#51 | |
A day late and $1 short...
Re: "Brass Monkey".....Installing 4/6" ECE Drop Kit
I am in the middle of a frame off build using PB parts, LS1 etc... and reading your thread and has me wishing I had found a truck like yours and done exactly what you are doing. You have a good one hold on to it. ![]()
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#52 |
I think a 225 65 on a 7" rim would be near ideal. Not sure if that tire exists though.
#53 | |
I pulled the BFG size charts. Would i be better off with a 255/60 on the rear with the 245/60on the front? This would minimize the tire rake to a 1/4" differece in lieu of a .7" difference with the 275/245 combo.
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
#54 | |
#55 |
I have 29" tires on the back of my truck and 27" on the front. That is a little noticeable rake. Those small #'s you talk won't matter a bit.
#56 | |
I don't really want to add another 3/4" of rake to it. I was thinking that with the 4/6 drop it would have been more leveled out initially.
#57 |
I had a 28" front tire and 29" rear tire with a 5.5/7 drop before I took my truck apart and it sat almost dead level. The secret for not rubbing in the front is tire size and off-set (backspace).
#58 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I agree with ECE . A 245/60 15 is only 26.46 inches tall where as the 255/70 is 29.04 tall. A 245 tire is 9.64 inches wide and a 255 is 10.03 wide which is .39 wider. You are running 8 inch wide rims which are perfect for 255/70's. In you went to a 245/60 on a 7 inch wide rim your truck should have any rubbing problems as your tire would be 1.39 inches narrower and 2.58 inches lower. If you want the rake look then the 275/15's on the back with 245's up front will give you that. If you want it level run the 245's on all 4 corners and the 2 inch front to back drop difference should just about level out the truck. I believe there is a natural 3 to 31/2 front to back natural height difference on a stock height truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#59 |
Looks great! Makes me wish mine was closer to being finished.
#60 |
![]() New tires are on. Just waiting for this 12" snow to get off the roads so I can get to the alignment shop.
#61 |
laying low
![]() Join Date: Mar 2001
That looks a lot better. Plenty of tire clearance I bet. Monkey looks good.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#62 |
It's a sweet ride, it would be hard to not be able to drive it. Hope the weather clears up for you all!
#63 |
Spring cant get here quick enough!
#64 |
![]() Join Date: Apr 2005
Looks good. Did it have a sway bar or did you add one?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#65 |
I added the ECE front sway bar.
#66 |
#67 |
I cant wait to see. I have some nice banked backroad curves going through open fields around my house.
#68 |
amazing what an altitude adjustment will do. Looking good.
#69 | ||
"I ain't nobody, dork."
Very nice! Stance looks perfect.
![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#70 |
![]() Join Date: Jan 2013
What size tires did you end up going with? Truck looks great!
#71 |
![]() Join Date: Jul 2009
Truck looks killer! I love the 61 Biscayne too. I'd take either one
#72 |
245/60/15
275/60/15 BFG Radial TA 15x8 wheels
#73 |
![]() Join Date: Jul 2012
Looks good Coursey. Nice thread, thanks for sharing!
Yeah...more snow coming. |
#74 |
![]() ![]() Finally after 2 weeks of ice I was able to get it loaded on the trailer. Now they are calling for 6-10" of more ice and snow! I don't know if i will ever get this truck to the alignment shop!
#75 |
Winter has really come on hard here at the end. Nice trailer! Truck looks good. Is that your shop? Really nice. And of course I like the tow rig too.
