#51 | |
Re: Faded 87 soon to be LS powered
At the moment I still kept lines for trans out of the 05, will try to fit in 05 radiator too if I can. If it does not work out I will follow your suggestion on it. Man I am heading to a busy weekend Friday after work. Everything is getting clear in the head, just need to get it done now. Its funny how simple it all become after you grab the right info together how to do it.
Put a cover over it, have a beer or two, kool down, and look at it in a couple weeks, we all have to take a break! 64 Short Fleetside, 283, T5 http://67-72chevytrucks.com/vboard/s...d.php?t=572500 Faded 87 soon to be LS powered http://67-72chevytrucks.com/vboard/s...d.php?t=653667 |
#52 | |
I'm just glad to be here!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#53 |
Race-
I looked at your diagram of you fuel system. I had not seen the 611203 fittings before. that eliminates some fittings and connections on the hoses that I used. I think those fittings would work well in the system the way you have it drawn.
#54 |
I changed parts list some more. I think this should do it now. Parts are listed and priced on attachment. AC Delco GF 822 is not listed here but needed and hose cutters that summit was out of stock at the moment. I will pick those locally. Plus hose clamps to hold hose lines to the frame.
Put a cover over it, have a beer or two, kool down, and look at it in a couple weeks, we all have to take a break! 64 Short Fleetside, 283, T5 http://67-72chevytrucks.com/vboard/s...d.php?t=572500 Faded 87 soon to be LS powered http://67-72chevytrucks.com/vboard/s...d.php?t=653667 Last edited by Raceaprilia; 01-16-2015 at 06:36 PM. |
#55 |
List looks good.
#56 |
Did some work over long weekend. Engine is mounted for the last time. Gibson headers are on (they do fit with slight mod on engine mounts in my case), intake, coils, harness is back on. Did not make mount for PCM yet, also relocation of battery tray still on the list.
Front wheels finally showed on Friday and decided to get them on right away. Installed 3" drop spindle together with new joints on upper/lower arms, new brake cylinders, pads, hoses,... Added 3" drop coils with it. The thing sit nice and low ![]() Gas supply parts are dropping in daily now - I guess weekend plan is already defined. Not much time rest of the week, work will keep me busy till Friday for sure.
#57 |
Not much work done over the weekend. Gas tank is ready to be dropped in, sending unit is in place, need to cut and prepare fuel lines to connect it to engine.
Did manage to finish some work around engine bay. Modified PCM holder is in place on driver inner fender, mount for fuses is located on the holder. Battery tray was relocated on driver side. 05 radiator and fans are mounted and overall fit good and look good too. Just picked CL score tonight - like new K&N CAI that was slightly used still in box for $180 -that's about 30% off new sell price.
#58 |
Couple more...
#59 |
I have a runner! Had fuel lines switched from fuel tank to the GF 822 but when that was fixed it fired right up. Driveshaft had to be shortened 1" and it fits back in. I got couple exhaust pipes with H pipe insert from Summit and ordered some Magnaflow mufflers with it. When parts arrive majority of small thing will be squared away already and it is getting on the road for test drive. Still need to hook up shifter linkage to the steering column and get switch for haul mode. Oh yea, dyed interior black and had seat redone in black and red vinyl. Excited!!!
#60 |
I probly missed it but what did you do for engine mounts?
1986 Chevy Silverado LWB (project) 1967 Chevy SBSS (future project) 2003 Chevy Tahoe (wifes daily) 2004 GMC 2500 Duramax (company truck) 1986 GMC Wrangler LWB (newly acquired beater) ![]() |
#61 |
See pic on post #37. Beside that plate just SBC mounts that came stock with truck.
#62 |
When I pulled fuel tank to installed new one this made my day. I guess one of the girls at assembly line was feeling love at work that day
![]() Pic of seat and truck in new shoes. Seat is copied by idea on the forum that I liked the most off all. 3" spring combined with 3" spindle is too much @ front. Need to raise it up it rub at any minimum turn. Will use member suggestion and cut 3/4" off stock spring for now to see how it sit and then cut some more to get ride height and later invest in 1" or 2" drop spring if needed.
#63 |
What size wheel and tire do you have on the front? Can you measure your wheel well height for me please?
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
#64 |
![]() Join Date: Feb 2010
i must have missed this but what headers did you end up running? im hopping they will fit in my 69 burban if you don't mind sharing some information on them
1980c-10 mybaby |
#65 |
Its 255/45-20. Rims have 5,25" BS up front. Had to pull out 3" springs and put 2" springs to avoid rubbing to the inner fender. All good now. Floor to front center outside fender lip measure 29,5" now. No picture of it yet. Rocker panel and bed bottom measure 10-10,5" front to back if you find that helpful too.
#66 |
Gibson GP 139S. They do fit and they exit just in center of frame rails and not below frame like some might. I run my own trans cross member and exhaust line passes on top of it. Easy pipe routing. Just need to route pipes couple inches more toward center of truck to avoid running it too close to fuel lines in frame rails.
#67 |
All is running good for now, still need to hook up shifter cable and some minor things need to be done.
On the tow mode switch; I have below momentary switch. It has led ring light on front face. Where do I connect the pin 71 wire? Switch will have constant negative supply and ignition switched positive to turn on light on switch. Do I lead 71 wire to NC, NO or C ? Thanks for help again.
#68 |
The Tow/Haul wire needs a momentary signal to ground to activate it. Run the wire to the NO contact. When you push the botton, it should close the circuit, when you release the button the circuit should be open.
Verify this with you ohm meter. Put one lead on the NO terminal and the other lead on the (-) terminal. It should have an open circuit without the button depressed. Depress the button, the circuit should close and read resistance on your meter. If that does not make a circuit, switch the one lead on the (-) terminal to the C terminal and try again. If this makes it work, then the C terminal needs to be hooked up to ground for the button to work with the Tow/Haul mode. The (+) and (-) terminals may only be for the light...
#69 | |
![]() Engine bay is done, it is not beauty queen but that was not goal either. Exhaust is done, it is 2,5" pipes with H and Magnaflow center-center muffler and turndowns before rear axle. Boy that sounds good! Need to make movie clip and post it here for opinions! Still need to clean/remove some old wires for 305 - I will do that when I change heater core on the weekend.
#70 |
Nice job, looks good!
1983 GMC SWB - 350, TH-400 2002 Camaro SS - 408 9sec street car 2000 Trans Am - H/C/I 2014 Chevy Z71 |
#71 |
Did I ever said that LS in truck runs amazing lol? I love every bit of it.
Went for longer test drive today and its pure fun. Need to put new rotors on it because it does shake when stopping hard and with LS you need stopping power too. I knew it will be needed but still hoped what was on will be ok. On the tow mode; for now it is still just wire that is hooked to the ground while driving. It does make big difference when it switch mode. That thing will fly. I use stock type temp sensor and stock gauge. When I ground the tow wire then gauge goes crazy up and down for a while. It might be just something else at same time causing it. After couple miles all go back to normal. Whole truck is polished now, side trim is removed also waiting for the new one to put on it. Changed faded driver mirror. Need to get good driver quality rear bumper also to make it smooth. Was thinking to use 72 rear bumper like on 64 but not sure just yet. Will probably go with cheap used stock bumper.
#72 |
My stock under hood sound insulation is a mess and it is falling apart. While back I noticed that member used one plastic liner made for this with some silver insulation directly to the hood like sound deadener. It looked great. Anyone know how it is called and where to get it? I try to google it without sucess with my broken english lol. Thanks
#73 |
#74 | |
#75 |
Great past Sunday trip around the area. Still have some minor play in steering components that I will change all and alighn it this week and need to put in new park brake cables plus drums at same time.
