#1 | ||
Re: What can be said about the 4-speed New Process NV833 overdrive manual transmissio
I wouldn't have thought that would be the weak spot. Quote:
In later years they went to a flat stick which looks like a cleaner design. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Thank you Keith, I was totally thinking of you when asking that question, hoping you would see this thread and give us some factory know how, thanks again bud, really appreciate the feedback.
Maybe you can knock out the pins on the bottom and install a new Hurst handle? Or get the shifter parts to convert it to a bolt on type handle? Just a thought. I'm working late tonight but I should be able to get out my NP833 shifter and take some pics of how it's supposed to look.
#4 | |
I always used a thin piece of aluminum on either side (a steel scale might work, too). Insert it between the shift handle and the inside of the base to defeat the clips and the handle should slip right out. It just snaps back in for installation. You could keep that blade base/snap in feature and weld whatever shifter handle you wanted to the top of it (like the factory did). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 12-10-2015 at 01:30 PM. |
Moderator
![]() Join Date: Oct 2008
You could carefully slice through that weld with a cutoff wheel.
Some parts are available for the Comp Plus from Hurst https://www.hurstshiftersonline.com/...53&viewAll=yes The grease fitting makes it look like a Chrysler A-body shifter... the bendy bracket looks like it's for an 84 MY6 setup http://www.gmpartswiki.com/getpage?pageid=58016
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-09-2015 at 04:10 PM. |
thanks for all the help guys, I cleaned the shifter up a bit and am able to see some numbers on it, do these mean anything
#8 | |
Just patent numbers and internal codes. I don't see anything that looks like a GM part number. K
speaking of clutch forks, lol
it appears there is no difference between my 1974 one and one for a 1982 model, at least according to AutoZone, their part number is CF-100 for both and they reference the same O.E.M. #14066235 for both any thoughts or comments from you all on that? I am going to check on the throwout bearing next I am thinking can I just remove my 3,000 pound Muncie SM465 and bolt up my new beauty New Process 440 / 833 to my old bellhousing and keep the clutch guts inside undisturbed? that would make a short order out of this ordeal |
things get interesting when comparing throwout bearings, again using AutoZone (don't judge me) their website is great for this kind of stuff unlike some parts stores (I'm looking at you NAPA)
anywho, for 1974 they list 4 different ones, for 1982 they list 2 different ones, interstingly enough 1 is the same for both years, go figure Made by National Part Number: 614018 even more interesting is that both model years list a bearing made by Brute Power yet with different part numbers CC1705C vs 614018 sometimes I just don't understand AutoZone math, ha ha I'm going on about this because success is 80 percent pirsperation and the other 30 percent inspiration, jk |
![]() Join Date: Feb 2011
recent purchase NOS nob
MusicMan70 1961 GMC Suburban |
G = full size van
K
#13 |
Very nice.
I made mine out of a transfer case knob (new knob but with my old indicator "disc" inserted). The threads were different (fine vs coarse) but I ran a tap threw it to correct that. K
#14 |
![]() Join Date: Nov 2010
#15 |
Well after some research and studying all the HURST Shifter Stick charts I came to the realization (which you probably knew already) that GM was too cheap to buy the sticks from HURST and decided to use their own, aka generic ones, at least in the 81-83 era - correct me if I'm wrong
It appears that HURST tags all their sticks with their logo, its a pride thing I guess, kinda cool, well and my stick aint got not HURST written on it, does yours? (run out to the garage and check, we'll hold.... lol) here are some of the HURST stick charts I consulted SHIFTER STICKS Steel Sticks Page 40 SHIFTER STICKS Steel Sticks Page 41 same goes for the shift knob, it is also a GM creation, as I do not see any that look like our stock one (with that Overdrive feature) on HURST's website |
#16 | |||
Here's some more detail on the T case shift knob conversion. I notice both my knob and the replacement knob are textured; the NOS knob above appears "shiny" which is not how I recall them being. I would probably be ok with a more nostalgic round shift ball, but that might be just me. K Quote:
#17 | |
Moderator
And please let us know if and how your repairs were successful. |
#18 | |
The flat stick is what I noticed that made me want one so bad. What I grew up with:
#19 |
alright than, onward and upward, I really don't care if I have a name brand shifter stick or not, I'm just enjoying the research part, and sharing what I find, but remember always double check what you read on The Line, ha ha
ok now on to the Identification of our Transmission, HURST style, in other words which transmission is ours? Well again the HURST website / Transmission chart does not list our GM transmission, they show three different New Process 4 speeds but ours does not appear to be one of them. NEW PROCESS 421 for the Mopar A-Body NEW PROCESS 422 for the Mopar B-Body NEW PROCESS 423 for the Mopar B-Bory or E-Body Well what does that tell us or confirm? Again correct me if I am way off, but it confirms that we can't get our shift linkage rods from HURST since they never made them for GM, you see GM used / made their own linkage for this beast, fun fun fun making them that much harder to find, and they did not put part numbers on the sticks I don't think and rambling on and on, I heard of our trans refered to by the number 440 yet I have yet to see that anywhere in official GM documentation, they do refer to it as option MY6 but thats about it |
#20 |
As noted before, there are several shifters for GM. My 2wd and 4wd shifters are different, the 4wd appears to be heavier built and positioned slightly to the left when compared to the 2wd one, not sure if it's 4wd or a model year thing as it is earlier (mech bell while the 2wd is hydro belll).
Yes, the shifter itself can be rebuilt with Hurst parts or reconditioned by Hurst. No, the linkage can't be bought (remeber my earlier comment about getting the shifter? Turns out you need the shifter and all its rods as a package). The rods do not appear to directly interchange between the variations of shifters (look at the offsets). No, the early Chrysler parts do not work as is. I have heard that the Dodge truck shifter wil work although not in the exact same location, and again needs the rods to match the shifter. I have also heard that the early Chrysler shifter, possibly still available from Hurst, can be modded to work. I see you are looking for one of the rods. Can you detail exactly which of the shfters you have? Althouugh i doubt you can get a rod by itself, some clever person might be able to send you the pattern for the rod and/or make one for you.
1987 2 ton ![]() 1982 250/TH350 beater in progressDad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrappingPlus a mess o' tractors |
#21 | |
#22 | |
But the one you put together with the "grip" looks great too and the price is right!
#23 |
Any interest in letting the old one go?
#24 | |
I didn't keep it so I can't reconfirm at this point. K
#25 | |
If I get a chance I'll seeif they have tags still. They are in a shed with no lights so have to have a bright day and some ambition to get to them.
| Bookmarks |
