Old 05-04-2015, 12:16 AM   #51
Lugnutz65
Lugnutz65's Avatar
Re: 62 c/10 engine swaprz
Originally Posted by brap999 View Post
The only thing I will add to this is that I went through 2 used T5's before giving up and buying a rebuild from a local trans shop. Each one lasted only a few months before something would break. Buying a rebuild was the Best thing I ever did, it's been running strong for 2 years now and no problems.
Oh and make sure you get the V8 T5, and not the V6 T5. Some the junk yards around here tried to pawn off a V6 T5 as the V8 version.
I respect your opinion. Why do you think a V6 version is less desire able than the V8 T5? The final gear on a V8 version is usually 0.63 and might bog the engine if Hp is low. I agree that a 350ci should be able to pull the 0.63 OD gear. It depends a lot on what rear diff gear he has. The V6 T5 has a great OD gear of 0.72. That gear really works well in these older trucks.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 05-04-2015, 12:28 AM   #52
brap999
brap999's Avatar
It's been a while since I did the research but the V6 T5 had lower max torque rating, and a smaller clutch with fewer splines on the input shaft than the v8 T5. Reading on the Gen 3 camaro forums it seemed to recommend V8 T5.
Of course, it also comes down to how you drive, i guess if you have a mild V8 and drive conservatively i would think there wouldn't be any problems. Me personally, I'm already pushing past the max torque rating of the Non-WC V8 T5, and I don't drive conservatively
I had my Non-WC V8 T5 behind an inline 6 and now behind my 350 and it worked well with both.
1963 Chevrolet C10 Stepside
1972 Pontiac GTO
1998 Dodge Viper GTS
1999 Jeep Cherokee XJ
2018 Chevy Camaro ZL1-1LE
It's never too early to beef up my obituary
brap999 is offline   Reply With Quote
Old 05-04-2015, 01:07 AM   #53
Captainfab
60-66 Nut
A Small block will not bolt up to a bellhousing that was bolted to a 235. You will either have to find a '62 and earlier V8 bellbousing or just go with a later model hydraulic bellhousing and add a trans crossmember.
Old 05-04-2015, 07:05 AM   #54
OldChevy61
OldChevy61's Avatar
Thanks for all the input. Captainfab, that is what I was getting from what I have read on a couple other sites.
OldChevy61 is offline   Reply With Quote
Old 05-04-2015, 10:56 AM   #55
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
TJ,
He's not worried about bolting a T5 to a 235 bell. He thinks he can't bolt a 235 bell to a SBC engine. Thus he'll probably need to find a new bell. One that will bolt to a SBC AND allow him to keep his hydraulic clutch system.
My bad...read this way to late last night. haha
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 05-04-2015, 11:55 AM   #56
OldChevy61
OldChevy61's Avatar
Where can I find pics of a 62 with the 72 motor stands bolted in. Or correct location specs. I know they need a 1/2 shim on top frame holes. I saw a post awhile back but can't seem to find it now.
Old 05-04-2015, 05:55 PM   #57
Lugnutz65
Lugnutz65's Avatar
Just sent you a PM.
Old 05-04-2015, 06:50 PM   #58
HumphreyMurdoch
HumphreyMurdoch's Avatar
If you want to keep the hydraulic clutch setup with a small block, you have a couple options.
1. Find an original Hydraulic Bellhousing with the casting number 3765710.
They are hard to find and usually too darn expensive, compared to a mechanical bellhousing.
There might be one on Ebay, the one picture looks promising and claims the right casting number.
http://www.ebay.com/itm/65-67-CHEV-G...5fe713&vxp=mtr
2. Your other option is use a mechanical bellhousing with the Novak setup.
https://www.novak-adapt.com/catalog/clutch/kit_hcr3.htm
But with the cost of a bellhousing and that setup, you probably won't save any money from an original hydraulic bellhousing.
Either way, if you convert to disc brakes. You'll need to buy Captains Master Cyl adapter. He has it for Manual or Power brakes and Hydraulic clutch or Mechanical. So Whatever setup you choose, hes got what you need and I can attest that his stuff is TOP NOTCH.
However, another option. I believe you can convert to mechanical clutch linkage too. I'm not certain on the what how to do that. I kept mine hydraulic.
'62 C10 LWB fleet side.
283 w/ a T5
HumphreyMurdoch is offline   Reply With Quote
Old 05-05-2015, 12:04 AM   #59
Captainfab
60-66 Nut
This is a pic I have posted before of the '67-'72 small block engine mount brackets siting on a '62 GMC frame and crossmember in the approximate location where they should be.
Old 05-05-2015, 07:15 AM   #60
OldChevy61
OldChevy61's Avatar
Thank you. That helps a lot. Now to get this thing dismantled and start moving forward.
Old 05-10-2015, 12:18 PM   #61
OldChevy61
OldChevy61's Avatar
Next question, going 350 using the 72 side mounts, will be running a T5 or Muncie 4 speed with newer model bell. Is there a source for a rear trans cross member for the 62,s. Found them for 63 on down, but not the 62 back.
Old 05-10-2015, 12:25 PM   #62
LVPhotos
LVPhotos's Avatar
I had some 1/2"×3" box tube Bolted to bottom of frame. One across and one small piece to shim up. A tube and flat plates can do the same thing.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 05-10-2015, 11:57 PM   #63
Captainfab
60-66 Nut
There are no aftermarket trans crossmembers for the '60-'62 trucks. You will have to fabricate one, or modify a factory one to work.
Old 05-11-2015, 06:10 PM   #64
OldChevy61
OldChevy61's Avatar
Headed to the pick n pull in the morning on a scouting mission. Any input on the nv3500 trans. They seem to have lots more s10,s in those year models than for the t5. Not that I'm in a hurry and can't wait on that. Mainly looking for a decent short or long block to build, but never know what I might run across.
Old 05-11-2015, 06:47 PM   #65
par4tom
Here is the bellhousing I have in my 61...it uses the factory crossmember and has the hydraulic clutch on the passenger side...is this what you are looking for? And, if I am reading your original question correctly, the "horseshoe" engine mount will work on the 350. In fact, I had that horseshoe mount on my engine for years...
You can use the factory holes for everything...
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 05-11-2015, 06:57 PM   #66
OldChevy61
OldChevy61's Avatar
Tom
I will either have to find one like this or go with a newer style that uses the slave cylinder and add a rear trans cross member. I would rather have the old style to use the existing cross member. As far as the horse shoe mount, I found a pair of 72 side mounts I'm gonna use.
Old 05-11-2015, 09:13 PM   #67
par4tom
Here's a couple of photos with the 67-72 motor mounts and the spacers on top of the frame rails.
My Build Thread
Old 05-11-2015, 09:13 PM   #68
Lugnutz65
Lugnutz65's Avatar
The NV3500 is something I have no experience with but many forum members view them as a good option equal to the T5. The problem is they are very difficult and expensive to rebuild (so I've been told). Wikipedia says the OD gear is 0.73 which is great for a 3.73 rear and even a 3.42 if you have a V8 SBC. The bell is incorporated with the case. An NV3500 pulled from a 4.3L engine in an S10 truck will have a SBC pattern bell. It would be a good choice if you can find one with low miles. I don't know how to hook up a hydraulic clutch to the NV3500.
Old 05-11-2015, 09:15 PM   #69
par4tom
Here's the other one. Sorry they are sideways, but you'll get the idea.
Tom
My Build Thread
Old 05-11-2015, 09:20 PM   #70
OldChevy61
OldChevy61's Avatar
Been doing a lot of reading on them this evening and not keen on the one piece bell and trans. No good info on the hydraulic clutch setup that I could understand. Will go with the T5 unless I find a good Muncie for a deal,lol.
Old 05-11-2015, 09:21 PM   #71
OldChevy61
OldChevy61's Avatar
Tom
That helps a lot. Hope I have patience to get my truck as clean as yours,lol
Old 05-11-2015, 09:35 PM   #72
Lugnutz65
Lugnutz65's Avatar
Do you mean a Muncie T10? That will have a 1:1 final drive which will be the same as a factory 3 speed. The T10 is a very popular choice with the muscle car crowd but if you go with that then maybe look for a taller rear diff for better highway RPMs.
Old 05-11-2015, 09:44 PM   #73
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Why don't you do a 427 BBC and Tremec 5 speed. lol Beat the heck outta a 350 anyday.
Old 05-11-2015, 09:47 PM   #74
OldChevy61
OldChevy61's Avatar
Lol, never liked a big block and them tremecs are a little out of my reach,if you know what I mean.lol
Old 05-11-2015, 09:52 PM   #75
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Ah, BBC means more power. lol I saved for almost 2 years before I did my hopped up 292 and tremec 5 speed. Well worth it.
