03-14-2015, 05:58 PM | #51 |
SIR
Re: Lets see your gauges setups
hanline...look & work great....
66long low fleet http://community.webshots.com/user/LVNR66 |
03-14-2015, 06:15 PM | #52 |
Wish the pic was better SIR. I have a set of gauges in my OT VW Karmann Ghia from Haneline. They have nice stuff.
03-14-2015, 06:59 PM | #53 |
the only time you get a bad GPS signal is in long tunnels or otherwise underground. not sure how this accesses the satellites but a regular GPS uses about 12 of them at one time and if one is blocked by trees or mountains, the accuracy goes down a bit until it gets full visibility again to the sky.
these GPS speedos must have some sort of antenna that has to be mounted outside. |
03-14-2015, 08:52 PM | #54 | |
http://www.boeseengineering.com/Shop...lphin-gauges-1 I really cannot remember the exact thickness but it was near .25 inch. Each of the gauge holes was counter bored (?) about .125 so that the gauges set down into the insert. If making your own, I do not think the thickness is critical as long as it is thick enough to prevent flex, gauges do not have to be recessed either. Small gauges are 2 1/16 diameter, large 3 3/8 inches. I ordered mine with the brushed finish. Show us what you end up with when you finish. Hugh |
03-15-2015, 11:24 PM | #55 | |
me too, but I left the original silkscreen on the lens
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
03-15-2015, 11:57 PM | #56 |
Sneaky sneaky. That looks cool but it would drive me crazy trying to look through one set of numbers to see the other gauges. Pretty incognito if you just glance quickly
03-16-2015, 11:05 AM | #57 |
03-16-2015, 07:11 PM | #58 |
Nothing special, just a "factory" cluster.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
03-16-2015, 07:16 PM | #59 |
Looks right....
03-16-2015, 07:25 PM | #60 |
You know, I'm not a 'mod-a-holic' but I do like to change things up a little. Your original guage cluster really looks great! I wonder if it could be changed so that the indicators would be actual numbers instead of 'tick-marks' and if the back lighting could be changed to red.....THEN, I'd be sold on it for my truck. I've got an autometer setup thinking that it was what I wanted but I'm not very happy with the look. Now I'm looking for something different!....again!
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
03-16-2015, 08:55 PM | #61 | |
honestly, you dont even notice it.
03-16-2015, 10:06 PM | #62 |
Mark..I haven't seen your cab/dash for awhile...really over the top!!
In other words..I like it Bob |
03-17-2015, 09:41 AM | #63 |
Astronaut, really like that clean look. What all is involved in re-numbering/recalibrating the speedo?
Lee |
03-17-2015, 09:52 AM | #64 |
one more...
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
03-17-2015, 10:08 AM | #65 | |
The speedometer may end up being driven by an Abbot cable-x box or Dakota Digital's newer version. That will take car of the speedometer calibration. Jason handles the tach calibration.
05-17-2017, 07:45 PM | #66 |
But Found Her 25yrs Later!
I posted this in another thread:
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
06-30-2018, 11:17 PM | #67 |
Did a little more work on my gauge cluster today. The little bow ties have chrome behind them and the bezel is going to be chrome.
07-06-2019, 08:30 PM | #68 |
Got the gauges installed yesterday.
07-06-2019, 10:09 PM | #69 |
I got the Dakota Digital Retro gauges installed last week. All the readings are taken from the LS bus except oil pressure, they provided the pressure sensor.
There are multiple screens you can click thru on the left hand display and customize them as you wish. I converted the choke knob to a dimmer for the back light. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
07-08-2019, 10:50 AM | #70 | |
Never Ending Projects
Here is mine.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-08-2019, 06:49 PM | #71 |
Are yours from a newer model truck?
07-08-2019, 07:01 PM | #72 |
