 PM   #60
schwoch1
Local Detroit diesel nut!
schwoch1's Avatar
PM sent to you with a question!!!
THanks
Nothing cool anymore, I am old and boring....
schwoch1 is offline   Reply With Quote
Old 10-09-2016, 12:47 AM   #61
Captainfab
60-66 Nut
PM replied to.
THanks
Old 11-03-2016, 11:03 PM   #62
Hinz28
Hinz28's Avatar
Anyone have any pictures of 69-72 installed inside the cab. There's quite the rib that needs trimmed out. The directions explain it pretty well but I have yet to see a picture? Maybe I'll get one once I have it notched out
1970 Chevrolet C10 SWB 6.0 LSx
1971 Chevrolet K10/30 5.3 LSx
1972 K5 Blazer 8 lug LSX
Hinz28 is offline   Reply With Quote
Old 11-07-2016, 01:57 AM   #63
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Ttt
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 11-11-2016, 01:39 AM   #64
1970 CST Short Wide
Senior Moment
Best $ I've spent in a long time. Shipping was FAST , product was Fantastic, worked exactly like it was supposed to even though I had to modify because of MY set up.
Thanks John
Steve 1970 CST Short Wide
Pittsburg Ca
94565
Old 11-11-2016, 09:12 PM   #65
colgad
colgad's Avatar
Installed the flat plate version today after painting and it went perfect. A great product thanks for the quick delivery.
Dave
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 11-11-2016, 10:35 PM   #66
Jocker64
How much would you sell the clutch brackets kit, no master cylinder?
Jocker64 is offline   Reply With Quote
Old 11-12-2016, 12:48 AM   #67
Captainfab
60-66 Nut
It would be $50.00 less than the price in post #1.
Old 01-27-2017, 07:02 PM   #68
JPsChevy
JPsChevy's Avatar
I'm interseted in buying a kit, I'm installing an NV3500 that came out of an 06 1500 that had the 4.3/5spd. Did you come up with a master with a line out the bottom?
Opportunity is missed by most because it is dressed in overalls and looks like work.
- Thomas Edison
JPsChevy is offline   Reply With Quote
Old 01-28-2017, 01:09 AM   #69
Captainfab
60-66 Nut
No I do not have a source for a clutch master with the port on the bottom. With the Wilwood's it is either on the top or front.
Old 01-28-2017, 08:48 AM   #70
JPsChevy
JPsChevy's Avatar
That is fine I was just wondering, I will take a complete kit not powder coated. Pm me your PayPal and a total.
- Thomas Edison
Old 01-29-2017, 12:14 AM   #71
Captainfab
60-66 Nut
I sent you a PM
Old 02-17-2017, 11:52 AM   #72
67ChevyRedneck
Gotcha!
Ready to finally buy this. The trans I'm using is posted above. I don't need the MC that I posted above if you know of one that works with my application, but I do want it to come out the front, I DO NOT want one that comes out of the top.
I just want the unpainted mount plate for the clutch and the clutch parts like below:
Thanks!
Jesse James
Project "On a Dime"
Old 02-18-2017, 01:05 AM   #73
Captainfab
60-66 Nut
This is the other style of Wilwood clutch masters that I use. It has the port on the front. It just depends on what you want. The other one you posted about will raise the cost.
https://www.summitracing.com/parts/wil-260-6764
Old 02-18-2017, 10:14 AM   #74
67ChevyRedneck
Nice, I like that way better than the plastic tank one!
Yes, I want the front routing, makes the install a lot cleaner looking dropping the line straight down.
If that ones matches up with my NV3500 trans I'll take it. Is it still $191.85 (odd number for the forum )?
PM me your paypal info. Thanks!
Jesse James
Project "On a Dime"
Old 02-19-2017, 01:47 AM   #75
Captainfab
60-66 Nut
I will send you a PM.
