10-31-2015, 04:02 PM | #51 |
Re: 1949 AD truck 'Chevy-49'
Rear floor is removed, will ad a cross member before I weld the new panel in.
Tomorrow we will tilt the cab on his back, to get better access to the bottom of the floor pan. |
11-02-2015, 04:44 PM | #52 |
Yep, looks good!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
11-02-2015, 04:49 PM | #53 |
Hi Kees, thanks. Want to have cab on the frame end off this Year.
11-02-2015, 05:06 PM | #54 |
I think you'll manage that!
You still got a few months
11-07-2015, 01:24 PM | #55 |
Cab is on his back and trimmed the cab supports to weld the rear reinforcement tube on.
Rear tube ready to weld. Added also extra tubes for reinforcement. I also read a few posts about removing the rear seat support, I would also like to remove rear seat support. Can I remove the rear seat supports do you think ? |
11-07-2015, 01:29 PM | #56 |
Simple? What's simple?
I removed mine, haven't noticed any problems ... it wasn't connected on either side, anyway . But seriously, that piece lent rigidity to the floor left to right, because there was no link between the cab mounts. With that reinforcement tube welded in there, you'll have no problems removing it.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
11-07-2015, 02:30 PM | #57 |
Your floor is looking really good!
11-15-2015, 07:09 AM | #58 |
AD thanks, JJorgensen thanks will remove the rear seat support shortly.
Drilled all the holes in the new floor panels and sprayed weld thru primer. Welding is ready, next step is rear cab corner and inner cab corner. |
11-15-2015, 11:57 AM | #59 |
That floor is coming out quite well! Does your truck still have the angle braces from the door pillar to the inner cab corner? Mine were both damaged and had to be tossed.
11-15-2015, 03:09 PM | #60 | |
Cut the right side out, still have to remove the inner corner, thought it would come out easily, but need more work. I managed also to remove the rear seat support. |
11-15-2015, 04:35 PM | #61 |
Looks good, nice work!
11-16-2015, 11:45 AM | #62 |
Nice work on the floor....
11-28-2015, 02:11 PM | #63 |
Kees and 69CST-V thanks for the compliments
Today spend some time on the inner rear cab corner, cleaned and sprayed weld thru primer.. Inner rear cab corner welded. Next job is to trim the rear cab corner.... |
11-29-2015, 02:56 PM | #64 |
Rear cab corner trimmed, drilled holes for welding.
Sprayed Brunox epoxy primer Corner clamped in. |
11-29-2015, 04:37 PM | #65 |
Tacked in, I'm happy how it sits...
11-30-2015, 11:21 AM | #66 |
Great job on the corners...
11-30-2015, 01:38 PM | #67 |
The corner is looking really good. Should last another 65 years!
12-19-2015, 12:28 PM | #68 | |
Today made some path panels, fuel filler hole and fresh air intake on the top Cowl. |
12-19-2015, 01:20 PM | #69 |
Who did you buy the floor and firewall kit from?. They look like solid and good quality.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
12-19-2015, 01:31 PM | #70 | |
http://www.absolutesheetmetal.com/co...evy-pick-parts Firewall ad rear floor panels made by myself. |
12-19-2015, 08:35 PM | #71 |
Hey Chevy 49, progress looks good, about the top vent, I filled the vent on my '54 back in the day, it looked good and I thought all would be fine because I was going to install AC anyway. Anytime I had the windows down at highway speeds and no vent to open there was a lot of air buffeting in the cab. On my current AD I rebuilt the top and side vent and use them both. It makes a world of difference in the cap pressures having the ability to open the vents and have the air flow through the cab. If you have a buddy with working vents try a test drive with vent open and closed and you'll see what I mean.
Metal work looks great, keep up the pictures. Rob
My '47 C.O.E build |
12-28-2015, 11:37 PM | #72 |
Very nice work! I'm at the same stage making the same rust repairs to my truck right now so this is really interesting. Great job on the floors!
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
12-30-2015, 12:48 PM | #73 |
@ Rob,
Thanks for your tip about the cab ventilation, I drove the truck several years ago and did not drive with the vents open, hmmm... maybe electric windows will help. @ Scott2 Thanks, that's the way I did get also all the information I need(ed). This week bought a new welder, tried a lot of (test) welds to get the settings right, first welds to the cab: Left cab corner is also in, need to trim the door gap later. Fuel filler patch is in. |
12-30-2015, 03:42 PM | #74 |
I need to redo the floor in my 54 and replace many of the same parts you did.
Will I have any issues with laying my cab on its back to complete the repairs? I re-enforced the cab with 1"x1" tubing so i don't think it will flex, but I dont want to damage the sheet metal on the back of the cab. Thoughts? Thanks, |
12-30-2015, 04:24 PM | #75 | |
It was scary.....will not do it again. Next time I will use the tube that I welded on the rear pillar and weld another one higher on the rear pillar. Lift the cab on the lower tube put on a jack stand and turn/spin /lower the cab and put another jack stand under the higher tube. |
