03-24-2015, 05:51 PM | #51 |
Re: 4L60E/241C info
Ready to assemble as soon as bearings and seals arrive........!
Ended up using Rustoleum self-etching primer on the bead blasted, bare metal. Covered with Rustoleum metallic nickel enamel......we'll see how it holds up on aluminum. Never had much luck with paint staying on aluminum very long, but it will look nice until it goes under the bottom...! Ordered all new yellow zinc chromate flange head cap screws. Last edited by A1971Blazer; 03-24-2015 at 05:56 PM. |
03-24-2015, 06:15 PM | #52 |
Re: 4L60E/241C info
Looks great. I like the bolts. I just used the originals....just cleaned them up.
What did you do for the VSS and the 4X4 low switch? The ecm needs to see 4low and the 241c just closes a contact at 4wd high and low? I think I am going to have the switch for 4wd goto a light and add a switch to the shifter housing for 4low.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! Last edited by First c10; 03-24-2015 at 06:18 PM. Reason: Forgot a question |
03-24-2015, 06:31 PM | #53 | |
Re: 4L60E/241C info
Now if it was on the transmission output before the TC...yea, I think it would confuse the ecm...at least the speedometer? |
03-24-2015, 06:36 PM | #54 | |
Re: 4L60E/241C info
I changed the harness wire from the 2008 style to the 1991 style and even ordered a new VSS just to make sure I am good.(the one with the TC had a broken connector on one side.)
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
03-24-2015, 07:04 PM | #55 | |
Re: 4L60E/241C info
I went ahead and ordered a new VSS too....my tranny is going to the shop this week too to get the output shaft changed and do the upgrades. As soon as it comes back, I will be ready to start fitting the engine and driveline in. I still have to rebuild and re-gear both axles. I can't make up my mind if I want to run a 2½" lift with 33" tires and 4.10 gears, or 4" lift with 35" tires and 4.56 gears......I am gonna run a truetrac rear for sure. What tire size/gear are you running? |
03-24-2015, 07:10 PM | #56 |
Re: 4L60E/241C info
I am running a 33/12.50-15 dick Cepek with 15x10 Alcoa's with 3.73 axles. 4" lift. It should be fine as I don't think my son will be rock crawling in it. Well you never know.
03-24-2015, 07:11 PM | #57 |
Re: 4L60E/241C info
Tread pattern
03-24-2015, 07:19 PM | #58 |
Re: 4L60E/241C info
Nice...! never under-estimate what a son will do......
My son and I have been into wheeling for a long time. We built my Jeep then built him one too. If his breaks.....well it's his! I'm building this one for a driver and probably an heirloom for my grandson who's 7 now, so I don't want to get too aggressive with it but I do want it to be "capable" if the need/itch arises. |
03-24-2015, 07:35 PM | #59 |
Re: 4L60E/241C info
This's one place I heard about the 4wd to ecm issue. Vss???
I agree to never under estimate a son. I have 2 that are older. My middle son we built a 70 c10 and he takes care of it pretty good for 16. Nice to plan to leave a truck for the grandson. That is cool. I am sure I will be there one day. But not yet they are to young to have kids. Lol.
03-24-2015, 07:57 PM | #60 | |
Re: 4L60E/241C info
I have so far to go that I'm not gonna worry too much about the VSS/4WD issue for now. I guess we'll just cross that bridge when we get there? One more thing, does your 241 have the companion flange on the front output? This one does and I have ordered a CV yoke that I think will fit. It measures out the same according to the dimension specs. This one has a stamped metal seal protector pressed on. I may have to make one if it doesn't fit the new yoke....or I may not even need it? |
03-24-2015, 09:33 PM | #61 |
Re: 4L60E/241C info
Here is a pic of my front drive line connection. Not sure why my pictures are 90* out all of a sudden.
03-25-2015, 08:07 PM | #62 | |
Re: 4L60E/241C info
I've got a real good 700R4 laying around........that would solve the 4lo PCM issue.......also got the adapter that came with the TC.......and the 4WD output shaft I have is the same as the 4L60........since my motor is DBC it won't make much difference. A few less wiring issues too......talk me into it or out of it........???? |
03-25-2015, 08:17 PM | #63 |
Re: 4L60E/241C info
Never was my plan to have you loose sleep unless it staying up late working on the truck.
I vote to keep the package together. I would just ask your harness builder (I think psi) about it. I am building my own harness from the stock one. I have added a few pins to my harness for a few things so even if your harness guy didn't add anything for 4x4 can't be too hard to do. I am thinking a micro switch for 4low on the shifter should be good.
03-25-2015, 08:20 PM | #64 | |
Re: 4L60E/241C info
03-25-2015, 08:39 PM | #65 |
Re: 4L60E/241C info
Isn't the stock cv joint a bolt on flange that bolts to the square flange? This is something I haven't worked on yet. So I am not sure.
03-25-2015, 09:02 PM | #66 |
Re: 4L60E/241C info
Probably is, I wasn't sure......this old blazer had a CV front yoke on the 205 transfer case and the CV and drive shaft slip joint is shot........I had to get a yoke either way....and I have a good CV unit I can use to build the front drive shaft. I just never used the flange type before......it looks plenty healthy though.
03-25-2015, 09:43 PM | #67 | |
Re: 4L60E/241C info
Hitting the rev limiter is also possible on a 700R4....In high range, Because the Governor is on the trans output shaft. Tune the Governor for 4/lo or high range? GM tuned for high range. It will be opposite from a ''E", Shift normal in High range then shift way early in 4/lo. It would also AT LEAST need to be a "K" case 700R4. Use the 4L60E, If for nothing else.....The stiffness of a modular trans case, And the bellhousing is structural member of aluminum block LS engines, Though "YOU" could make a good strong dust cover Your 0411 PCM is easily tuned for 4/lo shift tables! Don't sweat this stuff. |
03-25-2015, 09:54 PM | #68 |
Re: 4L60E/241C info
All I can say is damn I need to get out and get working on this truck. Great information guys.
03-26-2015, 06:16 AM | #69 |
Re: 4L60E/241C info
03-30-2015, 12:07 AM | #70 |
Re: 4L60E/241C info
I picked this up yesterday with the 91 suburban frame I got. Can or have you measured the length needed for the front driveline??? If so do you mind sharing?
03-30-2015, 07:02 AM | #71 | |
Re: 4L60E/241C info
I just yesterday brought my frame back into the garage. I did get the TC all re-assembled and I'm waiting on the transmission. I still have to get my lift kit installed, re-build and re-gear both axles, and fabricate my motor mounts and cross members. THEN I can get drive shaft lenghts.... |
03-30-2015, 03:22 PM | #72 |
Re: 4L60E/241C info
What your not done with that truck yet???
I was just wondering the length if you had figured it out yet. No worries I can wait!!!
03-30-2015, 03:38 PM | #73 | |
Re: 4L60E/241C info
I originally intended to use the NP205 TC and mount everything using it's original location. When I disassembled the TC, it had some major issues and adapting it to the 4L60 was gonna be more costly and time consuming. That when I started looking for a 241. Using it will change the entire scenario.... |
04-10-2015, 08:53 PM | #74 |
Re: 4L60E/241C info
OK..............slowly but surely......
Got the tranny back with all the upgrades and 4wd output shaft installed..... new core support from GMC Paul's leaned up behind it too.... Got the correct adapter.....4-7/16" long.....clocking looks like it may need some massage..?.... PFab swap mount is on the way. I could make it but time is more expensive right now.... Mock up with bare tranny case....wish I had a bare block too.....! It ain't a lot.......but it's a start....... plan is to get the motor and all the drive line in, all the fab work and all necessary holes drilled..... then pull apart, sand blast, and re-furbish from the ground up. You can see where I hit the frame and top of the front chunk while I was blasting some other stuff......then just rattled canned it. Amazing how even cheap paint will stick to blasted bare metal. Just had to make a teaser to keep me going...... |
04-10-2015, 09:05 PM | #75 |
Re: 4L60E/241C info
This has taken some time too........but I gotta make it easier....
Body jig/rotisserie |
