01-18-2015, 10:19 PM | #51 |
Re: 69 C20 Daily Driver build
I am doing everything myself. I think this is my 6th weekend working on it.
Mike 1971 C10 350 1969 C20 396 1979 Corvette L-82 |
01-18-2015, 10:21 PM | #52 | |
01-18-2015, 10:25 PM | #53 |
It turns out that I have 3.55 gears.
01-19-2015, 10:55 AM | #54 |
Well last night I got a few parts painted, installed the steering column, brake booster, seat, seat belts, along with a lot of small little things. I have a bunch of little things to work on this morning and then get the bed on and start with the wiring. Here are a few photos from yesterday
01-19-2015, 12:01 PM | #55 |
sweet color choice! BC/CC or Single-Stage?
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
01-19-2015, 08:56 PM | #56 |
Good to see another C20 getting some attention. You are flying on this thing. Keep at it or the 71 will start calling for attention and you'll never get done! Trust me, I speak from experience with projects losing momentum due to changing priorities. Just look at my thread for proof...
I was thinking 3.55 gears were a little highwayish for a C20, but then remembered this is a big block truck (lucky dog). I'll be following along!
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. |
01-19-2015, 09:51 PM | #57 |
born to lose
Awesome truck man! Hope to see it around sometime
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 Sold!! '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 stolen totalled gone.... Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
01-20-2015, 12:38 AM | #58 |
It is a single stage. Did not come out all that good as It was really cold when I was painting.
01-20-2015, 12:39 AM | #59 |
01-20-2015, 12:40 AM | #60 | |
I wish it had a higher gear like a 3.07 as I will be driving about 80 miles a day on the interstate where the speed limit is 80 MPH.
01-20-2015, 12:46 AM | #61 |
So today I got the bed on and finished up a few little things in the inside. I am now working on the wiring. I have 3 bad wiring harnesses and I am combining them to make one that works. I got side tracked by installing a volt meter from a 87 truck and a tach that had a broken housing that has been floating around for years.
This was what the wiring looked like on the harness out of the 69 truck at the ignition switch.
01-20-2015, 12:51 AM | #62 |
I also just hit the $2000 mark. Still need a parking brake cable as the one I have is a 69 but I 68 cab and using the 68 park brake lever.
Also need tires but plan to look for some good use tires. Right now it has 245 75 16 on it. I am thinking about going with a 265 75 16, any thoughts? I had a C20 suburban and a 265 75 17 hit the fender when I turned the wheel. I hope with the shorter 16 in wheel it will not.
01-20-2015, 12:53 AM | #63 |
I know the gage needles are normally orange but I had red and orange means spending more money.
01-20-2015, 10:57 AM | #64 |
Still doesn't look bad. It's hard to control temps in anything but a real booth. Or keep trash out of it, like when your neighbor decides to cut the grass when you're painting...just ask me, I'll tell you ;-)
01-24-2015, 01:31 PM | #65 |
I'll never understand why people think it's a good idea to butcher ignition wires.
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord......... |
01-25-2015, 09:48 AM | #66 |
That sure does look nice!
Grandpa 1953 M38A1 Jeep 1989 GMC K2500 1958 Alaskan Camper all original WORK : A necessary evil that finances what I really like to do. |
01-26-2015, 12:42 PM | #67 |
So got it running. The starter when I got it was messed up due to having the wrong bolts in it. I took a chance with the flywheel but it's going to need to be replaced. Also will need to replace or rebuild the carborator.
01-26-2015, 12:44 PM | #68 |
02-01-2015, 02:46 AM | #69 |
Long work week and part of it was out of state so today was the first in a while to work on the truck. Started out with a junk yard run and went to 4 different junk yards looking for a decent carburetor. No luck but did find a heater control for $12 and a wheel with a good tire for $20.00. Also finished with the flywheel change, got all the parking brake stuff finished and painted the grill letters.
02-01-2015, 12:48 PM | #70 |
I'm going to have to look in my shed, but I may have the old carb off mine that I'll give you if it's still out there. It was the Q-Jet, and rebuilt just before I tore the truck down.
02-01-2015, 04:05 PM | #71 |
I looked everywhere. I must have thrown the carb out when I decided to go F.I.
02-08-2015, 12:48 AM | #72 |
Started rebuilding the front end. Stuck at tool failure!
02-08-2015, 02:59 AM | #73 |
So a busy week at work ending in my son braking his foot. Then my grandfathers vice that I inherited many years ago broke and smashed my foot. Next week is a week long ski trip.....
We'll the control arm shafts all had between 1/4 to 1/2 of a inch of play. Never seen that kind of play on one of these trucks. Turned out the nut on the pitman arm that holds it to the gear box was hand tight and I did not even need a puller as it fell off after I took the nut off. Still waiting on the lower control arm shaft kits but have everything else, we'll with the exception of a new bench vice.
02-08-2015, 03:01 AM | #74 |
I also changed the intake so that I can use a different carb that I had.
02-16-2015, 11:48 PM | #75 |
A few photos
